Question about Whirlpool Washing Machine Door Frame - 8182151
Washing machine door frame for neutral wm601
I need to purchase a washing machine door frame for model neutral wm601
  • 1294 Answers
SOURCE: door will not unlock
If the water has not completely emptied, this won't allow the door to open. Check by lowering the outlet hose into a bowl. If a fair amount of water comes the problem is likely to be a pump or filter blockage
Posted on Dec 19, 2007
Richie_asg1
  • 1036 Answers
SOURCE: WHIRLPOOL WASHING MACHINE
From Whirlpool direct, you can download the users manual - Here
Just enter the model number and you should get it.
Alternatively, phone the number on their site for a copy to be posted to you.
Posted on Jun 20, 2008
SOURCE: Washing Machine Door won't open
I had the same problem. I went through all the steps on this thread to no avail. Finaly I just pryed the thing open - with no damage, thank goodness.
Once open I saw that the latch in the door didn't move when I pulled the handle. The problem it seems was in the latch on the door itself. If you end up this problem and want to get wet clothes out, just stick a flat-head screwdriver, behind the door latch into the horseshoe-shaped metal bit and lever it open - no prying necessary.
Not sure how I'm going to fix this permantely but at least I got my wet clothes out and can do laundry as long as I keep the screwdriver near by.
To fix - I'll either need to figure out how to disassemble the door and replace the latch mechanism, or just buy a whole new door.
Posted on Sep 21, 2008
  • 1314 Answers
SOURCE: Reverse the door on the washing machine Model GHW915PW0
no because of the door lock switch
Posted on Jan 29, 2009
blueextc3221
  • 15935 Answers
SOURCE: whirlpool washing machine model wfw9500tw01
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
Washer fills with water but then will not cycle through after filling tub
I looked up yur model. It is a fine washer. Your lid switch on this model don't allow for wsh or spin if the the lid is ope. Older models would let the washer wash but not spin. This switch here won't allow for wash or spin. How it works
My page on these
Note: this washer is a newer model and I have yet to come across one. I believe your problem to be the lid switch. It has 3 wires. 2 hot ones and another one attached to the frame. Jump them 2 live wires and see if she runs. If it works get a new switch and party on!
I am TheMobilian.
Let me know what ya find out, I am here to help.
Jul 21, 2011 | Whirlpool LSR5132PQ Top Load Washer
Model 27422300 Kenmore Washer doen't spin or Agitate
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 26, 2011 | Kenmore 22642 Top Load Washer
Machine not spinning,
Jan 06, 2011 | Whirlpool Washing Machines
Cabrio washer washes then does not spin out
Jan 01, 2011 | Washing Machines
The washer (model #11082380100) does not drain after the wash cycle is finished.
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.Replace with this part.
Dec 28, 2010 | Kenmore Washing Machines
How to drain washer, at what setting? After a wash cycle, the water did not drain.
The lid switch may be defective. If so, the washing machine can't spin or drain and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. If you will post your model number, I will be able to point you to the part you need.richroth_80.gif Happy Holidays The FixYa Team
Dec 22, 2010 | Kenmore 24032\24036 Top Load Washer
My Whirlpool top loading washer model LXR7133JQ1 will not drain and will not spin. Hoses have been checked for blockages and nothing is there. Any suggestions???
The lid switch may be defective. If it is, the washing machine doesn't drain or spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Here is the part you need. Here is a video to walk you thru the process of replacing the switch.
Nov 30, 2010 | Whirlpool Washing Machines
Need to locate parts for purchase for old Admiral washing machine.
http://www.repairclinic.com/SSPartDetail.aspx?s=b101a11c226i1477&PartID=1477 you will find your hinge here
Apr 14, 2009 | Washing Machines
My washing machine model 110.24642300 was washing last night and just stopped after filling half way. what do I need to do
Lid switch
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Good luck...
Mar 28, 2009 | Kenmore Washing Machines
Whirlpool Washing Machine Door Frame - 8182151 Logo
46 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
