Question about Vivitar ViviCam 3935 Digital Camera
Memory card locked
How do I unlock memory card on a vivicam 3845?
  • 385 Answers
Check the side of the memory card
there is a lock on it.
Hope this helps
Regards
Richard.
Posted on Apr 21, 2009
Card locked comes up can not take a picture
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 02, 2014 | Vivitar ViviCam 8400 Digital Camera
Vivitar 7025 card locked
Jan 28, 2014 | Vivitar ViviCam 5024 Digital Camera
Can't take pictures with ViviCam 7022 It says Card protected
Oct 25, 2012 | Vivitar ViviCam 7022 7.1 MP Digital Camera...
Cant unlock any memory card in my vivicam 5024 camera help please
Nov 15, 2011 | Vivitar ViviCam 5024 Digital Camera
Inserted 4 GB memory card. new camera trying to take a pic and I keep getting the message card protected.
Memory cards particularly SD or SDHC have an option to protect the files from accidentally deletion. This is done by moving the small part of the memory card to the 'lock or unlock' position. Try to look for this small switch on the side of your memory card.
Dec 26, 2010 | Vivitar ViviCam 35 Digital Camera
Inserted memory card but keeps coming up memory card locked
SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Dec 25, 2010 | Vivitar ViviCam 5018 Digital Camera
I replACED MY MEMORY CARD WITH NEW SD 2gb CARD AND NOW IT SAYS MEMORY FULL AND THERE ARE NO PICS ON IT... HELP
make sure the lock on the side of the memory card is in the unlock position. sometimes they will lock when inserted into camera. good luck.
Dec 07, 2010 | Vivitar ViviCam 3785 Digital Camera
My daughter has a vivicam 5022 and when i put the memory card into it, it says card locked and wont take any pictures how do i unlock the card?
SD cards have a slide switch along one edge. The position nearest the contacts enables writing, the opposite position protects or locks it. Try sliding it fully to the locked position and then fully to the unlocked position. If that doesn't work, try a different card.
Jan 24, 2010 | Vivitar ViviCam 5022 Digital Camera
Card locked
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Jan 13, 2009 | Vivitar ViviCam 3935 Digital Camera
Vivitar ViviCam 3935 Digital Camera Logo
85 people viewed this question
Top Vivitar Cameras Experts
SHARCNET-USA
SHARCNET-USA
James Woodgreaves
James Woodgreaves
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
