Question about Sentry Safe Fire-Safe Personal Safe
Sentry S0500 Safe Won't Open Dead
Dead Battery
SOURCE: Sentry S3807 safe-cannot open
locksmiths agree on how to install sentury safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe?
to install batteries, turn the electronic lock case to the right and remove.Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Posted on Aug 09, 2010
  • 412 Answers
SOURCE: sentry 1610 safe - battery is dying?
I have 2 Sentry 1610 Safes. A fresh alkaline battery MAY open the safe once (maybe twice), and then the same problem. I have a variable DC power supply that I hook up to the battery terminals, set to 9 volts and increase the current until the keypad responds & the deadbolt releases. Sentry has no solution for this problem, as this model is too old & they have no parts or troubleshooting. If you know someone with a small DC Power Supply, you can get your safe open / closed.
Posted on Nov 02, 2010
SOURCE: The battery on my DSW3607
the battery pack is in the front where the combination is located. take off the front part, there is a screw at the bottom, batteries are behind.
Posted on Dec 10, 2010
  • 7 Answers
SOURCE: I need to open a Sentry safe V252 and I don't have the combination?
get an oversized flat tip screwdriver and a hammer and slide the flart tip in the gap where it opens just above the combo and swing away it will break the lock loose and you will be able to open it
Posted on May 21, 2012
Testimonial: "Thank you very much:) "
  • 53 Answers
SOURCE: How do I open a sentry s3877 safe when the battery is dead and safe is closed
The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
If you do not know your factory code, you can follow this link for your combination retrieval:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Posted on Sep 23, 2012
How do I open my Sentry Safe when the batteries have gone dead?
Some safes come with a key to open it with when this happens.key hole is cancelled under or near the keypad...not sure if yours is one of them.or there maybe a slot to plug in a battery pack .good luck..hope I have helped.
Oct 03, 2014 | Sentry FIRE-SAFE Combination Safe DS3431,...
Sep 23, 2012 | Sentry Fireproof Safe
What do you do if the batteries are dead in my Sentry fire safe and can't put code in ?
a1 locksmith advised me to To install batteries, remove cover between knob and keypad.Unlock door with the override key provided in the plastic bag attached to the owner's manual, and open the door using the knob. Remove battery cover located on the inside back of the door by sliding to the right. Insert the four batteries as indicated. Replace the battery cover.
Jul 23, 2012 | Sentry Security Safe with Electronic Lock...
I have the didgital S0500 and can't find the instruction booklet. How can I change the entry code and where do I replace the battery Is it possible to get another booklet Thanx
http://www.sentrysafe.com/CustomerCare/Product_Manuals
Go to this link and put in the product information and it will give you a pdf of the user manual.
Mar 14, 2011 | Sentry Safe Fire-Safe Personal Safe
I need a battery holder (for 4aa batterys) for my s0500 fire safe. how much and how do i order
most electrical stores carry these at around $2.00
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 13, 2009 | Sentry Fireproof Safe
Sentry safe S3877 have key and know combination but battery dead
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Apr 08, 2009 | Sentry Fireproof Safe
Jan 26, 2009 | Sentry Fireproof Safe
Sentry Safe Fire-Safe Personal Safe Logo
509 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Joseph Vernice
Joseph Vernice
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
