Question about GE Energy Star WCVH6260F Front Load Washer
Will not run!
GE wpsr3100.. 10 years old..
I load my washer and it filled with water to the top.. .. but nothing runs?
The control knob dies not repond .. I baled the water out.. and removed the clothes. Now what?
It's as if the master knob switch stopped giving commands.. is there a circuit breaker that could have blown? or is the switch just shot?
Is it fixable?
Scott G
    Problem Solver:
  • 9 Answers
The control knob is most likely to be out on it if you take it apart and get a part number it should be easy to replace call an appliance parts place. i had to do the same thing to my washer and it fixed the problem
Posted on Jan 13, 2009
My GE washing machine drains the water after the rinse cycle but does not start spinning. It just sits with the water pump running and does nothing. This doesn't happen with every load but seems to be...
Most likely the tube from the tub to the water level switch is full of "gunk" so the washer still thinks there is water in the machine, and therefore will not spin. Take the front panel off by pushing in the retaining clips at the top seam between the front panel and the washer top. Pull the thin hose off the left side of the tub and clean it out. (or cut off an inch or so, but you can only get away with that once or twice). To help prevent re-occurance, every two or three months you can fill the washer to the lowest level with hot water and several cups of bleach (no clothes) and run it through a cycle. Rinse at the ex-large setting to make sure all traces of bleach are gone before doing another load of laundry.
Nov 12, 2009 | GE WDSR2080D Top Load Washer
My GE Profile top load washer won't hold water
Your drain line is too low or has a blocked air gap. Take the drain line out of the drain. Hold it up high and turn the washer on to fill. If it fills and begins agitation,repair the drain line problem.
Sep 08, 2009 | GE Washing Machines
Will fill but not wash or spin
Does the motor run?  Does the water get pumped out at the end of wash cycle or during the rinse cycle or when you turn the dial by hand to the end of a cycle?  If the water gets pumped out then the motor is OK but the clutch is not working.  If the motor is not running then that is the problem.  If the water fills and then nothing happens (the dial does not turn by itself) the timer is bad.  If the timer is bad but you turn it by hand the other actions (wash, rinse, etc. should work indicating no problems with motor and clutch).
May 30, 2009 | GE WBSR3140DW Top Load Washer
Maytag atlantis Top loading washer
it sounds like a bad lid switch.
Apr 07, 2009 | Maytag Washing Machines
GE Profile will not run cycles. Runs water continuously.
OK, i would do a hard reset by unplugging for 2 minutes. if the problem still exists, this is defiantly a malfunctioning relay. it will have to be replaced.
Mar 06, 2009 | GE Profile WPRE6100G Top Load Washer
Washing Machine will not fill with water
It sounds like the water solenoid has gone bad or stuck closed OR timer/control knob has bad set of contacts which control the solenoid.
Jan 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer filled but does not run at all
When the unit completes its filling cycle, a relay will be activated to start the wash cycle. A 10 year old unit probably has dirty/corroded or otherwise malfunctioning relay contacts. This should be repaired by a qualified repairman as high voltages pass through these relays.
Mar 08, 2008 | Kenmore 24902 Top Load Washer
Water continues to fill
you replace 'that'by turning off water going to 'it'remove top of machine,take off hose's on valve,fit them to new valve,with the wireing,do it step by step.buy,eire
Dec 11, 2007 | GE WDSR2080D Top Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
57 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
