Question about Samsung HLP4663W 46" Rear Projection HDTV
6 months ago, the colors started messing up and it made this screaming banshee sound. The TV would turn itself off after a minute or so. I read about it and figured it was the color wheel. I bought a replacement part but while it was being shipped, the TV started working correctly again. Last week, it started doing it again. I replaced the color wheel and the TV now runs quietly but still no picture. The lamp light was flashing and I noticed no light coming out the back of the tv. I ordered a replacement lamp (Samsung genuine parts) and replaced it but still no picture. The lamp light is blinking on the panel. The TV turns itself off after a minute or so still and then all panel lights blink. Ideas?
  • 98 Answers
You need to put in the values for x,y, of red,blue,green & white.
when you get the color wheel, sticker(printed values) was in the same box.
If you have, let me know and I''ll let you know how to put in.
Posted on Feb 12, 2009
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
Sony Wega 42
Sounds like the bulb popped up... does it smells like there something that burned? any error light?
Apr 24, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tip
How To Replace the Color Wheel in Your Samsung DLP Television and Save $400
I’ve got one of the early models of the Samsung 43′ DLP Television sets. We’ve been through a lot together, but it’s just a fantastic picture. I love it.
Thankfully, I purchased the extended warranty for 4 years, because I’ve been through 3 lamps. However, as always, something went wrong after the warranty expired. It started a few months ago, a buzzing sound. It started out pretty soft, like someone was holding a very thin wire in the blades of a running fan. As weeks passed, that sound increased, and finally it became an all-out scream (just in time for the World Cup). Inside this television are only two moving parts that could cause that sound, the cooling fan and the color wheel. I know about the color wheel because I’ve seen it talked about over and over again on the Internet. I think the service guy may have mentioned it once or twice when he was here replacing the lamp. With all that mention, clearly this thing has issues. And, I can see the fan, and it doesn’t spin at the same time that this sound is produced.
samsung-color-wheel.jpgWhat’s a color wheel? I’m not sure exactly it’s purpose, but it has a small motor and it spins at about 9000 RPM. The older model Samsung televisions are plagued with the problem where the bearings in this little motor go and starts to sound like a banshee, or at least what I imagine a screaming banshee to sound like. Anyway, it’s pretty bad.
It needed to be replaced. There was no longer any putting it off. I happened to mention it to a BestBuy sales-kid and asked him where I should have it fixed. He said I could just call a local Samsung authorized repair shop, or “you could just repair it yourself.” The words echoed in my mind. I never considered that possibility and I dreaded the thought of my television being picked up or dropped off and gone for weeks. When I got home, I went online and found a few forums where guys shared that they successfully replaced their own color wheels and that it wasn’t that difficult. Say no more…
If you have the same problem and are thinking about fixing it yourself, it really isn’t that difficult. If you’ve ever taken your PC apart, this is not much different… The process involves about 20 screws, 5 or 6 cables to unplug, and of course put it all back. The toughest part about these projects is knowing what to take out and where to look for the part you’re replacing. The first time, I took out quite a bit more screws and cables than necessary. I did it again to write this article and now you don’t need to think about all that.
this will be continued in next TIP
on Mar 30, 2008 | Samsung DLP HL-P5663W 56" TV
50v710 turns off by itself then on
Have you check the power supply,that's what it seems to me.
Jun 29, 2009 | Hitachi 50V710 50" Rear Projection...
Samsung DLP TV has lot picture. Makes a Humming sound
That sounds most like the color wheel,
to change that you need to have some skill in electronics, I would recommend to take it to a shop
Apr 25, 2009 | Samsung DLP HL-P5663W 56" TV
MY HOME THEATRE AMP. SHUTS OFF ITSELF, AND SOMETIMES SCREAMS W/ N
First suggestion is to recheck all the connections
Rifaa
Nov 12, 2008 | GE GTD120 System
Samsung rear projection tv
I think it could be a faulty diode on the power supply board. If you can check this for yourself otherwise call out a competant technician. Good luck.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
RCA F32450 TV problem
color ic on the blink.
Jun 16, 2008 | RCA F32450 32" TV
Vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Dec 17, 2007 | Samsung LNT3242H Television
Samsung HLP4663W 46" Rear Projection HDTV Logo
87 people viewed this question
Henry  Thomas
Henry Thomas
