Question about Cuisinart Dcc-2800 Coffee Maker, 14 Cup Glass Carafe
How to disassemble cuisinart dcc-2800 lid
Lid will not latch closed so I wish to remove the lid spring and open and close it manually
5 Suggested Answers
clyde2j2
  • 137 Answers
SOURCE: Cuisinart DCC-240 drip lid came apart, how to reassemble?
You may not be able to put it back on, in case you can't it is no bigee, all this does is prevent coffee from running everywhere if you remove the pot before the maker is finished making coffee.
Wait for it to be done and you will just have just a drip or two.
Posted on Feb 08, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: broken hinge on reservoir cover for Cuisninart model DCC-2200
The hinge itself is not orderable, but a lid with the element that fits into the hinge was available from Cuisinart the last time I checked. Call 1-800-726-0190 to be sure. It is not easy to put the replacement lid into the right place without breaking the part, but it is possible - you have to put one bar into the hinge, and then pull the other bar just enough to fit it into place without breaking it. If you are out of warranty, the lid will cost somewhere betwen $15 and $20 with shipping.
Posted on Feb 26, 2009
  • 51 Answers
SOURCE: Lid will not close. Jams half way down
is there any build up any where aound the hinge? Rub a bit of butter on hinge then move lid up & down. this is kind of like oiling something but your using butter or margerine. I do this on the hinges of my doors when they start to squeek.
Posted on Jun 10, 2009
SOURCE: Cuisinart DCC-2200 14-cup Coffee Maker Problem:
Cuisinart DCC-2200 replacement carafe is Cuisinart DCC-2200RC 14 cup replacement glass carafe.
Posted on Aug 14, 2012
Tip
HOW TO TURN OFF THE TRUNK OPEN ALARM
The 2012 Camry's trunk lid has a 'trunk open' alarm that shows up on the instrument panel as 'door open' red icon. It also turns on the door open beeping sound so long as the trunk lid is open. This is normal and is usually not a problem..
However, if you should need to carry a large item in the trunk and can't close the lid, be prepared to listen to the incessant door open sound with no means to turn it off!!
The trunk lid alarm 'switch' is operated by the trunk latch when you open or close the lid. By manually operating the latch to it's closed position, you can temporarily silence the alarm.
Using a small screwdriver, you can easily press the actuator and turn the alarm off.
Picture 1: trunk lid latch in the OPEN (Alarm ON) position.
**WARNING**
YOU MUST RETURN THE ACTUATOR TO THE OPEN POSITION (ABOVE)
(ALARM ON) BEFORE YOU CLOSE THE LID. FAILURE TO DO SO MAY DAMAGE THE LATCHING MECHANISM
**WARNING**
DO THIS WITH THE TRUNK OPEN LEVER OR WITH THE REMOTE TRUNK OPEN BUTTON.
Picture 2: trunk lid latch in the CLOSED (Alarm OFF) position.
IF YOU TRY TO CLOSE THE LID WITH THE LATCH IN THIS POSITION YOU MAY DAMAGE OR BREAK THE LATCHING MECHANISM
on Sep 17, 2015 | Toyota Camry Cars & Trucks
Tip
How to fix the leak problem with Cuisnart coffee maker
Hi, my husband just this morning spotted the cause of the leaking problem with our DCC-2750 coffee maker. The coffee filter basket holder has a little handle loop that lines up with the 5:00 position. You have to PUSH DOWN AND LOCK IT INTO PLACE which opens the drainage hole at the bottom, allowing the liquid to go into the pot. Closing the lid is probably supposed to do this but sometimes doesn't (the manual says "press firmly on cover to be sure it closes securely").
Hope this helps someone else....
on Jul 23, 2011 | Cuisinart DCC-2000
Cuisinart dcc2800 Perfec Temp 14-Cup Programmable Coffeemaker
cuisinart DCC-2800 leaks water from under side, after 5 months the lid spring lock broke'.. then only after about a year and a half, and just out of warranty!!!!!!!, it must have sat on the store shelf over a year before we purchased it new. bad design for such a costly coffee maker and Cuisinart was not much help either when we called, I called several months earlier to get the problem fixed but was told to call back because there system was down for maintenance, so now when I had the chance to call back they tell me they did not want to fix it and only offered me a discount on a new one, why would I want to buy another when I spent sooo much on this one only to have water leaking all over my counter, table, chairs and floor'? never again, next one will be all stainless so it wont leak. so do not have to worry about asking for help again on such a expensive coffee maker.
May 03, 2013 | Cuisinart Dcc-2800 Coffee Maker, 14 Cup...
The cuisinart repeated;y clogs and sprays water
The two most common reasons for overflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Sep 07, 2009 | Cuisinart DCC-1200 Coffee Maker
My coffee maker, Cuisinart dcc 1400 only boils water, does not make coffee. It is one week old. I have a water filter in the plastic filter holder filled with coffee.
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Aug 10, 2009 | Cuisinart Coffee Makers & Espresso...
Feb 08, 2009 | Cuisinart DCC-240 Coffee Maker
I got a Cuisinart coffee maker DCC 1400C for a wedding present, worked fine, then all of a sudden STOPPED. I did the self clean, and that worked fine, the brew setting doesn't. The water doesn't go...
Unplug for 20 minutes or longer to reset. Make sure the lid is on the caraffe, or the brew basket will be stuck in the closed position. If the water still won't go through, consider ordering a new brew basket, because yours might have a faulty spring.
-Tha Mp3 Doctor
Dec 30, 2008 | Cuisinart DCC-1200 Coffee Maker
DGB-600BC
I have had the Cuisinart DGB-600BC for a bit over a year. The coffee grinds, and then sometime during the brewing cycle, it will go, "beep beep, beep beep, beep beep..." on and on.
I think I have traced the problem to the latch on the top lid that you open to access the bean hopper. I believe the latch sticks and doesn't close the lid tightly enough. It will appear to be closed, but the latch isn't all the way in place.
So, there is a small screw on the inside of the latch in the lid. Carefully unscrew this, remove the screw, latch, and the small spring. Remember which way the latch faces.
With a warm damp paper towel, clean the latch and the slot in the lid that the latch goes into. Reassemble, and make sure the screw is not so tight that the latch doesn't move freely.
This should solve your problem.
Jan 21, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Cuisinart Dcc-2800 Coffee Maker, 14 Cup Glass Carafe Logo
196 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
