Question about HP Pavilion tx2500z Notebook
How do I orientate my screen so that i do not have to flip the computer around after i switch into tablet mode?
    Problem Solver:
  • 15 Answers
Press the button in the lower right corner of the screen marked with two arrows following each other.
Moreover, you can use Tablet Properties to set the orientation you desire as default when you flip to tablet mode.
Posted on Jul 11, 2009
  • mbkafil Jul 11, 2009
    You can press the Orientation Button located in the right bottom corner of screen. It is marked with two arrows following each other in a circle.
    Moreover, you can set as default the screen orientation you desire in Tablet Properties.
I think I have pressed the dual display enable/disable button, and now the computer only mode displays upside down and touch pad wrong way around?? Dell inspiron
You can press and hold CTRL and ALT while pressing the down arrow key to rotate the display, if that doesn't work right click on an empty space on the Desktop and select Screen Resolution from there change the Orientation from Landscape (flipped) to Landscape.
Oct 17, 2013 | Dell Inspiron 5100 Notebook
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
Rotate screen back to normal
Feb 23, 2013 | Gateway Computers & Internet
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Feb 15, 2013 | Samsung N120-12GW Netbook
My screen does not flip 180 degrees when i turn the screen around
Jan 28, 2013 | Panasonic Toughbook 19 Rugged Notebook -...
My son has rotated the screen on my fujitsu lifebook s series so now it is upside down! How do i rotate it back? Please help!
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
Jan 21, 2013 | Intel S6240 Notebook
Acer tablet troubleshooting
b>
Jan 14, 2013 | Computers & Internet
My laptop screen has turned on it's side, how do i put it right
A tablet PC is expected to change orientation of the screen if you put the laptop in Tablet Mode.
If all hardware and software are in working order (correctly configured) you should be able to change screen orientation
  1. By pressing the rotation button. I can't say where it is since you did not specify the Toshiba Model.
  2. Or you press CTRL ALT ( UpArrow, DownArrow, Left Arrow, Right Arrow). CTRL ALT UpArrow will restore the screen to the default orientation in tab let PC Mode.
May 19, 2012 | Toshiba Computers & Internet
Orientating my Screen after I switch into tablet mode.
Also, remove the battery for 10 seconds and reinsert. This will enable auto orienting of screen.
Jan 13, 2009 | HP Pavilion tx2500z Notebook
HP Pavilion tx2500z Notebook Logo
175 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
