Question about Samsung HT-DB120 System
Some how i have locked myself out of the dvd system
It will not open the disk drive, it just comes up with the message opening, but never opens. It was working fine on friday evening, but after i tried to set the parental lock it wont open and it the logo does not appear on the screen anymore. Please help. Thanks
  • vesnaveles Dec 17, 2008
    I have the identical problem with spiders's problem bat i trye with a new motor and nothing ht-db120
Try a hard reset of leave it off for 24 hours it worked for me if there dont help im out of ideas bestr eguards nick
Posted on Jul 13, 2007
Dvd drive is flashing and wont release dvd and has system locked
Turn the system off completely even if you have to unplug it. Then use a paperclip or equivalent to open the drive through the manual access hole. This is the tiny hole on the front of the tray that will open the drive when the system is off. Remove the disk and restart the system. Don't use that disc. Hope this helps
Jul 11, 2011 | Dell Inspiron 1525 Notebook
DVD does`t open. It have one disc inside and I need it. Exist one software command (by pc) that permit to open the dvd without use the open key? Thank you, Jorge Lopez
Any operating system that believes the disk is in use may restrict the disk bay from opening by the use of the drive button or a soft eject keystroke. In Windows this most commonly happens when the system believes itself to be actively accessing or installing from the CD/DVD drive when actually the disk is unreadable, the drive has become unmounted, or a software product has locked the drive. In this case, there is no soft key command to force it to open.
You essentially have three choices:
  1. Wait for the application using the drive to time out and then eject the disk normally
  2. Force quit the application or software that is monopolizing the drive then eject the disk.
  3. Restart the computer to terminate any processes currently monopolizing the drive.
  4. Force a paper clip in the small access hole to manually eject the drive. (I know this third is exactly what you didn't want to do)
Apr 26, 2010 | Sony (DDU1613) (ddu1613black) Internal DVD...
Everytime i put in a game in my 360 it says open tray
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1. Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser. The laser is the part that actually reads the disc. The reality is... with all the hours and hours of gameplay, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3. Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything, including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock. The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
Mar 17, 2010 | Microsoft Xbox 360 Halo 3 Special Edition...
Open tray error
Nov 11, 2009 | Microsoft Xbox 360 Console
It keeps on saying open tray
Wont read the disc itll jus say readin then say open tray
HTML clipboard This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
Nov 09, 2009 | Microsoft Xbox 360 Console
DVD CD-R drive does not recognize a blank CD on toshiba sattelite
Try this before you enter disk.
  1. setup software or files to transfer when prompted to enter CDR, then place in drive.
  2. Or open my computer, select cd drive right click select, format disk. When prompt comes up for disk insert CDR.
Some systems have trouble with other manufactured formatted disk.
Mar 06, 2009 | Toshiba Computers & Internet
DVD HO1 error, and tray is jammed - how do i change the mode to External Port (iPod)?
It means that there's a misaligned disk inside. You need to
1. Unplug it and shake it side-to-side.
2. Then turn it on and press the open/close.
3. If it doesn't open, goto step 1.
4. When it opens, get the disks out, use disk exchange to try to get them all out.
5. Turn it off, unplug it, shake it again and make sure that there isn't another loose disk, if there is, then open it and get it out.
This is a known flaw in certain Panasonic DVD changers. Good luck
-Senrich
Nov 01, 2008 | Panasonic SC-HT740 System
Dell Inspiron-1520 unable to read RW DVD's.
you have a faulty disk inserted in the drive. Restart the computer and continuously press eject while the pc is booting, it should eject then.
Oct 11, 2008 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Disc tray locked
there is a small hole outside the disk-tray. it may anywhere
put a thin needle inside that when the computer is on
warning: Be sure that you stand or touch on a wooden plank for safety
Jun 08, 2008 | Panasonic SC-HT70 System
Samsung HT-DB120 System Logo
154 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
