Question about Fagor Dishwashers
Fagor lf-017s Hi, my fagor dish washer is showing an f3 alarm. f3 shows as a flood or not draining alarm in my booklet. However there is no remaining water inside the dishwasher. I have removed the dishwasher and checked the pump which is fine. The pump is running at the start of each cycle until thr f3 alarm steps in. Any ideas why the machine is still asking to drain when there is no water inside?
  • Fagor Master
  • 2,760 Answers
The water level float is stuck in the "UP" position
Posted on Sep 04, 2015
micromaster
  • 3614 Answers
SOURCE: dishwashing machine not fully draining (2 inches of water remain)
Following a cycle, a small pool of clean water inside the tub is typical. Excessive water means the pump isn't pumping water out properly, the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up. If dirty water spews from the air gap, the drain line is kinked or clogged. Note: If you've recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made (see your disposer instructions).
Posted on Apr 22, 2008
  • 82 Answers
SOURCE: Viking dish washer won't drain
Try clearing the air gap (which is the seemingly pointless thing that is near your kitchen faucet.)
1.Take off the shiny metal cover, and you can sometimes twist off the plastic cap, or you may need to use needle nose pliers to push in the tabs that hold it in. You may or may not see debris in the tube that is in the air-gap.
2. Now what you need to do is take a clear glass and put it over the air-gap with part of the glass hanging over the edge of the sink, you may want to put a towel around the other side of the glass to keep the water from going all over the counter, turn the dishwasher off then on again and select "rinse and hold". If there is any thing in the line it will come out.
3.If not you may need to take out the filter in the bottom of the dishwasher and on the left hand side in the sump area there is a small, (usually yellow) cap that covers the drain motor impeller that can usually be pulled towards the center/right by hand, if not with needle nose pliers. You will need to vacuum out the water with a wet/dry vacuum or towels.
If none of this works, let me know and I will go over some more uncommon draining problems.
Posted on Dec 08, 2008
  • 14 Answers
SOURCE: Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
Posted on Jun 19, 2009
QueenJLyn
  • 3 Answers
SOURCE: Maytag dishwasher not draining fully
Try cleaning out the air gap.  The air gap is not part of the machine, and is located on your sink. If this becomes clogged, it may cause the machine to not drain properly.  Also, I know you said you checked the drain hose and cleaned as far as the filter and chopper blade, but have you checked the lower filter?  There is a filter located underneath the machine that should periodically be cleaned.  To check this, you need to access the machine from underneath by removing the bottom vanity cover. Hope that one of these helps!
Posted on Aug 01, 2009
SOURCE: Zanussi ZSF 6161 Dishwasher with Error 30 Code
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
Posted on Sep 06, 2009
Fagor dishwasher is showing F2 please help.
Not drained in time allowed (6 minutes) - washing machine fails to drain water
  • Check that filter is not blocked or obstructed
  • Check drain hose is clear of any blockage or obstruction
  • Check wiring to drain pump
  • Check drain pump is not defective
  • Check level sensor or switch
  • Check wiring to level sensor
Aug 12, 2016 | Fagor Dishwashers
Fagor LF 65IT beeps 4 times a few minutes after switching on and all lights flashing on display
This is a flood warning. You must have water in the bottom of your machine which has raised the float and activated the flood switch. Open the lower front panel on your machine and for where the leak is coming from.
Apr 03, 2012 | Fagor LFA-65 IT Dishwasher
Im receiving the LF code what does this mean??
Check that the drain hose and water inlet hose are properly installed, and undo any kinks or clear any clogs if the display error reads "LF" indicating that the load is taking too long to fill, or "Ld" indicating that the washer is taking to long to drain. If the code reads "HC," the hot water hose is installed in the spot for the cold water hose and vice versa.
Also, check this information from Whirlpool DataBase: Display shows LF
Hope helps (remember to rate and comment this answer).
Sep 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Pump running continuously, Yes there was a drain pack, have emptied water, float switch clicks when moved with screw driver. Only one red light shows ( last cycle - pots ) what else can I do... James
What type of dishwasher do you have? Has your kitchen floor flooded? If it has. The tray under dish washer isn't water tight. Moisture creates some unusual problems. Some of newer dish washer the there control panel under the top of door this also create problem especially if the switches are on the top of the door. Another moisture problem. I have repaired a new Electrolux dish was three times in less than 6 months. The floor would flood from the Maytag side load washing machine. The Madam of the house didn't tell me that the washing machine flooded the kitchen floor. No window in the door and sometime fill water solenoid would stick and fill the tube. When they open washing machine door, 12 gallons of water would spill. So I fix both of them. GB...stewbison
Aug 21, 2011 | Asko Dishwashers
Deloghi dw67s dishwasher, drain pump on continuously, showing E4 and no water in washer. What is used to detect the overflow?
Hello
There is a slight leak somewhere or the machine keeps overfilling causing the drain pan to activate via the flood switch.
remove all dish trays from washer, unscrew and remove lid off salt softener, almost and thoroughly remove as much excess water as you can, it could be the vacuum switch/water level float.. do the tip over again, and be sure you get it all,
replace all trays and softner lid and machine should work again.
Aug 09, 2011 | Dishwashers
I HAVE THE SAMSUNG DISHWASHER dms300trs AND IT SHOWS F3 ERROR ???
Have the same problem with brand new, unused DMS500TR dishwasher. Rang Samsung, they said F3 is a water leak error.
Aug 19, 2010 | Dishwashers
What does error code F3 means?
error code f3 shows that there is a problem in the heating circuit of the dish washer. you may need to access the Heater or relay on the control board for any defect also check the wiring
Apr 05, 2010 | Whirlpool 24 in. ADP5962 Free-standing...
ERROR F3 - WHAT DO I DO?
hi the error shows bcoz of ur door problem...
replace the door lock and ur problem will be solved...
May 24, 2009 | Asko W6441 Front Load Washer
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Fagor dish washer VFU-05S
What do I do to overcome the fault 'F3' accompanied by beeping ?
Jul 15, 2008 | Fagor LFA-019 SS Stainless Steel...
Dishwashers Logo
143 people viewed this question
Top Fagor Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Dennis
J.D. Browning
J.D. Browning
Are you a Fagor Dishwasher Expert? Answer questions, earn points and help others
