Question about Dmm Garden
John deere 1120 diesel fuel pump/ distributor leaks from the throttle shaft, can I just take off the cover and replace the replace the o rings and gasket?
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
mattofilms
  • 110 Answers
SOURCE: 2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
Posted on Jul 02, 2009
wireguy212
  • 1627 Answers
SOURCE: I have a John Deere 2020 diesel. I can't get the fuel pump off
You need to remove the nut under the cover in front of the pump and then borrow a tool from a j.d dealership to pull the coupler off the pump,you may need the dealer to do this because they have a no lend pollicy for their special tools.Hope this helps.
Posted on Nov 10, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere 445 lawn tractor is leaking coolant
This model has a weap hole just under water pump.If it leaks enough it will stain front cover just to the side of crankshaft.Do not buy the rebuild kit,just replace pump.
Posted on Nov 14, 2009
nova2nv
  • 197 Answers
SOURCE: john deere tractor x585 not getting 12 volts at fuel pump
To check pump u remove fender deck,unhook connector, put 12 volt power to it.I have seen pumps react to a swift kick to the fuel tank,NO JOKE.You first have to check fuses,2 on control board and early x585 machines had a single red wire near control board that was only for fuel pump.Remove right side air screen and check for voltage on the relay closest to the radiator.Red wires #231/232 feed your fuel pump relay.Current flows from that relay #655 pink wire and goes to your fuel pump .Also check#215 grey wire {fuseable link}coming from starter post,they WILL burn out,it goes to #221 red wire with inline fuse and feeds rear of the 2 relays,that is your EFI relay.You have 3 fuseable links coming off starter post,check all of them.
Posted on Jan 01, 2010
My john deere 1070 loads up under a load and will stall. I changed fuel filter which was loaded with "gunk" and it ran ok for a while then is doing it again.
I am not sure what you are calling gunk but if this gunk is black it is engine oil. The tractor and the engine was built by Yanmar. The injection pump is lubricated with oil pressure from the engine. The seals in the pump will leak and engine oil will get in the fuel system and contaminate the diesel fuel and plug the fuel. Seals will have to be replaced in the injection pump to correct the gunk.
Nov 08, 2016 | John Deere Garden
I have a 953 track loader the throttle shaft on the injector pump is leaking oil do i have to replace the injector pump
Bad O-ring on shaft. You may be able to do it yourself, but definitely not a complete pump unless you have a cracked pump or serious injection performance problems thus bad engine performance. Double check pump shaft. area. may need to remove a cover to the drive. Usually, there is a diesel return line I suppose there is a slim chance that is pinched or plugged somehow. Check to make sure it's clear. Possible that supply line to Injunction pump is leaking at the connection, also usually a bad O-ring. Find a leak by
wraping a paper towel in places to discover the leak. Or there is
a black light kit with dye to discover leaks.
Dec 22, 2014 | Cars & Trucks
John deere oil leak and smokes
yes it most deffinatly probably is a broken piston ring dont ride until fix will damage cylinder
Aug 26, 2014 | Garden
Diesel fuel in engine oil
what model and make sounds like a bad diesel pump leaking into crankcase or putting too much fuel to injectors.
May 13, 2012 | John Deere 3020 Gas & Diesel Tractor...
Can I Replace The Throttle Shaft O Ring Without Removing The Injector Pump On Pergeot 405 Diesel To Stop Fuel Leak
I have done this before a few times, you can remove the top of the pump in situ. It is very awkward to put the top of the pump back on though. but can be done:)
Oct 25, 2011 | 1991 Peugeot 405
Just changed the fuel filter on a John deere 1020, is there a way to prime the injector pump?
If the fuel filter is full when replaced it shouldn't be necessary. But if you have access to compressed air, put air to the fuel tank and that will do it. Hope that helps ya.
Dec 21, 2010 | John Deere Fuel Pump Fits 1020 Thru 4230
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
I have diesel in my oil on my 2030 john deere tractor
it can be one of three problems fuel pump leaking injectoin pump or a injector over fueling
Apr 03, 2010 | John Deere Tractor Side Screen...
My john deere 990 wont start. it's not getting diesel to the engine
Check there is adequate fuel to supply engine. Check there is no damage to fuel lines and that the fuel filter is not plugged. Yours is a Yanmar diesel engine withe an autobleed feature which is supposed to bleed the air out of the system automatically. It may incorporate an electric fuel pump also, but some don't. You can prime the fuel system to the injection pump with the manual lift pump if it is equipped with it. After establishing fuel to the injection pump, loosen the nuts that hold the fuel lines onto the injectors approximately1 1/2 turns. Turn the engine over until you see fuel coming from the injector nuts. Tighten the nuts to 24 inch/lbs of torque, start the engine and run at 1/3 throttle untill it runs smooth.
Jan 04, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Nov 10, 2009 | John Deere Tractor Side Screen...
Garden Logo
83 people viewed this question
Top Dmm Garden Experts
Wayne McNeil
Joseph Mueller
Joseph Mueller
ray gallant
Are you a Dmm Garden Expert? Answer questions, earn points and help others
