Question about Electrolux Washing Machines
Turn off sound electrolux inspire washing machine
When the wash is done the machine beeps repeatedly and it is very annoying. Is there a way to turn the wash cycle finished sound off?
SOURCE: my tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Posted on Jan 05, 2007
  • 3 Answers
SOURCE: very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Posted on Dec 06, 2008
  • 3 Answers
SOURCE: annoying beep when wash cycle finishes on bosch classixx 1400 express
You should be able to power up the appliance with the dial turned to "x" so that a programme is not selected and keep the door open so that the machine is certain not to start a cycle. Please let me know if this helps at all. Thank you.
jtbjtb
  • 135 Answers
Open the control panel and locate the beeper. Pull off one wire and tape over it with electrical tape. Voila! Hope this helps!
Posted on Jan 01, 2009
  • 130 Answers
SOURCE: GE Profile washing machine not finishing cycles
the OL error is for over load.that is when you over load the clothes in the washing machine. If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
Posted on May 07, 2009
How do I turn off the beeping noise on the Electrolux 7kg Time Manager washing machine the 5kg Electrolux Sensor Dryer? The beeping noises indicating a cycle has finished are very loud. Please help!
The acoustic signals operate when:
• The programme is completed.
• The appliance has a malfunction.
To deactivate/activate the acoustic signals, press "Drying level" and "Prewash" button at the same time for 6 seconds.
If you deactivate the acoustic signals, they continue operate when the appliance has a malfunction.
Dado
Mar 06, 2016 | Electrolux Washing Machines
Electrolux EWF 1495 won't spin.
The belt could be stretched or the tension idler could be malfunctioning.
Feb 12, 2015 | Electrolux Washing Machines
Constant beeping
Check to see if the electrical outlet is grounded. There is a little three pronged tester for that.
Nov 26, 2013 | Electrolux Washing Machines
Bosch nexxt inspiration
You may have blockage-clean your drain trap-if this doesn't help you may have a plugged hose or something stuck in the pump-cheers Denny
Oct 15, 2013 | Washing Machines
How do I fix washing machine electrolux inspire EWF 147 80 w stopped no power
check fuse in plug!
check wire
check internal fuses
does lights come on but no spin?check carbon brushes.
more info
Mar 19, 2013 | Washing Machines
Electrolux EWF 1074 - How do I turn off the annoying beeps at the end of every wash
I have touchscreen! Doesnt work. Any suggestions? Hate having to get up middle of night to turn off this )%(/₪/#&/₪(" beep!
Feb 29, 2012 | Electrolux EW1000i Front Load Washer
Very annoying beep when finished programme
Nov 23, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Electrolux 1087 E90
When the washing machine is turned on... it beeps and displays error message E90 it wont operate.
what can i do ?
Sep 15, 2007 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
