Question about Motorola Mobility H350 Wireless Headset
Jabra VBT2050 headset won't pair with blackjack II
Got headset from but phone won't recognize it
  • 1 more comment
  • BharadwajK Mar 25, 2009
    I have the same problem of bluetooth headset not being detected in my MotoRokr Z6 mobile.
    I shall try the solution and post the feedback very soon
    The solution posted below works for me perfectly...Thanks to Zohail.
  • Anonymous Apr 01, 2009
    Excellent! Worked like a charm
  • 1,223 Answers
pls follow this
ok here u go first turn on the bluetooth func in ur mobile, now while ur bluetooth headset is off press the power centre big button for like 10 sec until the blue light stays on continously not blinking position ok then search for bluetooth devices in the phone bluetooth config ur headset will come up like JABRA VBT2050 select it then it will ask u for pairing code input 0000 and press ok ur device is now connected u will see the blue light which was continous b4 now blinking it means ur haedset is connected , u have to complete this process in almost 1 min bcoz there is a timeout for this process , now try any call u will hear it in ur headset
pls rate me fixya for this if it helped
Posted on Mar 06, 2009
Trying to pair my Jabra VBT2050 to my motorola. The passkey 00000 isn't working
you can only use one digit number not four detect the bluetoot headset
Sep 30, 2010 | Jabra BT350 Bluetooth Headset Headset
HK-760 Bluetooth dongle, pairs with my HP computer but after inserting the passkey, the computer starts searching for the peripheral device drivers without which a connection between my jabra VBT2050...
This device, according to the Jabra website, is intended only for phones, not PC's. The PC is searching for a driver in order to know how to communicate with the device. Since the VBT2050 does not have the necessary software contained within itself, the PC starts searching for device drivers. There are none that I could find on the Jabra website, so I don't think it is intended to be used with a PC.
Feb 20, 2010 | Bluetooth USB Adapater, USB...
Unable to pair VBT2050 to my girlfriend's Blackberry 8330 - Help!
Try deleting the headset from your phone and then re-pair from scratch.
Aug 19, 2009 | Jabra BT350 Bluetooth Headset Headset
Can i pair jabra bt125 with samsung blackjack ??
Mine is a Blackjack II, but i did get it to connect. Hold the clear button down on the Jabra until it lights solid blue, keep holding it with one hand while you use the other hand to operate your Blackjack. I went to Settings, then Connections, then Bluetooth, then "Add new device". As long as my Jabra was lit solid blue, the phone found the headset. Then it will ask you for the pin code, which i found by accident (0000 - four zero's).
Jul 11, 2009 | Jabra BT125 Headset
Problem pairing my Jabra vbt 2050 with my blackberry storm
Hold the volume up (+) button down along with the call button for 5-10 seconds (until the led lis solid). Then, while the led is lit up, initiate the pairing on your phone. It should pair this time. It worked for my phone, which was having the same problem you described.
Mar 04, 2009 | Jabra Bluetooth Headset with Adjustable...
Jabra VBT2050
The above solution only lacks one small item. Part of the pairing procedure is to hold the on/off button for the recommended 5 seconds to power up, but the light will NOT become constant until you hold both the power button AND the round center button on together until the light remains constant. Then you can pair the two devices.
Jan 27, 2009 | Jabra BT250 Consumer Headset
Jabra VBT2050 Not detecting
On The Blue Tooth You Have To Hold The On Off Till The Light Flash's Blue Red Over And Over Then Search For It On Your Phone.
Once You Find It It Will Be Recognized For Now On. Just Hit The Button On The Blue Tooth One More Time To Stop The Sync Mode.
Jan 19, 2009 | Jabra BT350 Bluetooth Headset Headset
Setting up Jabra VBT2050 Bluetooth
I took my husband's suggestion and used 0000 and it worked. My husband claims it is the factory default for all bluetooth headsets. Try it and let us know if it works.
Dec 26, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra vbt2050 won't connect
Jabra VBT2050 - You have to hold the round button in until the light stays lit (about 20 seconds) this will put it in discoverable mode, the pin is 0000, I have AT@T service and it works just fine. Hope this helps out!
Dec 21, 2008 | Radio Communications
Can't work out how to pair it with Blackberry Pearl
You can download the manual from the link below: There is a good online pairing guide that will take you through the necessary steps: Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 22, 2007 | Jabra BT250 Consumer Headset
Motorola Mobility H350 Wireless Headset Logo
161 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
