Question about Whirlpool LER4634J Electric Dryer
Dryer dosn't get hot
I have replaced the themostat still have the same problem the dryer dosn't get hot
  • jensketo Feb 17, 2009
    i have no heat, i have tested the heating element it is good
  • Dean Rhymer
    Dean Rhymer May 11, 2010
    do you have no heat or low heat
    Problem Solver:
  • 9 Answers
The heating element is bad
Posted on Jan 13, 2009
Novotronic t442c
Heater coil is not getting hot. That could be the thermal fuse or the thermostat or the heater element.
Jun 17, 2013 | Dryers
Dryer not gettig hot.
Must be a gas model. They typically do that when the gas solenoids get age on them. They work once then quit, then work some more when cooled back down after a long period of time. Very hard to diagnose for the DIY person but pretty much a common probo associated gas dryers. Swap out the solenoids and party on!
If your is an electric model I would check the vent pipe or filter chute for parcial blocking which might cause safety themostats to shut down the heat.
Jun 16, 2012 | Whirlpool Dryers
Does not get hot
first check the themostat of the dryer, if otherwise take it to the manucfatuerer for proper diagonsis
May 29, 2010 | Dryers
My Whirlpool geq8811ll1 dryer turns on and spins but doesnt blow
you probably have one of the wires not connected correctly. or you could have bad themostat.
Sep 01, 2009 | Whirlpool GEQ8811L Electric Dryer
Dryer element stays warm
If it heats w/ the timer in off position whenever plugged in the the element is shorting to ground, its most likely due to either a broken coil or a cracked insulator. If heating w/ timer set for drying but motor is not running, the heat circuit thru the centrifugal/start switch on the motor is stuck closed.
May 16, 2009 | Maytag MDE2600 Electric Dryer
Kenmore Thermostat
hi,
order or study the wiring diagram, could be a hi/lo heat setting circuit, the dryer should spin no matter what heat problem, jump the door switch
J
Jul 11, 2008 | Whirlpool LER5636P Electric Dryer
Clothes dryer not getting hot enough to dry in a good time frame
I have the same issue with my DLG3788W dryer. It seem to have only one setting for heat, rather than multiple heat settings. What can I do or do I have to call someone to repair this.
Oct 03, 2007 | LG DLE0332 Gas Dryer
Whirlpool LER4634J Electric Dryer Logo
126 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
