Toshiba 27AF41 27" TV
Problem for Toshiba 27AF41 27" TV
A bright line on the screen
By hbhalerao on Jun 10, 2007
After using the TV for about 6 years, one fine day all we could see on the TV was a bright horizontal line across the screen. A couple of times the image did return to normal for less than an hour and then went back to a bright line. We can't watch TV or video's.
My father-in-law had an exact similar problem on another brand tv in India and mentioned technician found a lose contact on the PCB, had to re-solder a connection and it works fine now.
Anyone knows how and where to fix this?
Comments:
Jun 11, 2007
- I think this is exactly what they did to fix the TV set I mentioned earlier. I barely have any technician skills to do the re-soldering myself.
Do you think this will done by a TV repair shop at relatively low cost?
Same Problem
Apr 03, 2008
-   Although mine is a 32" I am having the same problem and my set is not quite 2 years old and when I contacted a service dept. they wanted $200.00 flat fee for labor and additional charge for parts, if we want them to come to our house and fix it, it will cost and additional $75.00 to $100.00 to come. My husband is great at soldering and mechanical things, I'll show him this website and have him take a look, it's worth a try.
Thanks!
-   babs2
Best Solution
posted on Jun 10, 2007
Helpful)
premtech
Rank: Guru  Toshiba Expert
Rating: 89%, 1225 votes
A line running across the screen like that and then returning to a picture I would guess is the vertical IC has some poor solder joints. The vertical IC in that unit IC401 is an LA78041 a seven pin IC that is mounted to a metal heat sink. On the foil or under side of the board take a careful look at the pins of that IC and any that look suspicious carefully re-flow some solder over.. Careful not to keep your iron on the pin too long.. And if have to re-solder several take some time between them to allow the IC to cool so you don't damage it..
Good Luck
Bill
Was this helpful?
Yes
No
Popular Solutions for Toshiba 27AF41 27" TV
Questions and Unsolved Problems for Toshiba 27AF41 27" TV
Do you recommend Toshiba 27AF41 27" TV?
Answer
Answer
Tv was givin to me with no power button and a remote, I told giver that I I have comcast remote.... (More)
Answer
My television keeps having a flashing red light when I try to tun it on. Is there anyway to turn it... (More)
Answer
The tv won't turn on when I press the poswer button. The red light blinks, but won't turn off when I... (More)
Answer
The tv won't turn on when I press the power button. The red light blinks, but won't turn off when I... (More)
Answer
cant gat my older rca direct tv remote to operate my toshiba model 27af41 tv
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
