Smell of burning rubber
At times when the heating unit comes on there is a very strong smell of burning rubber. The unit has a direct drive pump. A techcian has been out and could not find anything wrong.
  • jpbrarsr Jan 13, 2009
    The unit is the heater for our home. When I turn the heater on there is a smell of burning rubber or wiring through out the house. This doesn't happen every time, but is sporattic. We don't see smoke but it sets off the smoke alarms. I have had a licensed electrician out to the house to look at it, but he was not able to find anything wrong. We ran the heater for about 30 min. while he was here, but it did not malfunction, (go figure). The model # of the unit is RBHC-21J18SFA. Serial # is T M3901 14631 Thank you again for your assistance. John Brashears
  • Brian Markstahler May 11, 2010
    what are we working on? as it has a direct drive pump i would assue it is either hot water or geo-thermal heat? more detaail as to your system is needed to attempt diagnosis.
  • 24 Answers
Alright so you have a heat pump with back up electric resistance heat. We need to determine if your odor occurs when the heat pump is operating, when the electric resistance heat is operating or both to isolate the possibilities since the issue is intermittent. Thermostat should have an emergency heat position, this will shut off the heat pump and operate the electric resistance heat only. If the smell/odor occurs then we have reduced the possible causes. let me know, happy hunting.
Posted on Jan 15, 2009
I have a 99 Chrysler 300m when I turn the heat r ac smoke comes from the vents and from under the hood.. When I turn the heat/ac off it stops.. It has a smell like burning rubber
sound like AC COMPRESSOR clutch bearing going bad causing locking up putting drag on drive causing drive belt slip giving a burn rubber smell.
Jun 17, 2013 | Cars & Trucks
Battery light on and a strong burnin rubber smell
SOUND LIKE ALTERNATOR SHAFT BEARING FAILING CAUSING ALTERNATOR PULLEY LOCK OR PUT DRAG ON DRIVE BELT CAUSING BURN RUBBER SMELL OR DRIVE BELT LOOSE CAUSES BELT SLIPPAGE MAKE BELT RUB AND BURN.WHEN YOU SMELL RUBBER BELT BURN SMELL WATCH OUT DRIVE IS GOING TO BREAK.
Aug 04, 2011 | 1983 Ford Fairmont
When i am driving on the highway for long periods of time, my car has a really foul burning smell to it, what is causing that?
WHAT SMELLING ROTTEN EGG SMELL OR BURNING RUBBER SMELL.MAKE SURE YOUR EMERGENCY BRAKES RELEASED.YOU WILL SMELL BRAKE SHOES BURNING UP OVER HEATING.
Jan 27, 2011 | 2009 Pontiac G8
Strong burning smell coming from vents and from inside rheem electric central heat. Smells like rubber burning.
You must have to open it, try to clean it..and check for some eletric cables with short circuit or bad cables burning and overheating...check the motor fan and if it has a bad AC capacitor
check the photo, and you will have an idea.v4ndre_0.jpg Good luck!
Dec 06, 2010 | Heating & Cooling
Dryer part, smells burnt and is extremely loud
If you notice a burningsmell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The "Burning Belt" Smell
Older, top-loading washing machines use a belt drive to transport energy from the motor to the transmission and pump. The belt can prevent costly repairs to the motor or transmission by slipping, stretching, or breaking if there is a malfunction in the machine. If the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell.
The solution is actually quite simple: you need to replace the drive belt on your washing machine. You can call a repairperson or, if your washer is under warranty, the manufacturer. If you or someone you know is handy, you can replace the belt yourself. The belt is located either from the back access panel or from the underside of the washer.
Most new washing machine models are "direct drive." This means they do not use a belt. The motor is directly connected to the transmission. If you have a direct drive machine and your washer smells like it is burning, read on.
Electrical Problems
If your washer smells and you have a direct drive machine, it may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Other Causes
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell. For top load washers, overloading can cause the agitator to freeze or malfunction, stressing the drive belt and causing friction, which could emit a burning rubber smell.
To prevent overloading, know the size of your washer. They are measured in cubic feet. In addition, know how many towels, pants, shirts, and other items you can safely load. When it doubt, do smaller loads. Not only will this prevent overstressing the machine, it will also ensure clothes are thoroughly cleaned and rinsed.
Nov 07, 2010 | EuroTech Washing Machines
Acceleration trouble, engine heat, rubber burning smell
Sounds a lot like a blocked catalytic converter...have it checked.
Jul 19, 2009 | 2002 Jeep Wrangler
What is the smell and does it have to be fixed?
A burning rubber smell under the hood might be just that - consider having your accessory drive belt inspected, as it is possible that a bearing in one of the accessories (alternator, power steering pump, air conditioning compressor, etc.) or in the tensioner mechanism might be failing. This sort of fault will often cause that particular accessory bearing to spin less freely than the others, and as a result the belt continues to pass over the associated pulley at the same speed as the engine. Essentially, the result is similar to a car spinning its tires on dry pavement - and a similar 'burning rubber' odor is the friction and heat of the rubberized belt.
If the odor is more like burning oil than burning rubber, the rear valve cover gasket is situated in a place that results in dripping oil, even small and unnoticable amounts, onto the exhaust manifold that is directly underneath the valve cover.
These two items might be places to start your inquiry. Best of luck to you!
Apr 16, 2009 | 1998 Lexus ES 300
Very Strong Odor When Refrigerator Runs
Without looking at your fridge I would say the strong rubber smell is the heater element has dust on it or the heater contactor is closed and the heaters are staying on. Either way it would be good to get it checked out. I cannot think of anything else that would make a rubber burning smell.
Jan 23, 2009 | Frigidaire FRS26R4A Side by Side...
Burning Rubber smell coming from fridge
try taking the bottom panel off and vacuming all the dust on the coils. The dust may be heating up and burning. The coils are usually at the bottom of the fridge. Check to see if the fan is running also.
Jan 16, 2009 | Refrigerators
A smell of burning rubber is coming from my engine. What is it? Could it be the timing belt? Is it safe to drive any distance? Thanks burning rubber smell from engine
A common cause of a smell like that is a coolant leak.Take a close look around the hoses,clamps, frost plugs and the water pump as it has a weep hole that will leek coolant if the seal is breached. Sometimes all you will see is a stain, but no coolant as small leeks boil away with the engines heat.
If a belt was burning it would be very noisy. The timing belt is cogged so slippage is unlikely. It is possible that a foreign object has gotten on the exhaust manifold like a plastic bag. One last thing I can think of is a wire or something touching a hot surface and melting. Good luck.
Dec 14, 2008 | 1993 Toyota Camry V6
Heating & Cooling Logo
2,165 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
