Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Timer light we can't get the tv to come on....the time light is flashing rapidly. It has happened in the past and we have either held the reset button or turned everything off and then started back up and it was ok....this time there has been no luck. Any suggestion on how to fix it or what is causing this to occur. Thanks
  • postman860 Mar 13, 2009
    Our tv has been replaced....we got the extended warrinty and the part is no longer available....tv was 4 yrs old.....glad we got the extended coverage!!
  • simonis13 Apr 07, 2009
    I have the same problem with the timer light flashing rapidly and the TV won't power on. The equipment is a Mitsubishi WD-62725. Reset button and disconnecting power at the outlet for a period of time did not help. I have had the light engine replace 2 years ago. The original bulb is working just fine. The TV is 4 years old. According to another posting, a person with the same issue on the same TV said the part that fixes this problem is no longer available, and the TV was replaced ! Good for them! My question to them is...Was the TV replaced by Mitsubishi, Corporation or by a local service agent? I'm curious, and your experience may aid me in obtaining similar results. I don't want to have a major overhaul on my TV every 2 years and this TV is on that path. I have just over 15 months left on my 5 year extended service plan and I don't want to deal with another failure 6 months after my service plan expires.
  • 38 Answers
Your main boards are bad. The FMT, DM, & Power Supply. They are no longer available, You have to have the chasis rebuilt. Mitsubishi is rebuilding these chasis. You have to pull it without any cut wires & ship to Georgia.
tvdoctor
Posted on Mar 13, 2009
I have a sharp aquos lc-70le650u, will not turn on, power light flashes rapidly 2 times then 5 times
I'm not sure about this one since I never worked on 1 of them.. But I did find a link that you can check on. http://www.badcaps.net/forum/showthread.php?t=41773. Good luck on it
Mar 02, 2015 | Sharp AQUOS LC-70LE650U 70" Class Full HD...
WD-65734 Mitsubishi TV won't turn on. System reset
Are there any lights lit on the front of the TV? Have you checked for a bad lamp? When you reset the TV the timer/power light should flash on and off rapidly for 60-70 sseconds. Does that happen?
Aug 26, 2011 | Mitsubishi WD-62526 Projection TV
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
How do i reset the projection lamp timer?
Hello
Press the "Power" button on the TV remote to turn the TV on. Press the "Display" key. Press "5," followed by the "Vol+" key, followed by the "Power" button. Wait for the service menu screen to appear on the screen. This could take anywhere from a couple of seconds up to a minute or two.
Press the "Jump" key three times in rapid succession. Press "2" nine times in rapid succession
Press "3" once, followed by the "Mute" key, followed by the "Enter" key. Wait as the screen flashes momentarily.
Press the "Power" button on the TV to exit the "Service menu" and turn the TV off.
Mar 15, 2011 | Televison & Video
I have a HDTV 1080 and the power to our neighborhood went out over the night and now the green light on the TV just blinks. I can't get the TV to turn on. I have reset the system reset button on the from...
try this ... if there is a reset button on your 'front' control panel..maybe 2 - 3 positions to the left of your blinking timer light..
try inserting the tip of a mechanical pencil or tip of a straighten paperclip into the 'tiny hole' of th ereset button ...hold pressure on that button until yout blinking light starts blinking RAPIDLY .. this
rapid blinking should continue for several seconds or a minute.
then it should stop .. may even go off ... now ..hopefully.. you will be able to turn your set on
Aug 20, 2010 | Mitsubishi Televison & Video
Flashing green light
Did you try this yet
SYSTEM RESET
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
buranc@bellsouth.net
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Timer light is flashing but tv wont turn on!
When the timer light stoped flashing the remote control would not turn on the TV. The next time the light quit flashing I held the power button in on the TV for about 5 seconds and it came on and has had no problems since then with the remote or the local TV power button.
Greg Allen
Aug 29, 2008 | Mitsubishi Televison & Video
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
97 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
