Question about Verizon Communications Samsung Juke Cell Phone - Red
I can't find where to open the port for charing the phone?
  • 4 Answers
If you look on the right side of the phone therewill be a opening for headphones that is silver and a second opening that should be whatever color your phone is. The second opening is the place to put in your charger or the usb conector.
Posted on Jul 15, 2009
Iphone 3 battery not charging
Syed,
I am pretty sure in most of the cases there is a problem with the charging port of the phones. You can switch the battery with a friends or family member s iphone 3 and see if the battery charges in their phone. If not then the battery is dead and you need to buy a new one. If it is charging in other devices then your charing port where you insert your charger is faulty. I hope this helps :)
Jul 25, 2013 | Cell Phones
My samsung gt-c3303 champ auto charing problem,tell me solution of this problem?
Hello Friends:::::::::
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 14, 2013 | Cell Phones
Nokia 6300 charging not supported
When your phone shows charging not supported. First, you need to try a another battery on the phone, if it says the same thing, then try to use another charger, and if it shows the same thing, then you need to fix the charging port of the phone.
Before you do that, test, your battery and charger on another phone to see what happens, if they both work fine, then you need to fix the charging port of the phone.
Take care and good luck
Oct 13, 2010 | Nokia 6300 Cellular Phone
Headphone is not working and while charging it
its very easy simply change the charing jack of ur mobile nd these problem will solve
May 22, 2010 | AT&T Sony Ericsson W580i Cell Phone -...
V3 not charing
Try a known good charger and battery. If it still doesnt charge then its your charging port on the phone itself. If its ever been snagged while plugged in, high chances are that its the port itself and the best bet is to sell the phone on ebay and get another razr. Theyre fairly cheap now and plentiful. :)
Jan 18, 2010 | Motorola Mobility RAZR V3
Not charings
First of all, do not turn it on. Take out the battery, and completely dry the phone before trying to use again.
Did you dry the phone completely? If not here is the procedure to take out all moisture trapped in the phone: Dry the phone, battery, any accessory, etc. with cloth and wrap each piece, phone and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped phone in the bag with rice. The newspaper wrapping avoids direct contact of rice with your phone because the dust from the rice can get into the small areas of the phone. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs. Also, check the contacts between phone and battery, if necessary align or clean.
Dec 27, 2008 | Motorola Mobility L6 Cellular Phone
Want to charge phone my pc.
my motrola v3m isnotgeting chare with my pc i lostmy motrola drivers plz sugest me how 2 chare my mobile becas my motrola charger is not working
Oct 20, 2008 | Motorola Mobility RAZR V3
My daughter's LG EnV charging port
You can get a charger at factorydirectcellular.com. The link is
http://www.factorydirectcellular.com/home/universal/universal-battery-only-charger.htm
The charger charges the battery independent of the phone. It is the only one I have found and it works GREAT. I had a couple issues at first but the rep, Matt, bent over backwards to resolve them. I would recommend this charger and company to anybody. The charger is a universal charger and will charge other cell phone batteries as well. The only con is that it does take a little longer to charge than using the port.
Sep 06, 2008 | LG enV VX9900 Cellular Phone
LG CU500
try a new battery if that does not work then the USB port may need servicing.
Sep 06, 2008 | LG CU500 Cellular Phone
Open Questions:
See all Verizon Communications Samsung Juke Cell Phone - Questions
Verizon Communications Samsung Juke Cell Phone - Red Logo
37 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
Laxman Bisht
Laxman Bisht
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
