Question about Casio FX-115ES Scientific Calculator
Store value in casio fx-3650p - Casio FX-115ES Scientific Calculator
How can I change pi value to 3.14 on calculator?
I don't think you can change the pi value on your calculator. However, what you can do is store 3.14 in the memory and instead of using the pi key, recall the number from the memory key.
How to use the various memory keys is outlined in the manual.
Good luck,
Paul
http://support.casio.com/storage/en/manual/pdf/EN/004/fx-300ES_PLUS_EN.pdf
Apr 07, 2016 | Casio fx-300ES Calculator
I've got a casio fx 991plus calculator and I want to know how to use feet and inches in the calculation displays, like how is used meters and centimetres in the display
PDF]fx-570MS/991MS Additional Functions - Support - Casio
support.casio.com/pdf/004/fx570MS_991MS_E.pdf
Casiodisplay format (Disp) settings while the calculator is in the BASE ... Be sure to checkthe current calculation mode (SD, REG,. COMP ... Use [ and ] to display the expression 4 + 4. Press A ... want to perform scientific function calculations. COMP .
The Casio fx-991es, fx-570es and - Numericana
www.numericana.com/answer/casio.htm
The Casio fx-991ex succeeds the fx-991es (functionally identical to the ... Both are nonprogrammable nongraphing scientific calculators, with natural ... Side-by-side comparison of the fx-991EX and fx-991ES PLUS. ... Displays QR codes for smartphone use .... Work out a formula for many values of the input variables.
CASIO fx-991MS Calculator Tutorial: Lesson 5- Dealing with ...
Dec 03, 2015 | Casio Office Equipment & Supplies
What is an Ma error casio fx-9860gii
Ma error means Mathematical error.
Check input values and make corrections to ensure that values are within allowed limits.
Please Check the manual for the calculator. It is available on the Casio website. Here is the link.
fx 9860G fx 9860G SD Calculators Manuals CASIO
Aug 30, 2014 | Office Equipment & Supplies
How do I set up my Casio fx-115ES to perform algebra?
This calculator cannot manipulate letter symbols, so it cannot do algebra. It can only use numbers whose values are known to it: either those on display, or those stored in variables A to E or F , X, Y, and M.
Sep 08, 2013 | Casio FX-115ES Scientific Calculator
How i store the values in my fx-991ms casio calculator
You can store values in the memory locations the calculator has (A,B,C, D, M). However they will may not remain stored once the calculator is turned off.
To store a value in say Memory location A
type in the number and press STO> A.
If that does not work, type in a number and press STO> ALPHA A
To retrieve a stored value, press RCL A or RCL ALPHA A
May 25, 2012 | Casio Office Equipment & Supplies
How to store and recall on fx-115es
To store a value into one of the variables A, B, C, D, X, Y, press SHIFT [STO] and the variable name.
To recall a value from one of them, press RCL and the variable name.
Oct 12, 2010 | Casio FX-115ES Scientific Calculator
CASIO fx-300ES
Storing
  1. To store numerical values in the variables A,B,C,D,X,Y and M you use the [SHIFT][RCL] key combination to access the (STOre) function.
  2. In what follows [ key] is the physical key and (key) is the SHIFTED key
  3. ex: store the value 13 in variable A
  4. 13 [SHIFT][RCL] (STORE) [(-)] (A)
  5. The calculator displays 13 --> A on top line and 13.000.. on bottom line.
Recalling
  • To recall a value stored in a variable ex: recall value stored in variable A
  • Press [RCL][(-)] (A)
  • Calculator displays A on top line and 13 on bottom line.
If you need to use the variables A,B,C,D,X,Y, and the = sign to create an expression to be solved with the solve( function you must press the [ALPHA] key
=: [ALPHA] [CALC](=)
A: [ALPHA][(-)] (A)
B: [ALPHA][ 0 ' "] (B)
X: [ALPHA][ ) ] (X)
Y:[ALPHA][S<=>D] (Y)
etc.
Jan 05, 2010 | Casio fx-300ES Calculator
Casio fx-7400G PLUS cubic solver?
First let us repair the terminology.
  1. You can evaluate any expression (find the value of any expression for a particular value of its variable).Store a value in the variable, say X. Key in the expression and press [EXE].
  2. You can consider your expression(should not contain a relational operator such as =, greater than, less than, greater than or equal to, less than or equal to) to be a function Y1(x) = expression and graph it, or generate a table for it. You will have several values of the function calculated at various points.
  3. You can set your expression equal to 0 and find the particular value(s) of the variable (the unknown) that make the equality TRUE. That is called solving an equation.
I am not sure that it has a solver (solving an equation or an inequation) but you can always draw your expression as a function and explore the graph (SKTCH) to locate the roots (or zeros) of the functions (the values of the variable where the function equals zero.) That is called solving graphically.
Hope it helps.
Thank you for using FixYa and for rating this solution.
Nov 05, 2009 | Casio FX-7400G Plus Calculator
Want to solve quadratic equations on my casio 3650p super fx
In your manual, Appendix Program Library, (Page A1) you have the listing of the problem to solve the quadratic equation. Type it in your calculator and execute it.
Hope it helps.
Aug 13, 2009 | Casio FX-9750GPlus Calculator
Keep answers in decimal form all the time?
If you do not want to see fractions set your calculator Input/Output mode to LineIO.
To do so, press SHIFT, then MODE to enter the SetUp. From the options offered select 2:LineIO.
Jan 08, 2009 | Casio FX-115ES Scientific Calculator
Casio FX-115ES Scientific Calculator Logo
66 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
