I have LG Washing Machine Front Loader - WD1433RD. The display says LE and when I looked up the manual it is overoaded. However there is not much load in it. Any idea ?
  • 15,935 Answers
The load balance sensor is likely failed - or the vibration dampers are broken. Check their mounts as well.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Hi, hope you can help, I have a 4 kg LG Washer / Dyer (model WD - 1433RD). It is displaying "CL" on the readout. Have lost the manual so wondering if this is a simple fix or not?
CL means that the child lock feature is active and the control panel buttons will not respond. For the LG WD1433RD, press and hold the Rinse+ and Pre-Wash buttons together for about 3 seconds to toggle the lock off. For the LG WD14311RD, press and hold Option and Rinse for about 3 seconds. On both washers, there is a small icon between the two buttons needed to toggle the child lock feature on and off. (It's a small face above a padlock.)
The manual as a Djvu file for the LG WD14311RD is available here: http://www.lg.com/uk/support/product/support-product-profile.jsp?customerModelCode=WD-14311RD&initialTab=warranty&targetPage=support-product-profile .
The manual for the WD1433RD is available as a PDF here: http://www.manualsonline.com/ex/thread/view/idThread/80183 .
I hope this helps.
Apr 06, 2011 | LG WD14311RD Front Load Washer / Dryer
LG WD1433RD Washing comes out with black lines and sometimes even worse Have cleaned rubber seal repeatedly Same problem for years every few washes
My LG Front Loader Washing Machine WD-1433RD having a leakage from Front when it fills the water up to ~70% of water. There is no leakage prior to that level. Please help me to fix this.
Feb 19, 2011 | LG WD14311RD Front Load Washer / Dryer
Front loader won't spin, just after 2 mins up into the cycle it comes up with message le. Can you help please?
Hi just read your posting.Now I need to know the make and model of your machine.It sounds like you have an LG front loader.LE on the LG front loaders means your HALL SENSOR which is attached to your motor is faulty.Please reply with model number and I am sure I can help you.Looking forward to your reply.
Sep 11, 2010 | Washing Machines
Waher showing LE and not wahing
if your machine is an LG , then le code means your motor senor or motor is faulty.if u r confident change sensor first.is it a top loader or front loader?the sensor is attached to motor. if u would like more help please reply. if u r getting service company 2 do job, ring around 4 prices on changing sensor or motor. this should save u money
Apr 06, 2010 | LG Washing Machines
I have a LG washer dryer wd1433rd that keeps coming up with LE error....ive tried unplugging it...resetting it....is there anything else i can try?
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble.
CHECK THE BELOW LINK:
http://www.fixya.com/support/r2127066-le_error_code_lg_washer
Mar 31, 2010 | LG WM-2277HW Front Load Washer
WM0532HW LG front loader washing machine displays LE
LE codes are extensively covered in past Fix-Ya solutions, but are generally caused by only a handful of things. 1. the " Load Error " can be a very off balanced load. 2. excessive use of soap leads to too much suds, and thus drag on the inner tub. (use 1 tablespoon of HE soap max. per load) or 3. the Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000.
Feb 23, 2009 | LG WM-2277HW Front Load Washer
My LG WD-1023C Automatic Front Loader Washing Machine is displaying a CL error code and will not turn on.
it could be that your machine has been child locked, look in yor manual it will tell you how to fix it, this happened to me , hope this heps you good luck
Sep 11, 2008 | Washing Machines
Washing Machines Logo
114 people viewed this question
Top Washing Machines Experts
