Question about Maytag MDE9700AYW Neptune 174 Electric Dryer
Drum doesn't turn in maytag neptune MDE9700AYW
I took the top off the dryer and the belt was very loose and just laying on the drum (but not broken, it appears) It would seem it has just come off but the more screws I take out to get to the innards of the dryer the more I need to take out. My fear is I'll get it apart and never get it back together.
Any manuals out ther online or somethin'?
Thanks,
EdO
  • 21 Answers
Just remove the screws around the vent tube in the back and you can see the belt tensioner laying there on the floor of the dryer.
Most likely someone turned the drum the wrong direction and the belt came off.
The belt goes through the opening in the tensioner and under the idler pulley and then onto the motor drive pulley. Make sure to have the tensioner mounted into the floor first.
It just slides over into a slot and then over to the other side as tension is put on it.
Posted on Jan 18, 2009
  • raymond_stil
    raymond_stil Jun 10, 2012
    the belt still continues to be loose. any recommendations??
Stopped working today. will not come back on at all. lights come on like it is working, but drum doesnt roll
Check the belt, Remove the bottom kick panel and clean out the lint. turn the drum and see if it is broken or loose.
Jul 07, 2014 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag neptune dryer belt off and loose
If belt is not broken, then the tensioner is not routed properly. Generally belt comes around drum, then around tensioner pulley then on motor pulley. Tensioner is spring loaded, so you need to pull up on tensioner to get belt around motor. Good luck.
May 05, 2017 | Maytag MDE9700AYW Neptune 174 Electric...
Dyrer wont run lights come on but wont run
If the belt is not off, it may be a loose wire to the sensor that switches the dryer off when the belt is off or broken. Mine had that problem. If that doesn't work you will have to replace the tension pulley sensor.
Oct 27, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Felt belt found inside of drum
Hi - these are used to minimize the metal to metal contact of the drum & housing.
One will need to remove the top & front panels to gain access to remove the drum, afix felt to end in question and assemble the machine again.
Jun 14, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Neptune Electric Dryer Broken Drum
look in your owners manuel and see if the drum is covered.
Jun 23, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
the problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
Apr 21, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Neptune Maytag MDE9700AYW
Remove the screws from the bracket from the vent tube at the back of the dryer.
You can access the belt from there.
If the belt is off then the tensioner will push a switch to shut the dryer down.
Just hook the belt back on or replace the belt whatever needs to be done.
See other posts for this model number on how to connect the belt back if it came off.
They do that when turned the wrong direction.
Oct 11, 2008 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag frontload dryer MDE9700AYW
take the door off. take the front panel off. take the belt off the tumbler. take the tumbler out. you should see the roller. everything is held with regular phillips head screws.
Nov 10, 2007 | Maytag MDE9700AYM Electric Dryer
Maytag MDE9700AYW Neptune 174 Electric Dryer Logo
447 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
