Question about Toshiba 32A35 32" TV
Crooked picture looks like the tube needs to turn clockwise
    Problem Solver:
  • 12 Answers
Try to turn the yolk,its at the back of the tube
Posted on Jan 13, 2009
How do i fix a crooked screen on an older tube t.v.?
The yoke needs to be turned slightly and the picture will move in the same direction as you rotate the Yoke. (located on the neck of the Picture Tube) Just loosen the screw on the yokes clamp slightly then carefully touch only plastic edge of the yoke and turn it slightly while an assistance watches the picture be careful not to slide the yoke up hugher or lower on the neck. It has to saty at the same spot but just rotated slightly.The pic below shows the yoke with yellow arraows. Do not disturb the purity rings (RED ARROW) or it will cause blotches in the picture so its very important not to disturb the item with red arrow.
Mar 06, 2013 | Televison & Video
No picture at all,sound ok 3 tube crts off after 4secs when on
might be a crooked flyback transformer, first check for shorted transistors around the transformer and components at the horizontal output stage..
Mar 31, 2009 | Philips Televison & Video
Red standby light light blinking
The 5 blinks can indicate a picture tube starting to fail. Carefully open up the back and look for the flyback transformer. It will be the part with the large red wire coming out the top that goes to the side of the picture tube. There should be 2 controls on the flyback, screen and focus. Turn the screen control slightly clockwise. If the set stays on, the picture tube is starting to fail and you have bought yourself time to find a replacement. If that fails, then you will need to investigate other possibilities that will involve soldering. Let me know if you need to do that.
The 6 blinks indicate no horiszontal. This can be as simple as a couple of bad capacitors or the "jungle" IC. If you can solder, please post another question with the model and a brief description indicating that you can work in the set and we'll continue to track this down.
Thanks,
Dan
Dec 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron - Picture Disappears
Hi, IK circuit is engaging which basically means the picture tube is getting tired, the only "fix" is temporary (may get another year out of it). You have to increase the "screen control clockwise".
Remove back of set, follow large black or red wire attatched to picture tube down to the flyback transformer, mounted on flyback are two black controls, one is focus (leave it alone) the other is "screen", adjust it clockwise approx. 1/4 inch, remember that this is a high voltage circuit so use one hand in the set the other hand out of the set at all times,any questions ? e-mail me back, good luck, BMW Rider
Feb 27, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Trinitron experiences
The screen control inside the set may be on the highvoltage transformer or on the crt socket; either way if you can turn it up just a little clockwise and the picture comes up but doesn't look good you are likely to have a bad tube. Or try tapping lightly on the glass neck and watch the picture as you tap. If it reacts to the tap you have a bad tube. but the turning the screen control is the best test. Turn it the other way the picture goes off immediately. bad tube: too costly if it is available.
Dec 29, 2007 | Televison & Video
Television
tbrace, your picture tube is getting a little tired, the "IK circuit" is causing the blanking of the video because the tube is not returning a large enough signal back to the IC that monitors it. Theres only one fix (besides replacing the tube) for your set and that is to turn up the screen control. You have to remove the back from the set and on the right hand side there is a large plastic part called a flyback transformer, with a heavy wire coming out of the top which goes up to the picture tube, mounted on the front of this transformer is 2 black blastic "philips type" controls, one over the other look closely and one will be marked focus(do not turn that one) and the other is the screen control, turn the set on and SLOWLY turn the control clockwise until you see a bright picture with white lines in it, once you see the lines turn it back until they disappear, (check several channels to be sure they are gone) your done, may last 3 weeks, may last a year, it`s all you can do, BMW Rider
Dec 14, 2007 | Televison & Video
Dark screen/picture.
This 30" flat screen TV set may have a problem in the high voltage circuit of the TV set. You may be able to adjust this by taking off the back of the TV set. Look for the block where the large red wire runs up to the top of the picture tube. On this block will be two controls. one will say screen and one will say focus. Try and slowly turn the control that says screen or S on it clockwise and see if you can make the picture brighter. Turn up the control till you just start to see faint lines in the picture, then back the control down till the lines go away. If the picture does not come up when you turn this up, and all you get is a blank screen, you will need to have this set repaired by a qualified repair person. Good Luck
Jul 14, 2007 | Sanyo HT30744 TV
Blue convergence
if the problem as atated only needs rotation, then your need to turn the yolk on the blue tube. you will have to slightly loosen the screw that hold the yolk. rutate it the proper way to get it aligned with the other colors. retighten the screw, but do not over tighten, you do not want to break the tube. ALSO make sure that you do not move the yolk UP or DOWN. if so the blue picture will be resized. down the picture goes smaller, up the picture gets bigger. good luck.
Dec 24, 2006 | Hitachi 60EX01B 60" Rear Projection...
Blurry screen GE 25GT511
hi There shouldnt be much in the focus system to go wrong as really there is nly the tube base and the flyback transformer. The usual for a TV is the tube faulty so its beyond repair. You could try the focus control, this will be on the flyback transformer. Back off TV, look for a heavy lead going to the dome of the tube at centre top and with eyes ONLY follow that back to the flyback transformer. On the side of that transformer is 2 screws, one near the top is the focus control. You will need a screwdriver to turn it and it usually has a seal to be broken. That will turn from say 8 o clock to 4 o clock no more, turn it up clockwise, try both ways. if it almost fixes but not quite it would be the tube. good luck
Mar 21, 2006 | GE 25GT511 25" TV
Toshiba 32A35 32" TV Logo
48 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
