Question about Sewing Machines
I have a crofton 3032 white sewing machine and my thread keeps breaking. Could i have threaded it wrong? If so can you tell me how it needs to be done step by step?
I am not a sewing expert, and im trying to figure out why my thread is breeaking after starting to sew. Ive tried adjusting the tension, & threading my needle through both ways. Im not sure where ive went wrong.
SOURCE: Thread breaking
Well, I have owned the Janome 1600DP with the Gracie Frame for 3 years now and have only successfully quilting 3 quilts. Its very intimidating how easily the thread breaks!!!! Add hot flashes with the frustration and I've almost given up. Today, I think I have found something. I cleaned the bobbin case, cleaned between the discs, put in a new needle (using the one recommended) but I put the spool of thread in a coffee cup located at the non-sewing end of the machine, sitting it on the Gracie Frame. Then the thread is through the metal eye ring that came with the frame. All the rest of the threading is per the Janome instructions. So far, so good. There you have it but if I had to purchase a sewing machine again for quilting quilts, it would NOT be a Janome!!!
Posted on Oct 04, 2008
SOURCE: Bicor vx1005 ...thread keeps bunching
Try a different bobbin. Look for one that is a little narrower. I had the same problem and changing to a narrower bobbin fixed it.
Posted on Mar 29, 2009
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
  • 9 Answers
SOURCE: NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
Posted on Jun 14, 2009
  • 55 Answers
SOURCE: Thread Breaking On Brother Sewing Machine
if thread is good quality you may have a sharp groove in your needle plate hole from needle breakage. if so, polish with emery tape.
scott
Posted on Jul 27, 2009
I DO NOT HAVE A MANUAL FOR 8708. I ALSO AM HAVING TROUBLE WITH THE UPPER THREAD,( PROPER THREADING NEEDED,) IT KEEPS BREAKING, PLEASE HELP. VINCENT
The manual may help (assuming this is your machine):
Crofton MD 8708 Instruction Manual
The thread will break if the machine is threaded incorrectly. Be sure to ALWAYS RAISE the presser foot when threading the upper thread. Also, set the upper tension to the midway point. This is the standard setting for machines although there may need to be some tweaking to get the tension where you want it.
Oct 20, 2016 | Sewing Machines
Try sewing but bottom thread on fabric is crumpING UP
needle thread tension is not adjusted up properly tighten the setting until you have resistance when you pull the thread to thread the needle
Oct 02, 2016 | Sewing Machines
White 2037 twin needle keeps breaking thread
Thread breakage occurs commonly with mis-threading. Be sure to ALWAYS RAISE the presser foot when threading the top thread. Also, since you are using 2 threads, thread one completely and then thread the other so the threads do not get twisted in the thread path. If your machine has duel tension disks, thread each tension disk separately with a single thread. Setting the thread spools to turn opposite directions may help.
Also, make sure the needle eye is the right size for the thread. Thick or thin thread could break easily in the wrong needle.
Also, use only good quality thread--no bargain bin or old threads!
twin needle thread breakage Google Search
Nov 25, 2017 | White Sewing 2037 Mechanical Sewing...
Pressure foot for crofton machine
Should be standard at any sewing machine sho
Oct 06, 2013 | White Sewing White 3032
Riccar sewing machine tension
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Aug 05, 2013 | Sewing Machines
THE COTTON KEEPS ON BREAKING EACH TIME I WANT O SEW WITH MY YAMATA FY940
The needle thread breaks
8. try a different thread
9. try adjusting the top thread tension--to a lesser number or letter
use your manual to guide you through tension adjusting
Dec 20, 2012 | Sewing Machines
Why does my thread keep breaking on my machine while i am sewing
the top tension could be to tight
the needle could be damaged
try rethreading the machine just in case the thread is caught somewhere
clean under the needle plate & bobbin area for lint or loose threads
always make sure the top & bobbin thread tails are at least 3 to 6 inches long & pulled behind the needle to the back of the machine
Aug 29, 2011 | White Sewing White 3032
Sewing Machines Logo
41 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
