Question about Averatec 3150H Notebook
Can't connect to wireless internet
I r click on computer icon and cilck repair but it can't find a network connection to compleet repair
  • Anonymous Jan 13, 2009
    can't connect lan cable connection has an x on it help me get this network up- connected how do i do this
    Sergeant:
  • 366 Answers
Check my tip
Be sure you can browse internet using LAN cable connection
Posted on Jan 13, 2009
Internet explorer cannot display page. I am able to connect thru the router only when i am hard wired to the router. once i disconnect the hard link between the router and laptop and open IE i receive the...
Well sir make sure of one thing that you should be connected to the network you have created for your wireless.
If you are using windows right-click on the two small computer icon located in the system tray at extreme right-hand side corner of your computer screen and then left cilck on view available networks and select the network you are using enter the password(if any) and click connect.
The message will apppear you are now connected to the network.
Open Internet Explorer page and you will be navigated to your home page automatically.
Dec 06, 2009 | Belkin (F5D8231-4) Wireless Router...
Tip
How to connect your wireless computer to the wireless network ?
Connecting your wireless computer to the wireless network:
Make sure the wireless switch is turned on in the laptop, now look for the available wireless Networks in range, select your network name, enter the security key and get connected. You may also follow the navigation below according to your Operating System
WINDOWS XP: Start > Control Panel > Network and Internet Connections(Network connections) > Right Click Wireless Network Connection icon > Click on View Available Wireless Network
WINDOWS VISTA: Start > Control Panel > Network and Internet (Network and Sharing Center) > On your left hand side click on Manage Network connections > Right Click on Wireless Network Connection icon > Click on Connect/disconnect
WINDOWS 7: Start > Control Panel > Network and Internet (Network and Sharing Center) > On your left hand side Click on Change Adapter Settings > Right Click on Wireless Network Connection icon > Click on Connect/disconnect
MAC OSX: Select airport icon from desktop, turn on Airport, you will be able to view the available networks in range. Select your network name enter key and get connected.
You may also click on Apple logo > System preferences > Airport > select network name
You will be able to see the Network name (SSID) which you gave in the Router, try to connect to this it will ask for password type it and click on Connect. You will get connected wirelessly and able to go online.
on May 19, 2010 | Computers & Internet
Tip
Configure Wireless Zero Configuration to configure wireless connection on XP...
Configure Wireless Zero Configuration to connect to wireless network on your wireless XP computer.
Below mentioned steps will help enable Wireless Zero Configuration on your XP computer and achieve wireless connectivity. These steps applies to your XP wireless computer (Desktops and laptops) with external or built in wireless cards.
Please perform the following steps on your wireless computer to enable WZC (Wireless Zero Configuration):
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
7. Highlight the SSID from the list that you want to connect to.
8. Type the security Key here and click on the 'Connect' button. You should have successfully established a wireless network connection.
The above steps will help you in the configuration of wireless connectivity if you are not aware about the settings of wireless connection utility installed on the computer.
on Mar 18, 2010 | Computers & Internet
Netgear wg111 usb 2.0 won't connect even after clicking repair
Hi, Follow the steps below to configure settings:
4. Change the Start Up Type to Automatic and click on Apply.
8. Go to the 'Wireless Networks' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
Sep 02, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
My NETGEAR WPN111 will not connect to my access point its all installed. I try to repair the problem but it ses. (WINDOWS COULD NOT REPAIR THE FOLLOWING PROBLEM BECAUSE THE FOLLOWING ACTION COULD NOT BE...
If you have window XP then perform the steps below:
4. Highlight the SSID from the list that you want to connect to.
For windows Vista perform the steps below:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
7. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 15, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
I have a dell 1521 computer and it used to
Assuming that the wireless driver is enabled and working, if not reinstall the wireless card driver. Are all the lights on the router are on, if not power down the wireless router, wait for 30 secs and power up the wireless router. Sometimes when you boot up the wireless card doesn't get an IP address from the wireless router. If you see the wireless icon on the Task Bar with a red X against it, just right click on the icon and click on Repair. This will repair the connection and get the wireless router to issue the wireless card with a new IP address. If you don't have an icon on the Task Bar go to Control Panel - Network Connection and right click on the wireless Network connection and click on Repair.
Jun 03, 2009 | Dell Inspiron 1521 Laptop
Please Help -- Acer Aspire 3000 Wireless Stopped Working When I R
If your wireless network adapter is OK then :-
If your wireless connection is on the Task Bar the right click on this Icon and left click on REPAIR.
If no Icon on Task Bar the click on Control Panel - Network Connections - then right click on your LAN Connection and left click on REPAIR.
This will get your wireless router to issue your wireless card with a new IP address.
Apr 22, 2009 | Acer Aspire 3000 Notebook
I can only connect thru my router when hardline connected. Cannot connect thru wireless. wrt310n router
On the computer wired to the router.
1. Open an internet explorer browser
2. Go to 192.168.1.1
3. Leave the user blank then "admin" for password unless you changed it.
4. Go to the wireless tab Check the wireless settings If the Wireless network name is Linksys change it.
Cilck save settings.
Go to the subtab wireless security.
Change the security to WPA Personal
then for passphrase put in a password 8 chars or more.
Click save settings.
5. On your computer use the wireless connection to connect to your network name then enter your password
If that does not work or if you have difficulty with the directions just call linksys support 8003267114
Aug 18, 2008 | Computers & Internet
I keep getting dis-connected from my internet connection, it says the error is a faulty winsock. i have downloaded errorfix and it says it's all clear, but the same problem still occurs....can you help?
okay Ill be happy to help :-). Ill tell you step by step what to do. Okay go into the start bar. Click control panel. Then select the network and internet icon. Then at the bottom of the window click network connections. The next window you see will have icons that represent all different accessible internet connections. All of the icons will have the image of two computer screens. The icon that has the 2 computer screens that are blue means that your internet connection . You must right click on it and select repair. This should repair you internet connection. If not I am sorry if this doesn't work. And if it doesn't you should try downloading patches for your specific internet provider.
Jul 10, 2008 | Computers & Internet
No wireless
you have to renew the ip address.the easiest way to do this is restart the computer then try entering your net key.ALSO if you use a standard ethernet cable the computer may be trying to connect to the internet through that.what you want to do is disable the LAN connection in your network connections window and right click on the wireless connection icon and click REPAIR,this will renew your IP address also.If you do not know how to get to these settings go to START/ CONTROL PANEL/NETWORK CONNECTIONS then right click on your wireless connection then click repair.While your in that same window you can right click the LAN connection and disable it.To enable it simply right click the icon again and click enable.
Nov 14, 2007 | HP Compaq nc6000 Notebook
Averatec 3150H Notebook Logo
50 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
