Question about Whirlpool GU2400XTP Built-in Dishwasher
Water not draining whirlpool quiet partner ii
I had a garbage disposal installed in sink and a new kitchen faucet. Now my dishwasher will not drain the water. I think that it has something to do with the new garbage disposal. Please help.
  • 135 Answers
Remove the drain line where it hooks into the disposal. See if the plug, which must be removed to let water thru, is still in there. I ran into this on a service call a few years back. Removed to plug and voila! Hope this helps!
Posted on Jan 13, 2009
When my dish washer discharge water instead of the water going out the drain it come out the overflow valve.
The dishwasher usually drains into disposal, or directly into tailpiece, and water drains down to the p-trap.
Trap may be clogged or stopped up.
Clean out drain line, tighten connection where dishwasher attaches.
Clean out bottom of disposal under cutter blade.
Copy following link for clogged disposal, and drain line tips.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Oct 18, 2012 | Kohler K-692-7 Clairette Kitchen Sink...
My dishwasher isn't draining. The garbage disposal is hooked up separately.
Is sink drain line clogged?
Disconnect drain line at sink tailpiece and lower down to see if water inside dishwasher drains.
Call serviceman to clear clog in dishwasher hose, or repair dishwasher pump motor.
Oct 13, 2012 | Whirlpool Gold Dishwasher with Quiet...
Dishwasher Whirlpool quiet partner 2 will not drain
Check your drainage hose going to the kitchen sink. It should be routed up to an air gap on kitchen sink, or ran to the highest point as possible under the kitchen sink counter and then slope down into the disposer or branch wye tailpiece on your drainage piping depending on what your drainage configuration is. Not going up to the highest point, or an air gap, before draining into your drainage piping allows the water inside the dishwasher hose to drain back into the unit.
Feb 21, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner 1 won't drain all the way suddenly
Hello.
HERE ARE TOOLS NEEDED AND INSTRUCTIONS ON HOW TO SOLVE THE DRAINING PROBLEM BELOW.
(A) Clean cloth(s)
(B) Wrench (if necessary)
Whirlpool brand dishwashers come in black, brown, stainless steel or white finishes and a variety of sizes as well. Most Whirlpool dishwashers are energy efficient, and many have features such as a sanitizing rinse, enhanced sound effects, large capacity tubs and adjustable shelves and racks. However, none of these features will help users much if the dishwasher is not draining. While this issue may require professional repair, some troubleshooting steps may help determine if there is a relatively simple cause for the problem.
1 Verify that the Whirlpool dishwasher has not lost power due to a power failure or motor overload. Wait a few minutes to see if the motor automatically resets and resumes operation. Reset the circuit breaker or fuse if necessary.
2 Press or select "Start" to resume the cycle if the dishwasher was stopped mid-cycle. Choose a new drain cycle if necessary to remove excess water from the unit.
3 Turn off the dishwasher and unplug it from power. Examine the connection between the dishwasher and the garbage disposer, usually located underneath the kitchen sink. Make sure the disposer knockout plug was taken out between the two.
4 Run the garbage disposer in the kitchen sink to remove potential blockages.
5 Remove objects that may be blocking the drain on the dishwasher. Clean out the drain hose at the rear of the dishwasher.
Thanks.
Nov 06, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
We bought a new dishwasher because the old one wasn't draining all the way. Same problem with the new one?
The pump is a motor which runs in one direction to spray water in the dishwasher to clean and the opposite direction to drain the water. The problem could be from a clog or kink in the drain hose. Several years ago the drain line would connect to the sink garbage disposal. If the garbage disposal is not draining or the dishwasher connection to the garbage disposal is restricted or clogged the dishwasher will not drain. Under the sink, look at the garbage disposal to see if a rubber hose is connected at the side of the disposal unit. If a hose is connected to the side of the disposal, remove the hose clamp and check for any restrictions from garbage in the inlet or hose. You can use a screwdriver to clean the fitting to the garbage disposal and a wire hanger to free any restrictions in the hose. If the dishwasher does not connect to the garbage disposal it should connect to the sink trap. This is more common with new dishwashers because they have built-in disposals. Disconnect the drain hose from the sink trap and the dishwasher and look for a clog at the sink connection. The dishwasher inlet should have an angled piece of plastic or metal facing downward to prevent the waste from the dishwasher from spraying up into the sink. Do not get to aggressive with the cleaning in order to prevent breaking the angled piece of plastic or metal. Look for any kinks in the hose and try to run water through the hose, but do not use the sink which you removed the drain line from or it could leak under the cabinet. If you see a bad kink replace the hose with a new one. I hope this works and you find the problem without a great deal of time or trouble.
Nov 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
My Whirlpool Quiet Partner III is collecting dirty water after the garbage disposal has run. Is this problem the dishwasher or garbage disposal?
The drain hose under the sink needs to be tied up,above the point where it enters the drain pipe or disposal,water is feeding back into the unit,run the disposal more often also this helps prevent this from happening.
Aug 19, 2009 | Whirlpool Dishwashers
Whirlpool gold quiet partner 3 wont drain.
The new garbage disposer comes with a plastic cap in the drain port. Disassemble the drain pipe assembly and remove the cap/plug.
Jan 13, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Water Stayed in dishwasher
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Oct 28, 2008 | Frigidaire 24 in. FDB750RCC Stainless...
Whirlpool GU2400XTP Built-in Dishwasher Logo
360 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
