Question about Vulcan 36" WIDE ELECTRIC(Click Here): WALL MOUNT 36" Kitchen Hood
Vulcan Dishlex Exhaust rangehood System 3; broken filter supports
The tiny black screws that hold the filter up onto the hood have broken. Are they available in Sydney??
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Eureka airspeed one
DustcupScreen
Latch
Pull dust cup latch to release
dust cup. Remove filter and wash. Allow to air dry thoroughly (24 hours) before placing back in dust cup
Empty the dust cup into the trash container. Wipe debris off screen.
Hold dust cup handle in one hand and the bottom of dust cup in the other, turn dust cup counter clockwise to unlock the cup from the lid.
Hold dust cup handle in one hand and the bottom of dust cup in the other, line up arrow on dust cup with unlock icon on backside of dust cup. Turn clockwise to lock the cup to the lid.
Replacing the Belt
Unplug vacuum.
Recline cleaner back. Using Philips screwdriver, remove 4 screws from hood.
Using thumbs, push down on height adjust knob, while pulling up on
inside hood edges with fingers. Lift and remove hood.
Lift left side of brushroll out of
grooves. Then lift right side of
brushroll out of grooves.
Line up corners of hood and put hood tab inside the front of cleaner. From front to back, push hood onto base, keeping hood in base grooves, and line up 4 screw hol
Remove belt from the brushroll and motor shaft. Loop new belt over motor shaft and brushroll, onto grey belt pulley.
Jun 28, 2013 | Vacuums
AEG DK9660 extractor hood; the control panel has come loose; any pressure & it pops back out
You have to remove the base plate. There are 3 screws, one at each corner and one in middle at back. We had to release unit from wall by 5 mm to get at them as it was tiled up to unit. To release unit, remove filters and loosen screws holding it to wall. There are hooks higher up that continue to take the weight so it will not fall. I put a couple of wedges in to hold the unit off the wall. Take out 3 screws holding base plate and lower back, the front them comes out of slots. You can unplug the light wires and release the clips for the control cable to drop it down onto work top. Then you can easily work on switch unit. The plastic mounting had snapped on one side of mine, I used a longer screw and a square of metal behind to hold it in place. Then reverse the process, you need someone to hold the back of the base plate while you line up slots at the front.
Oct 19, 2012 | Kitchen Ranges
I need a small plastic part which controls air pressure in the Nilfisk Alto attix Vacuum cleaner
Fixya does not sell replacement air pressure controllers and cannot recommend sources.
Jul 24, 2017 | Nilfisk Vacuums
I have a columbia watch cl 7204. does the back pry off or rotate?
mcdevito75 here, Basically there are 3 ways to remove the watch back, If there are 4 screws holding the back onto the caseing you"ll need jewelers screwdrivers to reove the screws and cover, if there are square holes going around the edge of the back cover you"ll need a special tool called a case back remover tool available on ebay to un-screw the back cover, or the cover simply prys off. Look for a tiny tab on the back cover you may need a magnifier glass available at most Dollar stores or there may be a **** between the back cover and case of the watch to pry off the back cover, use a sharp knife and carefully twist the knife oncwe you find this tab or ****.
Sep 21, 2010 | Columbia All Sport watch
Need to change my air filter. Where is it located?
If it's the air filter for your air conditioner, it's located behind the glove box on the passenger side. No tools necessary....just pinch each side of the box until it hinges completely down so that you can see behind it. Unhook the latch for the cabin filter door, pull it out, replace the old filter, and replace all parts. Done!
If you're talking about the engine air filter, under the hood look for the big black box connected to the tube that connects to the engine. You'll see four (4) screws, one on each corner of the box holding it in place. Remove all four screws and lift the hood of the air filter container up so you can get to the filter. Replace the filter (the shape of the filter will determine how it will fit, you can't mess this one up), put the hood back on the box, and replace all four screws tightly. Done!
I highly recommend doing this yourself as the dealership and most garages will run you over $100 with labor and parts...at Wal-mart both filters cost <$30 depending on your vehicle.
Sep 18, 2010 | 2004 Honda Accord
Where is the airfilter located at on car?
LOOK UNDER HOOD FOLLOW AIRFLOW DUCT FROM THROTTLE BODY TO LARGE BLACK SQUARE LOOKING BOX WITH A COVER IT HAS 4 SCREWS HOLDING COVER ON.AIR FILTER IN THE BLACK SQUARE BOX HOUSING.
Mar 31, 2010 | 1995 Chevrolet Caprice Classic
How to change air filter 2005 volvo s40i
I have a 2007 Volvo S40 2.4i and I need to know how to replace the
engine air filter
Oct 03, 2009 | 2005 Volvo S40
Nakamichi BX-2 Cassette Deck Takeup Reel
I had sorta the same problem and I just fixed it. Mine was making clicking noises and jerking the tape causing speed variations and pitch changes, Uggghh. The FF, Rew, and take up functions are not belt driven like most decks. There is a little idler wheel between the motor and the take up axle. Take the whole transport assembly loose from the front of the deck...slide it back 3 inches . Take off the ground wire screw, and 3 screws holding the transport mechanism in place :...1 screw on top, 2 on bottom. Take the black front faceplate off of the drive...2 little screws. This exposes everything.The little idler wheel has a press on tiny,tiny piece of clear plastic holding it onto its little axle. Be hella careful. Use a tiny eyeglass screwdriver to pry it up and off. Dont lose it. Pull the idler wheel off. The rubber has hardened and slips. Pry the rubber rim off of the white plastic pulley using the tiny screwdriver. Put on an O ring that just fits. Scruff up the perimeter of the O ring with 220 sandpaper, Easy does it. Idler wheel goes back in, press on the little plastic retainer, put the black metal plate back on( 2 screws at top), slide the transport mechanism back into the front panel, secure with 3 screws, ground strap, replace cover. Clean heads, demagnetise, badda bing, badda boom.
Apr 06, 2008 | Audio Players & Recorders
Broken ring around 75-300 zoom lense
Hi Pamela,
You can order directly from Canon USA,
Canon's info: To order an internal replacement part, please call 1-800-828-4040. The hours of operation are 9:00 A.M. to 8:00 P.M. EST from Monday to Friday. When calling, speak the term "order parts" when the speech routing system asks the reason for your call. You will immediately be routed to the Parts Desk for assistance.
Jan 30, 2008 | Canon 75-300mm f/4-5.6 III USM EF Lens
Kitchen Ranges Logo
1,115 people viewed this question
Top Vulcan Kitchen Ranges Experts
Treefrog15
Treefrog15
Oloyede Monsuru
Dan Webster
Dan Webster
Are you a Vulcan Kitchen Range Expert? Answer questions, earn points and help others
