My matshita dvd ram ata uj8aoas did not work.. what should i do+
  • 91 Answers
SOURCE: need drivers for matshita dvd
Please get it downloaded at manufacturer website
Posted on Apr 30, 2011
Bubbabear64
  • 2794 Answers
SOURCE: matshita dvd ram uj 8505
Is this connected to a Vista computer?
Posted on Jul 05, 2008
SOURCE: MATSHITA DVD RAM UJ-850S Device Not Even Shown
Found out that the problem with my DVD drive was a registry error. Had that fixed and all is fine with the world again.
Posted on Mar 15, 2009
  • 70 Answers
SOURCE: matshita ATA DVD-RAM driver problem (code 39)
I fixed this problem on a co-workers laptop and it was a Matshita DVD/CD-ROM too. I fixed it for him and THIS SOLUTION DOES WORK!
First of all, you shouldn't have to install drivers for an optical drive. Upon troubleshooting and researching this issue for a couple of days, I found that it was caused by a couple of corrupt entries in the registry. After going into the registry to fix these entries, the drive was recognized and began to work. One thing I can assure you is that you won't have any success finding drivers for this DVD drive.
Whether you're using XP or Vista, you will follow the same exact steps:
Again, this issue is caused by corrupt entries in the registry, therefore, you will have to go into the registry to make changes. Please be VERY careful when working in the registry.
ALWAYS CREATE A FULL BACKUP WHEN MAKING ANY CHANGES TO YOUR SYSTEM. When modifying the registry, you can also create a backup of the registry only and restore it from the backup if any issues occur.
These steps work both in Vista and XP. REMEMBER! Your ONLY mission here is to remove these corrupt registry entries (if they exist). DO NOT touch any other entries in the registry.
1. Click Start then click All Programs
2. Click Accessories then click Run
3. Type regedit into the text box then click OK
4. In the navigation pane,on the left, locate HKEY_LOCAL_MACHINE then click the folder to open it and find the SYSTEM folder.
Click the SYSTEM folder then go to the folder named CurrentControlSet and click it.
Drill down to the folder named Class then click it.
Within the Class folder, you will see several folders named with a series of alphanumeric characters enclosed in {} brackets.
Find the one labeled {4D36E965-E325-11CE-BFC1-08002BE10318} and click it.
5. If I'm correct about your problem, in the right pane of the window, you will see UpperFilters (if not, your issue is caused by something else and you can exit the registry). If you do see UpperFilters listed in the right pane then click it.
You may see an UpperFilters.bak registry entry. You do not have to remove it. Click UpperFilters only. If you do not see UpperFilters but do see LowerFilters, you still may have to remove that entry for this fix to be successful.
6. On the Edit menu, click Delete. You can also right-click UpperFilters then click Delete. Confirm the deletion.
7. Now for the LowerFilters, in the right pane, click LowerFilters (again if you DO NOT see this entry nor did you find the UpperFilters entry in the registry, you will need to move onto troubleshoot further).
8. On the Edit menu, click Delete. You can also right-click LowerFilters and click Delete. Confirm the deletion.
9. Now you're finished. Exit the Registry Editor and restart the computer.
After you restart your computer, the first thing that you should do is open My Computer to see if the drive is now listed. If you did find the Upper and LowerFilter entries in your registry and removed them, your drive should appear now.
I am assuming that your drive is still operable and is installed correctly. When I fixed this same issue on my co-workers laptop, the DVD ROM was recognized and working after the reboot. Also, because these registry issues are one of the most likely causes, it doesn't hurt to go into the registry just to see if those entries are there. If they are present, this is most likely the cause and the only solution that I know of.
Try these steps if you haven't already and post the results...
Posted on Mar 26, 2009
  • 1257 Answers
SOURCE: Matshita DVD-Ram UJ 852S Ata Device
Follow this article to fix the issue:
http://support.microsoft.com/kb/314060
Posted on Apr 23, 2009
Matshita Dvd-ram UJ-861H ATA Device Not Working
Use this link to find possible answers to your problem. It is in the Microsoft Community
HP Pavilion with Vista Matshita Dvd ram UJ 861H ATA Device is disabled...
Feb 20, 2014 | Computers & Internet
Busco matshita dvd-ram uj-840s driver para el windows xp. Alguien me puede ayudar? No lo encuentro en ninguna pagina. En la pagina oficial solamente existe para el windows 2000. Gracias.
Not sure of your question; I read only English.
There are many sources for the drivers for your DVD; many would liek you to downlaod and use their driver update programs. An advantage is if there is ever an additional update the program will let you know. Here are two examples that you might consider as sources for an updated driver:
http://driver-helper.org/matshita-drivers/matshita5/matshita-dvd-ram-uj-840s-ata-device-driver-download/
http://www.driverboost.com/lp/drivers/update/Matshita-System-Drivers.php
Dec 28, 2010 | HP Computers & Internet
Uninstalled matshita dvd-ram uj-8505 ata device
Go to Control Panel, Add Hardware and Windows should do it for you.
If you are PC literate go to Start click on it go to My Computer nad right click on ot go to Hardware and click on it go to Device Manager and click on that scroll down to CD/DVD and click on that select the DVD unit and select update driver
Jan 14, 2010 | Sony VAIO VGN-N365E/B Notebook
My matshita dvd-ram is not working. It has a (!)
Do you have the most current driver for Vista for the drive? Also the most recent Vista Service Pack? Go to the manufacturers website and look under support to see if they have a firmware update and Vista driver. Good luck!
Sep 08, 2009 | Computers & Internet
System not reading my matshita dvd ram uj - 850s ata device
If you are using genuine microsoft OS the download the Microsoft User-mode Driver Framework Feature Pack1.0.0 (Pre-release5348) from microsoft corporation or from CNET driver update tracker....sodeep
Mar 17, 2009 | Acer Aspire 5100 Notebook
Try a Google search for the driver. I got my printer driver that way. Prints just fine.
Feb 14, 2009 | Computers & Internet
Code 28 error for matshita dvd-ram uj-852 ata device
hi,
Please go to the device manager by typing and entering devmgmt.msc in run option.
click the plus sign given before dvd cr rom drive and uninstall the drive coming.
then clisck the plus sign of ide ATA/ATAPI controllers and the uninstall the secondary IDE channels.
Retart the machine twice.
If the also the issue is not resoved then you will have to reload the OS again.
Jan 31, 2009 | Computers & Internet
Matshita DVD-RAM read DVD/CD but can not write.
Reformat computer to original setting. I've done this before and its working.
Nov 02, 2008 | Lenovo 3000 V100 Notebook
Does my Matshita DVD-RAM UJ-850S ATA Device support DAO/96 mode?
yes, yes and yes. DVDRAM drives do pretty much everything.
Oct 27, 2008 | Computers & Internet
Computers & Internet Logo
316 people viewed this question
David Payne
David Payne
