Question about Canon i860 InkJet Photo Printer
Yellow full but it will not print
This printer has been sitting for at least six months; maybe longer. It has plenty of yellow ink left, but it won't print any yellow color. what do i do?
    Genius:
  • 2,985 Answers
Take all the cartridges out. Get a wet tissue paper or better still a 'moist wipe' put it on a plate stand the cartridges on Does the print head come off on this model? If so do that same with the print head. Always print something in Full colour at lease once a week. If you are unable to do this then take the cartridges out put them in a plastic bag with damp tissue to stop them drying out and store in a cool place Also go to www.fixyourownprinter.com
Posted on Jun 10, 2007
SOURCE:
Epson Stylus Photo R800 not printing certain color
You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Aug 15, 2012 | Epson Stylus Photo R800 InkJet Printer
Yellow printhead on my Designjet 3500CP isn't releasing ink
If you can access the printhead, try taking a rag with a small area heavily wet with Denatured Alcohol (this is a cleaning solution that can be purchased at Walmart or most stores with cleaning supplies. Rub the printhead thoroughly with the alcohol for a minute or two, it should help loosen any dried ink. Then try to print or run a print head clean cycle on the printer.
Nov 03, 2017 | HP Designjet CP UV Yellow Ink System...
I have to print a word document in black. Because I have no yellow ink, the printer won't print anything. I have tried everything and just want to print a simple one page document and I have plenty of...
here's a solution i came across when dealing with the same problem. apparently the printer expects all of the cartridges to be full and has a sensor to make sure they are even when only printing black. hope this helps!
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Jul 13, 2011 | Brother MFC 490cw Color Inkjet...
Ink absober is full
Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during Print Head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible
Jan 11, 2011 | Casio Office Equipment & Supplies
PRINTER WON'T PRINT RED NO YELLOW ON TSTEST PATTERNS
Is the yellow ink full? You can run an ink check in your printer properties to find out for sure. You can also pull your yellow ink cartridge out and put it back in to make sure that it is sitting correctly.
Oct 08, 2010 | Brother DCP-110C All-In-One InkJet Printer
Empty yellow cartridge, but cannot print in black?
Most printers use a little of all inks in their functioning, just to keep all the inks flowing, so while it is not printing yellow, it uses it in the startup mode to verify function and cleaning mode to clean the nozzles. Manufacturers usually do not put in a bypass for this, because they make money mostly on selling you ink cartridges.
Jan 20, 2010 | Brother DCP 165C Compact Color Inkjet...
My ESP3 keeps printing out my pictures in pink , there's plenty of ink in the cartridges, but it only registers them as half full
Makje sure you run an ink nozzle clean regularly, when printers are turned off ink tends to soidify and block the jets ( no one tells you this) nut printers should be left on to ensure against this. EPSON printers used to do this a lot and completely clog after 36 hrs, so over a weekend you were lucky if anything printed on monday and the printer became a write off after a few months. We found by trial and error and at grreat cost to leave them on to keep ink warm and in a more liquid state.
Aug 14, 2009 | Office Equipment & Supplies
Mfc 210 nor working
make sure that you are using genuine Brother ink cartridges.what is on the lcd screen of the brother machine?if no cart,remove all cart.reinstall them.if there is an error message,sorry,but you have to replaced.and your brother machine does not have a green cart.it only has cyan(blue),mag(red),yellow and black.there is a way of cleaning it though
May 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
Canon i860 InkJet Photo Printer Logo
56 people viewed this question
Clive
Clive
old marine
old marine
