Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
My furnace wont start from the thermomstat.i have to push in start button on the panel to kick on.. i have my temp set at 70.. i changed the batteries on thermostat.. but every other day i have to go down in basement to turn the swicth on..from furnace
    Scholar:
  • 71 Answers
I assume this is gas furnace; have you put fresh batteries in the t-stat?
Posted on Jan 13, 2009
  • Glenn Snow Jan 13, 2009
    PS. I also assume that you do not have an a/c unit connected with this system else you would get low voltage from the ac unit transformer which would actuate both the heat side and ac side of the thermostate's contacts and not need to have batteries in the tstat.
    Another area to test is the gas control module. It sounds like the pilot's thermocouple is ok, else the pilot would go out, however, if the stat is getting the signal to the controller that gas is in demand but it will not accuate the valve to give gas to the burner, then the electro magnet actuator in the gas controller may be at fault. Particlarly since it will work with a manual stimulus.
    Therefore, long short, test the tstat then the gas controller circuitry. It would be much cheaper to do a quick test on the tstat by getting a jumper wire and touch it to the two terminals where the tstat would normally complet the circuit when heat is neaded. If you cannot tell where to bridge the circuit, forget it else you can damage the tstat or a transformer.
    Genius:
  • 1,199 Answers
I would say that the thermostat needs replaced! (this is the most common problem with the honeywell brand!
Please rate my response to your question!
THANK YOU!
My furnace runs to operating temp on thermostat shuts down then within 30 seconds try's to cycle back on three to four times. What would cause this.
Some thermostats have a swing setting that can be adjusted. A swing is the setting when you want the furnace to stop or start from the desired set point. For example, you set your thermostat at 70 and the swing is set at 10 degrees. Then the furnace will turn on 5 degrees below 70 and shut off 5 degrees above 70. Check you thermostats manual if it has this option.
Mar 15, 2016 | Heating & Cooling
Gas furnace doesnt turn on right away after going below temperature setting. set at 70 and houes temp went down to 67 for an hour until furnace kicked back on. just replaced old thermostat because it was...
If it is a digital thermostat you must follow the set up instructions once you install the wires. Some are multi device,, which means they can be used for oil burners, electric furnaces , and gas furnaces. They have cycle programs that are different. The book will tell you which set up code to use for the type of furnace you have. If it was doing it before, it could be the primary control on the furnace itself (usually a honeywell ),,a sticking relay etc.. you need to have a technician take a look at it.
Jan 23, 2015 | Heating & Cooling
Fasdfas
Does the furnace stays off?.
Furnace are ment to cycle on and off because of limits .If you set to 70 furnace would cycle several times before reaching that temperature.
Just make sure your filters are clean and you got proper return air flow because lack of air flow will cause furnace to shut off sooner than normal
Jun 08, 2017 | Heating & Cooling
I turned my thermostat down this morning to 68 degrees. I came back about 2 hours later to increase the temp to 70 degrees but when I push the ^ arrow instead of showing the increase to 70 it just flashes...
Since it's within 2 degrees of your setting it could be one of two things. Most furnaces run longer (pass your setting) to maintain the setting you made. Which really not a problem. However, your thermostat may need calibrating. To test this theory, place a regular wall thermometer next to your furnace's thermostat and see if the two temps match when the furnace cuts on and then when it cuts off.
If the temps are both the same, the furnace thermostat is fine.
If you're turning it down to 68, because no one will be at home during the day, just set it 2 degrees cooler than 68 degrees. You will then wind up with 68 degrees.
Feb 09, 2011 | Heating & Cooling
Have gas furnace and this winter,began having
The Thermostat Wizard is an interactive tool that will guide you through wiring and troubleshooting your thermostat, as well as programming it to the most comfortable settings for you and your family. Simply answer the questions from the Thermostat Wizard to correctly connect, troubleshoot and/or program your Honeywell Thermostat. You can even print the instructions and bring them right to the thermostat to help make things easier.
Go to: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Support/Thermostat+Wizard/
However - the problem is probably not with your thermostat but with your furnace. It is most likely a dirty flame sensor - a maintenance issue. If you have not had your furnace serviced recently (more than 1 year) that is where you should start. Modern furnaces require regular maintenance.
Please rate my answer!
Feb 28, 2009 | Honeywell Electronic Programmable...
Thermostat seems to be working, furnace does not always turn on
Joss sounds like the anticipator setting on thermostat i would replace it with a digital it will be more actturat . The furnace has to go over temp setting to turn off
Jan 15, 2009 | Honeywell Electronic Programmable...
Furnace wont start when thermostat sends signal
by restart button you mean reset i believe,its located on top of oil burner and says only push one time .if thats the button your pushing it is the reset button or retry for oil burner if you are pushing this there is a problem with burner
Jan 04, 2009 | Honeywell Electronic Programmable...
Honeywell Chronotherm III
Try this link:
http://yourhome.honeywell.com/yourhome/Applications/TechLit/TechLitSearchResults.aspx
It looks like there are a variety of model numbers for the Chronotherm III. Hopefully you can locate your model number.
Dec 17, 2007 | Honeywell Power Humidifier: Furnace...
Heating & Cooling Logo
192 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
