Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
Need part I need the part with the 2 yellow wires that mount to the board I beleive it is the ignitor. The other end goes by the nosal and has the prob on the end of it. Thanks Steve
  • 188 Answers
If you are looking for a All-Pro part I suggest you contact Master Parts at 800-446-1446 or you can find them online at www.masterparts.net. I hope this helps!
Posted on Jul 13, 2009
  • 124 Answers
Welcome back to FixYa. My name is Max and I'm the expert that chose your problem to fix. If you are satisfied with my service, I'd appreciate a rating of FixYa, since it's our highest rating. Now on to the problem:
You can download the owner's manual directly from this link:
http://www.4shared.com/file/83346916/1a21a714/123919-01A.html
Additionally, you can order your part from the following distributor, who handles All Pro parts:
http://www.masterdist.net/allproheaters
Thanks again for using FixYa!
Posted on Jan 31, 2009
Oven turns off while baking
There is a service flash, W10622771, for gas ranges of your model number--the bake burner ignitor is not lighting the gas--it's a direct spark ignition type. The ignitor is sparking but no ignition. Possible causes are (1) Wiring harness might be pinched between the bake/broil ignitors and the DSI board. (2) DSI mounting bracket may be contacting a solder joint on the back of the board. (3) Positioning of the ignitor and gas burner ignitor ports may be out of adjustment. (4) Ignitor electrode deterioration
Facing the range, the DSI board is behind the control panel on the left side, mounted in the bracket.You'll have to remove the back cover to expose the boards. BE SURE TO UNPLUG THE RANGE BEFORE DOING THIS. I can provide diagnostic mode if you want to proceed further.
Aug 09, 2015 | Maytag MGR8700DH MGR8700DH 5.8 cu. ft....
Gas oven will not lite but thing in bottom glows do not smell gas
By "thing in bottom" Iam assuming your talking about the igniter. If you are and it is only glowing then it probably needs to be replaced. If you cant smell the gas either thats a worring sign in of itself. I would first replace the igniter and then go from there though. Let me know how it goes!!
Aug 09, 2011 | Amana Ovens
Bake cycle wont work gas kenmore with electric controls you can set temp it goes to preheat and nothing happens broiler works and all the tops work
here is a tip i wrote covering that
What the problem is when your gas oven ignitor glows,but no heat for the...
MessageRate.ThreadID = 9947539; MessageRate.ProductID = 0;
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
Aug 03, 2011 | Kenmore Ovens
Heater will light but when gas is injected stays lit for 5 seconds then goes out
I would start with the flame sensing rod. There is a small metal rod approx 2 inches long with the diameter of a wire coat hanger.It has one wire attached to it which goes to the gas control board. It is mounted in front of one of the burners (often the burner furthest from the ignitor). This sensor sometimes develops a light coating that works like an insulator which will prevent it from sending the proper signal to the board to allow the gas valve to remain lit. In this case, the solution is simple: take a scotchbrite pad and lightly rub the flame sensing rod. This will remove the coating and allow for a proper signal to the board. Take care not to break the ceramic insulator, dislodge one of the burners, or to mistake the Hot Surface Ignitor for the flame sensing rod. The Hot Surface ignitor is the part that glows red and ignites the gas when the valve opens. It is extremely delicate. It has two wires (not one) and looks nothing like a single rod as I described the flame sensor. However, it too is mounted in front of a burner.
I hope you find this helpful. Good Luck! :-)
Feb 07, 2010 | Coleman Propane Forced Air Heater...
Need help with the wiring on the reddy heater 110 btu
CIRCUIT CARD-
-Photocell blue wired go to two terminals marked BLUE PHOTOCELL (any order)
-Motor red wire plugs onto terminal marked MTR MAIN, motor white wire plugs into terminal marked WHITE MOTOR.
-potentiometer (thing with knob) two white wires plug into terminals marked TEMP SEL
-Black wire from switch to terminal marked L1 BLACK
-White wire from power cord goes to terminal marked N White
-Ignitor (used to be yellow wires) goto terminals marked IGNITOR and IGNITOR RET (any order)
OTHER-
-White wire from power cord goes to switch terminal marked 3A , other pigtail of the white wire goes to board as described above.
-Black wire from power cord goes to swtich terminal marked 4B
Nov 14, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
1996 subaru outback wagon alternator wiring diagram. What is the yellow wire for?
are u sure about Yellow ??? i'm pretty sure Yellow is on '90 - '94 models.
Anyways, for those models it goes
1. Alter to Diode
2. Diode to Ignition Coil
3. Ignition Coil to Fuse # 16 in Fuse & Relay Box ( which is a 15A )
Hope that helps.
Nov 06, 2009 | 1997 Subaru Legacy
OVEN WILL NOT (GAS) LITE
With the assumption you have a gas range with electric ignition and is fully powered (plugged in); the possible problem may be the "Electric ignitor/Glow bar".
When turning on the oven, do you see a redish (good) or yellowish (not good; replace) glow emitting from the very bottom or the oven/broil area?
There are typically 2 types of electric glow bar ignitors; Round and Square. Ignitors are actually fairly easy to replace, removing 2 mounting screws and cutting/splicing 2 seperate wires together. Is your ignitor "round" (circular - like size of finger ) or "square" (rectangular - like snickers candy bar)
If your ignitor is not coming on at all; this can be a couple things;
Defective Ignitor - Gone completely Bad - Out (Assuming your have full power 110v to ignitor)
Defective Gas Valve - Assist in passing 110V to Ignitor
Defective Control Board / Thermostat: Assist in passing 110V to Ignitor
FYI - As a safety measure, the ignitor needs to "come on and appear solid red" to properly pass power to gas valve; thus opening and allowing gas to pass through the burners and combust.
Jan 27, 2009 | Magic Chef 31203 Gas Kitchen Range
Ignitor keeps sparking
ignitor works , so it's not broken. It's probably a flame sensor. It may be broken or what happens frequently , it moved out of place. Other cause might be a low gas pressure. Even if it starts, the flame dies soon and after few repeats it goes into lockout. I do not beleive your 'box' is broken either
Jan 20, 2009 | Heating & Cooling
BLINKING LIGHTS ON fURNACE
had same problem, first you need to find the location of ignitor double black wires from plug on board and flame sensor.single red wire. 4 red flashes means ground fault, I removed ignitor, cleaned with some scothchbrite, cleaned around screw holes(2) to reestablish ground, I even ran a wire from one of the mounting screws to a ground elsewhere. then I went on to the flame sensor witch will give you flashing yellow light. single red wire to sensor that has one screw holding in. Remove sensor carefully and do the same as the ignitor, clean with scothbrite. I did this a year ago and is still going!
Jan 21, 2008 | Dishwashers
GE XL44 gas oven
Starfish, remove the oven racks, in back there will be two chrome screws, remove them. Lift the lower oven panel out by pulling up from the rear. Remove the screws holding the flame spreader and remove the flame spreader. Now you will see the burner and igniter attached to it. There are 2 quarter inch hex screws holding the ignitor on. GE likes to put them on an angle where you cant get at them. If you have trouble you can remove the bottom drawer and remove the screws securing the burner to the back wall. There should be one in the front too. The burner will now lift up and you can get at the screws. The new ignitor should come with ceramic wire nuts. Just cut the old igniter, strip the ends of the wires going to it and wire nut the new one on. Reverse the rest of the steps. Here's a little trouble shooting schem. Catriver...post back.
Jan 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
