Question about Sewing Machines
How do you thread a juki lu563
The thread tangles and there is no stitches on material
RickE1
  • 202 Answers
SOURCE: upper thread getting tangled in the bobbin
Always remember T-N-T. Thread, Needle, Tension. Assuming its threaded properly, is the needle all the way in and facing the right direction? These symptoms also suggest the bobbin may be in the bobbincase upside down thus turning in the wrong direction. Hope this helps.
Posted on Aug 23, 2007
dupina
  • 110 Answers
SOURCE: bunching thread underneath
When your thread is bunching at the bottom, your top tension is not tight enough, or you did not thread the machine correctly. Make sure the thread goes through the tension blades. Check your manual how to do it properly. you can check if there is any tension by pulling on the thread before threading through the eye of the the needle, and with the presser foot down. By pulling with the left hand and adjusting the tension with the right hand you should be able to feel a difference. Normal setting is between 3 and 5
Posted on Nov 13, 2007
  • 99 Answers
SOURCE: Amatur Sewer?threads tangled below
Stop sewing! You need to adjust your tension. Your book will explain exactly how to do this. If you can't find your book, try setting the tensions to the same number. If your tension adjustments have a mark at a certain number, use that setting for most materials. If not, try setting it to about 3.
To test your settings, thread your bobbin with a different color, then do a test stitch. Check the top and bottom stitches for a spot of the other color thread showing through. If the bobbin thread shows in the top, raise the bobbin tension setting a bit and try it again.
Hope this FixesYa!
Posted on Aug 11, 2008
SewTechWayne
  • 186 Answers
SOURCE: Needle Thread breaking after about 30 seconds of quilting
Make sure the feed dogs are dropped (or feed dog cover is on - I can't remember which way this machine works). The stitch length on the machine has no function so ignore it. (I set it to zero so the machine doesn't have to work as hard). Hopefully this is all that's wrong. If not, use a shorter setting for the stitch length on the regulator, oil the hook and move slowly and smoothly.
Posted on Jan 31, 2009
  • 43 Answers
SOURCE: skip stitch
The three most obvious causes (other than that of the machine possibly being slightly out of time) are:
1) Too small of a needle size - increase the size.
2) A needle that has a flaw / defect - change the needle.
3) Needle not inserted correctly, either not pushed all the way up into the needle bar, or not installed facing the correct place. On this machine, the small "scarf" in the needle (an indent just above the eye) shouldface the right side of the machine.
Posted on May 07, 2009
Why is the thread shredding above the needlehole on my juki lu563
are you threading the needle from the correct side
upper tension too tight
thread too old
needle alignment and timing needs adjustment
Mar 18, 2015 | Juki Sewing Machines
The thread on my Janine3-18 is getting tangled on the bottom of tho sewing
usual if thread tangles on the bottom is that you top thread tension need adjusted try on a piece of scrap material and adjust your tension until the stitches are even top and bottom hope this helps you
Feb 11, 2015 | Sewing Machines
My juke lu563 will not form a stitch with the bobbin thread. Also the walking foot doesn't move the material
remove all the parts for the foot an put them on an run each w/o thread an watch.put parts on a little at a time an watch for failure
its likely the foot spindle not moving at all .
Jan 12, 2015 | Sewing Machines
How big a thread and needle capacity with juki
Largest thread is a Tex 177 and needle is a DPx17 #24
Sep 18, 2014 | Sewing Machines
The bottom stitching looks like a line and not stitches the top stitching is fine
whether its bias or straight does not matter to machine. loosen the bobbin tension and put more tension on take up spring by inserting a screwdriver in the slot of the top thread tensioner. turn to right.
Dec 13, 2012 | Juki DDL8300N Sewing Machine
try adjusting the top thread tension and see if that helps
also try changing the thread.
also change the needle--make sure it's the right needle for the fabric
being sewed.
My thread on the top of the material is stitched fine.. the bottom stitch ballons
try changing the needle
rethread the machine use every thread guide
check to see if the thread has come off the thread take up lever
clean under the needle plate & in the bobbin area for lint
if none of these suggestions work, then the machine needs to be
checked to see if there is a problem with the timing
Sep 23, 2012 | Juki Sewing Machines
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
Upper thread getting tangled in the bobbin
Aug 21, 2007 | Euro-Pro 416 Mechanical Sewing Machine
Sewing Machines Logo
13 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
