Question about Castle Toys
Bepuzzled castle 3d how to put together - Castle Toys
3 Suggested Answers
SOURCE: Instructions for 3D alpine castle
I have a copy of the instructions
Posted on Oct 20, 2010
  • 6 Answers
SOURCE: Mega Bloks Disney Princess Castle Playhouse
www.laxmibloks.com
Posted on May 03, 2010
Where can I get instructions to put together my new Original 3d Crystal Puzzle, Tinker Bell?
I'm not sure how good this will work and you might have already gotten the answer but this site might help a bit: http://www.ugames.com/rules/bepuzzled/CrystalPuzzles/30983_Tinker%20Bell_instructions.pdf
Jan 24, 2016 | Puzzle Toys
Need instruction to put a canvas Disney Castle together. Has plastic poles and material.
Go to Amazon & look up the tent & the picture should help you. I put one together for my granddaughter.
Oct 14, 2014 | Disney Princess Playhut Tent Mega Castle...
Need instructions for milton bradley 3d alphine castle
Go to this site and request Customer Service:
http://www.hasbro.com/?US
Jan 23, 2013 | Milton Bradley 3D Puzzle American Bald...
Jan 09, 2010 | Milton Bradley Toys
I need to replace a Front wheel bearing on my 98 ford ranger.
Remove the wheel and take off your brake caliper. Once you have the wheel off, you will see a dust cap in the center of the wheel. Remove the dust cap by using a pair of channel locks, don't use something to pry it loose as this will cause it to leak grease later. Once you have the dust cap off you will see inside a castle nut held in place with a cotter pin. Remove the pin and unscrew the nut. This will allow the rotor and bearing to come out. Replace the bearing with the new one using a high temp grease to grease them.... IMPORTANT: when you grease the new bearings make sure to grease them thoroughly. Put a glob of grease in the palm of your hand and slowly dab the sides of the new bearings in the grease (this will allow the bearings to be greased on the inside).... Put back together as you found it. NOTE: When tightening the castle nut, tighten it down tight and then release it a quarter turn back before before inserting the pin to hold it back in place. Good luck! Let me know how it goes.  PS If when you have the rotor off, you have trouble getting the inside bearing off try this very simple and useful trick: Put the rotor back on the spindle and thread the castle nut on a couple of times. Next **** the rotor across the nut. This will cause the bearing to hang up on the castle nut and simply pop out.
May 07, 2009 | Ford Ranger Cars & Trucks
Front wheel bearings
Once you have the tire off, take your dust cap off the center of the assemble. (Don't pry it loose as this will cause leaks, use a pair of channel locks to loosen and remove it.) Once the dust cap is off you will be able to see that there is a castle nut inside and a push pin that holds it in place. Remove the pin and then the castle nut. This will allow your bearings to slide out. When you put the new bearings in be sure to properly grease them before you put them in. Put a glob of grease in the palm of your hand and slowly dab the entire sides of the bearing in the grease allowing all of it to be greased. Put it all back together the same way you found it. When tightening the castle nut back on tighten down good and snug and then release back a 1/4 turn before inserting the pin back in place and putting dust cap back on. Hope this helps, let me know how it goes and if you need some more help. Good luck!
Apr 30, 2009 | 2000 Dodge Grand Caravan
Toys Logo
85 people viewed this question
Top Castle Toys Experts
Tom Chichester
Brett Duxbury
Brett Duxbury
D. E. Hev
Are you a Castle Toy Expert? Answer questions, earn points and help others
