Question about HP Pavilion tx2500z Notebook
Orientating my Screen after I switch into tablet mode.
The first time I flipped my screen around and used the tablet mode, the computer automatically re orientated the computer screen. Now every time I switch to tablet mode i have to turn the computer around, otherwise the screen would be upside down.
    Problem Solver:
  • 15 Answers
You can press the Orientation Button located in the right bottom corner of screen. It is marked with two arrows following each other in a circle.
Moreover, you can set as default the screen orientation you desire in Tablet Properties.
Also, remove the battery for 10 seconds and reinsert. This will enable auto orienting of screen.
Posted on Jul 11, 2009
I have a RCA tablet model# RCT6272W23 the screen was broken. I replaced the screen with one that my friend had. Everything but the brand was the same . I mean everything perfect to the point. It turns on...
Greetings.
Not all screens are interchangeable even same Make and Models can have problems. What is the make of the screen tablet you used to replace on your broken one? It may have some issues with size or your tablet may have been damage when you cracked the orginal screen.
Try if you dare flipping it 180 degrees around to see if it fixes the issue.
Good luck
chadman
Mar 10, 2015 | Tablets & eReaders
Just bought a emerson EM744 tablet and the screen show 3xs everything even when chargeing it has 3 batterys like the screen is split is there a way to fix this or should I just take it back?
I fixed this triple screen issue by opening the unit (slide fingernail around the edge), then reseat the video connector, it's the largest connector, flip up the locking tab, then reseat the connector & flip the tab back down. Test it, then close it up.
Dec 25, 2013 | Tablets & eReaders
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
Rotate screen back to normal
Feb 23, 2013 | Gateway Computers & Internet
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Feb 15, 2013 | Samsung N120-12GW Netbook
My screen does not flip 180 degrees when i turn the screen around
Jan 28, 2013 | Panasonic Toughbook 19 Rugged Notebook -...
My son has rotated the screen on my fujitsu lifebook s series so now it is upside down! How do i rotate it back? Please help!
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
Jan 21, 2013 | Intel S6240 Notebook
Acer tablet troubleshooting
b>
Jan 14, 2013 | Computers & Internet
Change screen orientation
b>
Dec 14, 2012 | Dell Computers & Internet
HP Pavilion tx2500z Notebook Logo
335 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
