Question about Music
Hi, I have purchased a Kimball superstar II organ. It powers up fine, but across the whole keyboard in both registers and the foot pedals, only G and F keys make a sound. The other keys, when pressed, produce only a clicking sound. The sounds produced are clean and powerful, but 10 notes is no fun! Is there an easy way to fix this? Thanks a lot!
2 Suggested Answers
  • 5603 Answers
SOURCE: looking for a schematic of the Casio ctk-700 to
The keyboard is LIKELY scanned as a matrix.
You have two problems:
The contacts in the Thomas will have to be totally disconnected rendering use of any of the Thomas organ unlikely.
The second problem is that the keyboard LIKELY has velocity sensing. This means TWO contacts must be used PER note. One contact "makes" first and "breaks" last. This is used for velocity sensing on synths. The Thomas foot pedals likely only have a single contact per pedal, and even if they had two, it is unlikely they sequentially close..
The matrix scanning is accomplished by sensing the connection of two crossing points on a matrix of circuit lines. USUALLY each of 12 wires tie to all of one note across the board. Then two other lines for each octave "strobe" the first make contact and then the second of those strobes the second make contact. There are two of these strobe lines for EACH octave on the board.
Remember that these lines scan at digital logic speeds so wire length and NOISE/STAIC DISCHGARGE PROTECTION is a must.
Posted on Aug 28, 2009
When was the Kimball 1021 made and what is the full description of the organ? Thank you!
archive.org/stream/OrganBlueBook-1985-1986.organforum.com/forums/showthread.php?2907-Kimball-Organ/OrganBlueBook1986-Pt.2#page/n65/mode/2up,.organservice.com/kimball/kimball.htm
Nov 09, 2017 | The Music
On my kimball 700 organ, the pedals make no sound.
This can either be an unplugged or dirty connector, or a blown circuit. If possible , get to the connectors on the pedalboard and clean them. If that doesn't fix it, call in a repairman.
Jan 30, 2017 | The Music
How can I turn off the sound to the foot pedals of my Lowery organ. Is there any setting on the organ to do that?
If you turn off any voice tabs for the pedals, they are effectivly turned off.
Mar 22, 2015 | Music
I've recently purchased a Roland foot pedal for my casio privia px-300 keyboard. When playing a note, even though the pedal is not pressed, the note sustains. When I press the foot pedal down, it cuts...
Sorry, but Roland uses the opposite sense switch. They use normally closed where Casio requires normally open contacts. SOMETIMES one can rewire the pedal internally, but you have to be mechanically and electrically inclined to do that.
Jun 04, 2011 | Casio Privia Keyboard Case
I recently got a Kimball Swinger 1000 for free from craigslist and after i plugged the thing in, it only makes feedback noises when the keys are struck. Same when headphones are plugged in. The lights,...
First thing is to check the power supplies. You really need to get a manual that inclides the schematics. I suspect that one of the voltages is not present. Also look for cables that may have partially fallen off.
Feb 14, 2011 | Music
I purchased a used Hammond Organ Aurora, Model 700, 710 C125 but the previous owner did not have the manual for it. I am looking for a manual so I know how and what to do to play it. I don't know what...
Try the organforum . com. There are a lot of Hammond people there. The model 700 is the base model and probably enough to get you started.
Also just get a organ music book as a lot of the vernacular is in those. Also check your library for organ books. OFTEN the user manuals aren't much use to learn the instrument.
Most organs will either have tabs or drawbars. These select the type of "voice" and often one selects more than one as a mix. Each keyboard is refered to as a "Manual". Most organs have foot pedals. Each of the manuals and the foot pedals will have a seperate set of tabs associated with them.
To get started, turn on the organ and press the expression pedal which controls the volume... experiment setting a few tabs or drawbars an play notes on the manuals. You will soon learn what controls what.
Note that some models of Hammond organs used rotating tone wheels and those require lubrication. Those that do, usually have a power switch labelled "start" and "Run". These organs are usually higher value and one should have them serviced before using.
Nov 23, 2010 | Music
Thomas jester 132 organ troubleshooting E-flat below mid c not working correctly on either keyboard or foot pedal all other keys ok volume pedal is scratchy but works ok
Here is where you can get the service manual:http://celedoniaorgan.netfirms.com/cosco/nfoscomm/catalog/product_info.php?products_id=1021&osCsid=3eaaa99d6bfceeaaf9b844687ba58d55 Since the problem is with the foot pedal note and the keyboard note I would suspect that there is a problem with the tone generation circuit for that note. You might try cleaning the key contacts on both for that note first to see if that works. The volume pedal probably just needs the volume pot cleaned with contact cleaner spray. I hope this helps. Let me know if it does.
Nov 26, 2009 | Music
Looking for a schematic of the Casio ctk-700 to
Aug 22, 2009 | Casio Music
I have a yamaha electone hs4, The foot pedals do not work.
JM: Your problem is this: There are rubber washerson the bolt that holds the pedal on. They are shot. Most likely Yamaha doesnot have the parts.Go to the plumbing dept of a hardware store and get some faucet washers and replace them. YYou can tell if the washers are shot by tiping over the organ and looking at the pivot bolt. Most likely that is yoiur problem. I am an organ tech. and have replaced many of these. DM
Mar 13, 2009 | Yamaha Full-Size Keyboard
Music Logo
174 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
