Question about RCA P60921 60" Rear Projection Television
Picture pulses the 3 lights inside arent constant they like pulse and cause the picture to go brighter darker ...............brighter darker........
    Champion:
  • 240 Answers
Replace the flote.
any repairman will know wat this is.
part cost is from $56 to $93.
check around
partsstore dot com keeps a good parts stock for tompson or rca.
hope this helps
regards,
daniel.
Posted on Jan 13, 2009
I have replaced the fuel pump on my 1991 chevy cheyenne im getting fuel to the injectors but they aint working
Check the injector fuse. With key on, injectors should have constant power available to them on one wire. The other injector wire is ground wire. With constant power to injectors, all it takes to pulse the injectors is for the computer to ground the injector ground inside the computer for a split second, and pulse occurs, causing fuel to spray out the injectors.
So if injectors aren't working, either the injector drive circuit (the power to injectors) or the injector ground circuit is lost. You can buy a cheap "noid light" at any auto parts store, and check the injector circuit. Just plug the light into the injector connector and crank the engine over. If the light is blinking, circuit is good. If no light, the circuit has a problem, either on the drive side or the ground side.
Here's a way to check the ground circuit separately. Use a test light clipped to the Positive battery post. Probe the ground wire terminal of the injector connector while the engine is cranked over. The test light should be blinking-meaning the computer is grounding the circuit normally and would be causing the injectors to pulse, if power is available to them.
Aug 19, 2013 | Cars & Trucks
My injectors arent pulsing on my 1989 k1500 suburban. I have 12 volt power to the injectors and have replaced the module in the distributior. Any one have an anwser for me
The injector ground circuit must not be working. What causes the pulse is when the computer internally grounds the injector circuit, power is passed across the injector solenoid terminals. All the injector grounds are spliced together on each bank of engine, and run into the computer. So, injector power, but no pulsing would seem a computer malfunction as long as the ground wires are good. Did you check all the injectors for pulse with the noid light, or at least both sides of engine?
Jan 23, 2013 | 1989 Chevrolet K1500
Phillips 47PFL422D/37 I've had the tv about 6 years with no trouble. But now the picture is to dark to watch it also pulses. I've tried to unplug it and plug it back in I get a picture for
First, average life on these sets is about 3 to 4 years at best and only boards are sold so even if you can pin point the board (no individual parts are sold) it is likely if will not get fixed and doing so is a bad investment as all the boards are now old.
Dec 04, 2012 | Televison & Video
1986 pontiac fiero won't start, changed fuel pump and relay gas coming up, but no spray from injectors
Actually the injectors don't spray "all the time". They pulse open for a few milliseconds then close every time they are grounded by the ECM. The distributor has a pick-up coil (Variable Reluctance sensor) that provides an A/C (Alternating Current) pulse every 120 degrees of crankshaft revolution to the Ignition Control Module also contained inside the distributor. The I.C.M. amplifies, rectifies and passes along the pules as a +12V square wave to the ECM. The ECM uses these pulses to calculate RPM and determine when the engine is rotating vs. stopped. Together with this information and more from Coolant Temp., Throttle Position, Manifold Pressure and Air Temp. the computer constantly 'looks up' what the appropriate amount of time it should pulse the injectors for to deliver the required amount of fuel.
With that in mind, the injectors are supplied with +12V via a 3 AMP fuse labeled INJ 1 for 1 bank of 3 injectors, and INJ 2 for the 2nd bank of injectors. Make sure your injectors are getting +12V whenever the key is ON or they wont fire (or at least 3 won't).
If all 6 injectors have +12V and you have fuel pressure (checked by pushing down in the center of the Schrader (tire valve stem looking thing) valve and fuel SPRAYING out, and your still not getting fuel it is probably because the injectors aren't pulsing. They are probably not pulsing because the ECM is not receiving any reference pulses from the distributor. If you have spark then you are producing reference pulses.
I hope some of this explained from an actual '86 Fiero GT 2.8L V6 owner/mechanic will help narrow down your problem.
Mar 20, 2011 | 1986 Pontiac Fiero
Well jet pump pulses
Air in the system or a weak motor depending on the pulse.
May 14, 2009 | Plumbing
Images go suddenly darker
Turn off the the OPC feature in the Menu. If that doesnt help, what youre seeing is most likely the Advanced Dynamic Contrast going to work. In layman's terms, it automatically adjusts the contrast depending on the video signal it is receiving. If you want to disable this, change the AV settings to "User" (button underneath the bottom door on the sharp remote)
Jan 03, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Monitor colors "pulse"
What video card do you have?? Some older video cards don't display very well at higher resolutions... You may want to get the latest video card drivers which may help the problem.
You can find out what card by opening display settings and going to the screen that shows the 1280x1024 resolution.
Let us know how it goes
Oct 22, 2006 | LG Flatron L1951S 19" LCD Flat Panel...
RCA P60921 60" Rear Projection Television Logo
69 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
