Question about Dryers
Kenmore dryer does not heat up. Mod#110 60912990
Replaced heating element and thermal fuse, but no luck.
Other operation appears normal - good airflow and drum rotation.
Suggestions?
Thank you.
  • miscbox Jan 14, 2009
    That did the trick. Thank you very much!
    New Friend:
  • 88 Answers
First I would make sure that you have 240volts coming into the dryer. Then I would check the thermal cut-off in is a fuse on the housing of the element. that should be it but if not look for the heater relay.
Posted on Jan 13, 2009
Kenmore elite electric dryer runs but then gets hot and then shuts off, replaced thermal fuse, dryer vent and tubing not plugged, dryer runs gets hot blows thermal fuse again.
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Apr 28, 2015 | Kenmore Dryers
Why doesn't my Kenmore 110 98575120 dryer heat up?
Most likely the thermal fuse is bad. Here' the part as well as a video of how to check it. http://www.repairclinic.com/PartDetail/b6p17/Kenmore-Washer-Dryer-Combo-Thermal-Fuse/3399849/527775?modelNumber=110.98575120&ss=a17b6d170762&mr=1
You'll need to remove the back panel of the dryer to get to it. It'll be located on the outlet duct neat where the hose hooks up. Don't forget to clean out the vent all the way to the outside. Poor airflow is why they fail. If your vent is clear than replace the t-stat on the heat element as well as the fuse.
Hope this helps. Good luck,
John
Mar 22, 2015 | Kenmore Dryers
Dryer not heating mod # 110.64652400
you may have several problems, first, check the thermal cut-off with a meter(continuity) at the side top or the heating element. if not beep or mesure "0" on the display then is bad, change it as a kit#279816 part# at Sears. if is good(it beeps) then check the heating element for ohm about 10 to 12ohms. if it reads "0" then is bad, part#279838. if is good then check continuity on the thermal fuse at the blower housing(a white 2prong part) if it not beep then change ir part#3392519. all parts at Sears Website or Sears Service Center. good luck to you.
Feb 06, 2011 | Kenmore Dryers
Dryer tumbles but no heat. Replaced Thermal
Howdy: Those are good shotguns. It could be the firing ignitor. Two solenoids control the signal to the element. If thay stick it keeps the element on too long or too shot. Take it down to test at Sears. Good luck - Doug
Dec 09, 2009 | Kenmore Dryers
Replaced thermal fuse ,ran cycle all the way than died again.Have had to replace fuse in past would usually get 9 months out of it .Replaced it dryer ran fine but after cycle completed dryer was dead...
Have you cleaned the lint out of the airways and the heat exchanger area? The lint filter traps most of the lint but not all, the airways and especially the area where the heating element is still fills up with lint. To get it out, you'll have to take the back off the dryer and open up the enclosure for the heating element and vacuum it out. The lint clogs the airway, which restricts the airflow, which lets the heating element get too hot, which is why the thermal fuse shuts it off. Otherwise, it would catch fire (and in some cases, still does). It should be good for another few years when you get the lint out. Good luck.
Aug 16, 2009 | Kenmore Dryers
Dryer will not heat. Mod: 11066652500 Ser: MS2302035
If your dryer is electric, it's most likely a thermal cut-off or the heating element. if it's gas, it's probably the thermal fuse. i do lots of these each week. 90% of the time it's what i just explained. good luck :)
Jul 03, 2009 | Kenmore Dryers
Turns on and has no heat
Check operating and high limit thermostats. Just check all thermostats and thermal fuse non resetable. After that is done check heating element. Good luck Be sure & check thermostats something is not shutting it off. Timer may be stuck in cycle.
Jun 26, 2009 | Kenmore Dryers
Kenmore Dryer won't heat up
thermal fuse is bad. replace fuse. clean out vent duct. thermal fuse usually blows when there is restricted air flow over heating element.
Jun 24, 2009 | Dryers
Kenmore dryer doesnt heat
You may also need to change your thermal fuse and the thermostat. On some models the thermal fuse operates the heating element only and others the whole dryer
Mar 19, 2009 | Dryers
Dryers Logo
195 people viewed this question
Top Dryers Experts
