Question about Kenmore 62602 Electric Dryer
Kenmore dryer wiring diagram
Can you tell me where to get a wiring diagram for kenmore dryer 110.68932792
  • ohio_gramma Jan 16, 2009
    My dryer is the 70 series, is there a diagram to fix the heating problem suggested?
Can I get a diagram to fix the heating problem for a Kenmore dryer?
Posted on Jan 16, 2009
aborcass
  • 2651 Answers
SOURCE: Kenmore Dryer Model #110-86467810
remove bottom acces panel from under door, close door adnhook one end of sprinf to lower frame and other end around loop in hinge
Posted on Mar 01, 2008
jsrock516
  • 5911 Answers
SOURCE: WIRING DIAGRAM
The manufacturer normally places a wiring diagram inside the operator console. Remove the back panel and there should be a diagram taped inside. Some of these diagrams will show two circuits. One is for a gas dryer, and one is for an electric dryer. Make sure you reference the correct one. I hope this helps you. If you need further assistance please let me know.
Posted on Aug 15, 2008
jsrock516
  • 5911 Answers
The following link explains the proper wiring scheme for installing a 220VAC power cord to an appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Make sure you also have a dedicated outlet and power source for your dryer. This means a single outlet with a single circuit breaker. Most homes are constructed this way to ensure safe operation of the appliance and to prevent improper loading. If you have questions, please let me know.
As far as a wiring diagram is concerned, most manufacturers place a schematic drawing inside the operator console of the appliance for troublshooting purposes. I hope this helps.
Posted on Oct 16, 2008
  • 35 Answers
SOURCE: kenmore dryer model#110/62622100 will not atsrt
check to make sure you dont have a blown fuse or a triped breaker if they are fine if you have a volt meter take the back panel off on the control are or if it is the other kind losen up the two screws in the back of the control area and when you get it lifted up make sure unpluged then put the volt meter on the beep mode when probes touch then put it on the two spots on the swicth and push the button if it beeps it is good if it dont it is bad and that part dont cost too much another thing you should check before you do all that check make sure you have 220 volts on that plug if the switch is good and you have 220 volts it probably the motor or the timer they both or expensive
Posted on Jun 07, 2009
jsrock516
  • 5911 Answers
SOURCE: Diagram
That's a model "110" followed by a whole series of numbers. The 110 prefix identifies the manufacturer as Whirlpool. You need the rest of the number which is usually located on a nameplate along the door opening. Once you have the model number, any of the following repair sites are excellent sources for parts:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites offer great service with competitive pricing, with the first two offering better exploded view parts illustrations. Shop all of them for the best price.
If you need assistance, please let me know. I hope this helps you.
Posted on Jun 29, 2009
I need a wiring diagram for a Kenmore 110.86872100. replacing the thermostat and the heater element, don't want to cross wires. Can you help?
If you remove the cover from the back of the dryer control panel there will probably be a wiring diagram for your dryer folded up and taped to the back. Something to try if you can't find it otherwise.
May 23, 2010 | Kenmore Dryers
Need a wiring diagram for Kenmore 110.63102101 dryer
Here you go, this is for both gas and electric units, since your unit is electric use the top diagram
Kenmore 6210 Dryer wiring diagram
May 01, 2010 | Kenmore 400 6942 Dryer
Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Feb 07, 2010 | Kenmore 62602 Electric Dryer
Kenmore 70 series electric
As the push switch is sitting in its housing, the two red and white wires connect to the top contact (the one that splits into two). You should be able to tell which is top and which is bottom by the way they have routed themselves over time.
The black wire connects to the bottom contact, and the plastic clip connects to the side contacts (the left side as you are looking at the front of the dryer).
You can verify the connections on the diagram on the inside of the rear panel, which you should always do before connecting the wires and turning the dryer on.
Oct 12, 2008 | Kenmore 73952 Gas Dryer
Thermal fuse
remove the bottom paneland look y the heating element there should be a mini manual down there with a wiring diagram
Aug 16, 2008 | Kenmore Elite HE4 Electric Dryer
WIRING DIAGRAM
Aug 13, 2008 | Kenmore 63942 Dryer
I NEED OWNERS MANUAL TO KENMORE DRYER
thiknin you need a service guide , not owners manual( only tell how to operate} ther is a schematic/ wiring diagram locate with inthe console itself usually taped to the back wall behind the timer
Mar 27, 2008 | Kenmore 63942 Dryer
Kenmore 62602 Electric Dryer Logo
2,580 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
