Question about Kenmore Refrigerators
How to remove the drink and ice dispenser from a type 2555A fridge?
Ice flap has come loose and needs to be refitted. I need to get into the mechanism to reattach the hinge. How do I remove the ice/water dispenser from the door of the fridge?
  • 4 Answers
SOURCE: Ice dispenser little flap not closing after dispensing ice, build up of ice on inside
you have apossibale air leak mixing with cold air from refer
Posted on Oct 17, 2008
aasc
  • 1606 Answers
SOURCE: in door ice dispenser
Remove the top freezer door hinge cover , and disconnect the plug there . This will remove the power to the door . Inside the lower part of the dispensor cover , inside the dispensor area , between the grill and the actual dispensor bottom , use a small screwdriver in the crease , and push down and inward carefully , to release the 2 plastic clips , mounted on the bottom of the dispensor cover . 1 clip on each side at the bottom . Then lift the cover straight up ( not outward ) , to release the top plastic clips Then unplug the receptical to the dispensor cover . You should see 4 screws holding the dispensor caseing , which will need to be removed , for access to the controls .
Posted on Oct 25, 2009
  • 1891 Answers
SOURCE: door flap and latch to ice maker and water
the parts you need can be found a www.apdepot.com part # 32 is door but latch / is ?? but in the diag you will be able to see what you need . hope this helps mm. . tip after reassemble try using food grade silcone on moving parts and shute this prevents freeze up .. mm
Posted on Jul 16, 2010
  • 2248 Answers
SOURCE: Bottom hinge on GE side
there should be a disconnect behind the kickplate under the door,also a disconnect for the wire harness too.don't cut anything,i've found people cut the wires and then had to replace the door for this.if for some reason there isn't a disconnect there remove the hose from the water valve but there's a disconnect there.pop off the kickplate and you should see it
Posted on Jan 22, 2011
kdrake84
  • 262 Answers
SOURCE: Model: ED2KHAXVS Installed: June 2009 Issue: Dispenser
Hi John....
Here is a link to your units dispenser parts drawing.
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Refrigerator-Parts/Model-ED2KHAXVS00/1198/0165000/W1002173/00008?blt=06&prst=&shdMod=
Being that you have ice in the bucket,that tells me that there is an electrical issue...no ice or water from dispenser.
Two parts you need to check
Part number 14 the switch and part number 17 the electronic board.
Let me know what you find....
Keith
Posted on Feb 21, 2011
Have a gs201eta ww refrigerator ice maker problem Unit makes ice, light works and water dispenses from the door. However ice cubes and crushed iced does not dispense from the door. The dispenser motor...
The fridge gets its cold air from the freezer through a vent between the freezer and fridge. the fan in the freezer blows air through it. there is a flap you adjust with the fridge temp. control.
Make sure it's opening and closing when you adjust the fridge temp. try to chec in the user guide.
Hope helps.
Jul 07, 2010 | Refrigerators
Ice dispenser won't work, light won't work.ge side by side fridge
A GE uses a 12 volt bulb . It will not come on , if you went and bought a bulb with the same receptical end . HAS to be a 12 volt .
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a side by side fridge/ freezer bought new 5 yrs age and the water/ice dispenser keeps leaking water. I noticed the the lever in the dispenser area seems loose. what would cause this type of problem?
One of two thing. Either the flap is not closing all the way allowing condensation to build up and drip, or you have a seaping water valve allowing water to seep out of the water spout insde the door.
Please rate solution if helpful. Thanks
Aug 19, 2009 | Whirlpool Refrigerators
The lights on the Ice and Water Dispenser flash
On left top side of door, remove cap and disconnect wire. This will turn off the control board on front of fridge and fridge will still run. Then follow this link - http://www.liny.net/MaytagIce2O.htm - click on frig picture at right and you will get step by step instructions with parts and tools you may need costing around $20.00 for a do it yourself fix.
Aug 19, 2009 | Maytag MFI2568AE Side by Side French Door...
In my GE Performance refrigerator side-by-side Ice is being made, but no water is dispensing. The GE Smartfilter is atleast 5 yrs old (I never used/never changed) because we always bought water from...
The water that goes to the door actually is routed through the hinge on the freezer door. Take a look and see if you can't find where the tube comes out and goes into the water dispenser. I bet it has come loose and is rerouting the water down the side of the fridge and onto the floor; hence the puddle.
Also, just because you don't drink the water doesn't mean you don't drink the water! If you use ice from the ice dispenser then you ARE drinking the water. The water that feeds the ice trays comes through the filter, so you might consider changing it every 6 months rather you use the water dispenser or not.
Hope this helps, I have one too and its causing a different set of problems...
May 11, 2009 | GE Profile Performance 25.2 cu. ft....
Ice dispenser
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced or something is wrong with the mechanism. The problem you describe is almost always air leakage around that flap.
Post back with the complete model number from the fridge if you need more help.
Nov 14, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Icemaker flap/door does not mechanically open
The description says you have an LG fridge?  I may need the entire model # from the sticker inside the fridge to tell for sure, but there is a motor behind the dispenser controls that opens the door.  Let me know if you need more help.  Also, you can view parts and diagrams at http://www.appliancepartspros.com/.
Oct 21, 2007 | LG LFX25960ST Stainless Steel French Door...
No water or ice through door
sounds like the dispenser assembly is not sensing that the trap door is opening fully, so it wont send power to the auger motor or fill valve. If you are pretty handy, you can disassemble the door and take out the dispenser assembly and try to take the assembly apart and correct the throw on the trap door. Otherwise, I'm afraid you need a new dispenser to the tune of about $250 parts and $225 trip and labor. Good luck!
Nov 07, 2006 | Sub-Zero 690 Side by Side Refrigerator
Refrigerators Logo
24 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
