Question about Miele Dishwashers
Miele G5100 length of normal wash cycle
Jusy got my first Miele. Normal wash cycle been running for 90 minutes. Is this right?
Amigaman
  • 248 Answers
SOURCE: 665.17019401 - Kenmore diswasher
It indicates a water temp problem. If water temp doesn't rise at a certain rate, by the heater, it goes into this error. Probably a problem with heater or wires to it.
Posted on Nov 22, 2007
aborcass
  • 2651 Answers
SOURCE: Have Whirlpool dishwasher Gold Series,
sounds like the door is losing contact with the door switch, first thing i would check is the door strike.Metal strike plate located on the tub itself that the door latch catches as it closes. its a spring metal striker, i would try bending it down a little bit to ensure better contact with the switches inside the door itself . next id open the control panel and check to make sure your door switches are secured well, wires are tight.
Posted on Mar 22, 2008
SOURCE: Kenmore 665 15899
To reset and run diagnosis on the model 15899100 Kenmore Dishwasher you need to press the following buttons on your front panel. Hi Temp, Air Dry, Hi temp, Air Dry. The sears service technician just left my house and used these codes to reset and run diag on my washer.
Hope this helps
Posted on May 28, 2009
stephanos18
  • 144 Answers
SOURCE: f3 error showing
F3 means the Dishwasher thinks it's water temperature in the tub is over 80oC. So when the unit stops see how hot the water is. The unit has a temp sensor which is part of the element which maybe faulty, the element maybe faulty or the Motor controller module is faulty. I'd try the Motor Controller module first as replacing the element can be a tricky job if you haven't done one before. If you have a double dishdrawer you can swap over the Motor Controller modules (main computers in the front of each drawer) as the top and bottom are the same part, inturn you will prove 100% if this is the fault or not without buying a new controller. Cheers
Posted on May 31, 2009
SOURCE: NORMAL Wash light is blinking and I can't CANCEL
We had the same issue with ours...tried turning off at the breaker, still didn't reset. Contacted appliance repair who came in and unplugged it from underneath the sink, waited a few seconds and plugged it back...dishwasher reset and repairman charged trip charge and labor $65 BUT problem is resolved and we now know what to do in the future.
Posted on Oct 18, 2009
How long is the wash cycle?
seems abnormally long as most full wash cycles ore only 60 minutes unless you include a soak section in the wash which will take longer
check for a deep rinse also adds time
Jan 31, 2016 | Kenmore Washing Machines
My Miele W1119 washer won't run. It was fine earlier today and I just completed a load of wash. When I started the next load on the Normal cycle, the timer lights to 58 minutes as always and the...
sounds like bushes mine done the same changed them now all good check it is not leaking water on to the bottom of machine this will activate the sensor to stop washing and drain water
Jun 04, 2017 | Miele Touchtronic W1119 Large Capacity...
The digital timer skips 9 minutes out of the wash cycle. After starting the normal 140 degree wash cycle (46 minutes) the washer will start and wash normally until it has counted down to 41, then it...
hi shotgun - sometimes the mieles with auto adjustment functions do make changes to the wash time - usually based on a smart sensor technology.
Unfortunately I have no data or information for your particular model, I have info on earlier & the latest models only. In hindsight what this function does is adjust water levels based on the load weight or amount of the wash, the computer then calibrates the water levels and accordingly the amount of time to wash.
Eg - 4 kg load would be longer than say a load 1.5kg to process - if can understand this concept. However I cannot be 100% certain it applies to your particular model, if the user manual is availbel it may just pay to read thru in case it applies to the washer.
Jun 21, 2011 | Miele Super Novotronic W1986 Front Load...
How long is the light wash cycle suppossed to run and does the options cycle need to be run too? i have put my machine on light cycle and it runs back and forth from sensing to wash .. stops and goes back...
Hello, Thank You for using FixYa. I will be helping you today.Yes it is normal. The length of the cycle depends on the water temperature entering the unit and the options selected. The unit has a sensor that checks the water constantly until it is clean. A normal cycle on this unit with options selected can last two hours. And stopping the unit and opening the door extends the time also.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Whirlpool DU1055XTV 24 in Builtin...
Question about a W4802 washing machine - can the water level / amount of water used in the machine for wash and rinse cycles be increased?
Hi - not under normal conditions, these are factory set only the Miele Agents can alter the programmes pending on their softwares.
Jun 14, 2011 | Miele W 4802 Washer
We just installed a new kenmore dishwasher yesterday. Model 13242 It has been running for almost2 hours and is still on the washing cycle--no water in it however--is this normal? I'm in a bit of a panic as...
THAT IS NOT NORMAL!!!!!!! A normal wash and dry cycle will take approx. 2 hours in length including drying cycle.
You should see that water has been present in the machine within the first 2 minutes of the start of the wash cycle, you should also be able to hear the water entering the wash tub.
The fill valve or water supply seems to be the issue, if the water doesn't enter the tub then the controller won't proceed witht the wash cycle. Double check your water supply tube / hose to make sure there is water present at the connection to the dishwasher.
GOOD LUCK !
Aug 08, 2010 | Kenmore Dishwashers
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
My dishwasher is seeming to stay on the wash cycle. How long is a normal wash cycle?
Dishwashers today use a lot less water and energy to do this they filter the water like crazy this makes the wash times go way up, the motor used today uses only a little power so a long cycle does not cost much.
They average wash time for a new machine is 90 - 120 minutes. Some high efficiency units can run 4 hours per cycle.
Apr 24, 2010 | Kenmore Dishwashers
Dishwasher takes hours to run through wash and dry cycle. what should normal cycle time be?
2 to 6 hours is possible. The newer machines have a water heat cycle that will raise the water temperature. lets say your incoming water is 90 degrees. The machine want to see 140 -165 depending on the cycle so that cycle will take 75 minutes to reach 165 (1 min per degree temp rise). multiply that by the number of wash and rinse cycles and it can run a very long time. Water should enter the washer at 120 degrees minimum. let it fill and measure the temp you will be surprised. Eric
Sep 13, 2009 | Kenmore Dishwashers
Miele Dishwasher G2170 3 year old
On the display panel of the washing machine there are a few screws on the side. Remove that panel and check for power at the computer and sensor. Also make sure that when it is one and calling for water that it is getting everything everywhere
Feb 14, 2009 | Miele Advanta G2170SCSF Dishwasher
Dishwashers Logo
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
