Question about Wurlitzer Audio Players & Recorders
Rowe cd 100B picks up the wrong selections
Picks up the wrong cd
4 Suggested Answers
SOURCE: I have an 1991 ami rowe juke box -laserstar
I operate rowe cd 100 jukeboxes for a living, In the manual it will tell you what these error codes are, off the top of my head I know that one to mean either there is a problem with the inner or outter cam switch. these switches are located under what we call the transfer motor, there will be two of them look in your manual to see whether the error relates to the inner or outter cam switch. Inner being the one closest to the actual mechanism and outter being the one furthest from the mechanism. The switches are usually black but can be white and are about the size of an block ink/pencil eraser. You most likely can get the switch from a local electronics store I.E. radio shack.
Posted on Oct 22, 2010
  • 149 Answers
SOURCE: I just purchased a Rowe 100B CD jukebox. Most of
Hi,when a CD skips like that, it means that the lens of the player is getting weak,that's when a CD player skips.
You might want to replace the lens of the player or before doing that,you can use a lens cleaner to clean up the lens, might be dirty..
After cleaning the lens and it still skips, you will need to replace the lens.
Would advice, if it's still on guarantee, you could simply go and replace it with another one,instead of going through the stress of repairs. Just an advice.
Have a nice day..
Posted on Feb 17, 2011
  • 23 Answers
SOURCE: Row Jukebox 100B CD stops playing
Have you tried using a different disc?
If the disc is playing fine and then stopping, 9 times out of 10 it's the disc, not the player..
Posted on May 04, 2011
How do I fix my rowe juke box?
Sensor circuits for locating specific records has gone south.
Did you contact Rowe for assistance?
Sep 25, 2015 | Audio Players & Recorders
Row Jukebox 100B CD stops playing half way into a song. system error light is flashing on. I cleaned the lens, didn't help
It sounds like your laser lens may have or be in the process of kicking the bucket.
What you CAN do is adjust the POT on your lens...a fairly simple process if you can get at the lens assembly. Not so simple if you have to take everything apart to get to it.
Google "laser pot adjustment" and read up on how to do it.
If you aren't tech-savvy you may want to consider purchasing a new device or drive for your device.
May 04, 2011 | Audio Players & Recorders
I just purchased a Rowe 100B CD jukebox. Most of the CD's skip a little. Does this mean the CD player is going bad, or could there be another problem. I'd hate to replace the CD player if there's a simpler...
Have a nice day..
Feb 17, 2011 | Audio Players & Recorders
Hi' I have just got a rowe ami r-83 disco jukebox. All is ffine apart from when you select say 120, it picks up and plays 168. Any ideas. Regards Chris
you need to check the Home signal to make sure the opto is activated at position 99. When the unit powers up the mechanism scans one complete cycle so it re-indexes the computer and starts scanning from position 00. If you want a quick test, turn the power off and scan the carousel to position 99 by releasing the latch on the left side of the mech just under and behind the mechanism motor. then power up the unit and it should pick the right selection. You can also observe the optic indicators on the mechanism control board under the turntable. The Home signal only operates at 99, the Index pulses between each record as it scans. Good Luck
Nov 29, 2010 | Wurlitzer Jukebox 1015 One More Time...
I have an 1991 ami rowe juke box -laserstar cd-100b with error 05-62-how can I fix it??? I own operator and service manuals.
Jul 14, 2010 | Audio Players & Recorders
Rowe Nostalgia jukebox will only play a few of the numbers of the 100 cd;s. Is there anyway to reset it so it will play all numbers?
You will need to go into the programming section on the menu.
I suggest that if you do not have a manual that you obtain one from Rowe Ami, Victory Glass or distribution.
Have you initalised all of the CD's on your jukebox? Every time you replace a CD you have to initalise it.
Regards
Alan Hood
ami-man
UK
Jan 31, 2010 | Wurlitzer Jukebox 1015 One More Time...
Rowe ami jukebox
Check the optical sensor, it may be blocked with dust.
Jun 09, 2008 | Audio Players & Recorders
Rowe jukebox
I take it that the jukebox accepts selections when you type them in. Also that you have tried selecting the A side and the B side records.
Is the switch on the CCC (Central Control Computer) set to Record it should not be set to Video.
Rowe Ami jukeboxes are very pone to dry (cold in the USA) joints.
If you can solder then the following items need to checked for dry joints.
Power Supply PCB (printed circuit board)
CCC
Mechanism Control Board
When taking out the plugs pull on the plugs (not the wires)
Look on the soldered side where the connectors pins are fitted for any cracking around the soldered joint ( this is the sign of a dry joint).
Resolder any suspect joints on all of the boards and refit into the jukebox and test.
If this does not cure the problem then the boards will be needed to be sent to a Rowe Ami specalist, I am one of these in the UK.
Regards
Alan Hood
ami-man
UK
May 30, 2008 | Wurlitzer Jukebox 1015 One More Time...
42 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
phil
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
