Samsung LE32D400E1W Tv. Best Sound Bar for this model
I purchased a Sound Bar to use on this model, but there arent any input sockets on the rear of the set. Solution please.
SOURCE: samsung tv settings
Freeview Built-in Tuner
Picture Mode: Standard
Contrast: 85
Brightness: 53
Sharpness: 25
Colour: 45
Tint: 50/50 (Greyed Out)
Colour Tone: Cool1
Detailed Settings:
Black Adjust: High
Dynamic Contrast: Off
Gamma: 0
Edge Enhancement: On
White Balance:
R-Offset: 17
G-Offset: 15
B-Offset: 11
R-Gain: 7
G-Gain: 14
B-Gain: 30
Backlight: 10
Digital NR (Noise Reduction): Auto
Active Colour: Off (Greyed Out)
DNIe: On
Movie Plus: On
Sound Mode: Music
SRS TX XT: On
Game Mode: Off
Energy Saving: Off
Posted on Jun 03, 2008
  • 46 Answers
SOURCE: No HDMI input socket on Toshiba 'HD Ready' TV
There is an easy way to adapt the cable.
Any good computer shop will have the adaptor.
Take the HDMI cable to them, and tell them you want an adaptor to go to composite signal.
(I know that they're made, many of the graphics cards I use to build computers come with that cable adaptor)
You also might try Best Buy or Radio Shack, but you might not have much luck with them.
Posted on Jan 16, 2009
dsacco86
  • 1077 Answers
SOURCE: Sharp LC 46D85U TV with NO SOUND (but perfect picture)
Sound like the TV has a defective audio board. Opening up the TV would most likely void the warranty.
It's best to take the TV back and exchange it for a new one. Personally, I wouldn't want to be stuck with a defective TV ( that just came out of the box ) that they are going to repair for you.
Posted on Jul 05, 2009
vinnyq
  • 157 Answers
SOURCE: best tv settings for samsung LE40A457
Best is kind of subjective since each person's eyes are different. If you are looking for a bright and vivid picture, you can go to the picture mode and change it to that setting. Usually it is called something like "Vivid" or "Dynamic." Besides that, it is all user preference. Most people prefer to just use the factory default settings.
Posted on Nov 09, 2009
  • 1039 Answers
SOURCE: sir/ma'am i have a
Connect the optical out of the tv to the optical in on the sound bar.
Posted on Sep 01, 2011
Soundbar connection from Phillips TV to a Samsung HD 550 soundbar
The sound bar only needs sound input from the tv so optical cable connection will work fine. HDMI cable will also work fine. Use the one that you have available.
Mar 18, 2017 | Samsung Televison & Video
I hooked up my soundbar using the HDMI out (TV) port from bar to HDMI in port on my Philips TV power is on bar however I can't get any sound out of bar. But just audio cables worked what to do?
OK, If its the Samsung Sound Bar, this item should have 2 HDMI input, 1 3.5mm audio jack input and a digital audio input (fiber optic). Since there are various input, the remote control should have a source button, or it will probably read O/A Input, this is to change thru the inputs from the sound bar. If you connected your TV HDMI output to HDMI 1 from the Sound Bar, then press the source button to reach HDMI 1, maybe it will be display with a different name, like sound 1, or DIGI.1 Give it a shot and let me know in the comment section. Good luck.
Dec 19, 2015 | Samsung HW-H450 2.1 Channel 290 Watt...
Having problems connecting using RCA cables (TV to Sound Bar) - No sound on Sound Bar
I assume by using your phone (cable rca to mini jack) the sounbar functions normal. Next time give more info like tv and soundbar make and model no and what connections are available on both components and if its input or output connections.
On the tv make sure the rca cable (tv to soundbar) is plug into the stereo output of the tv and not in a av input. Some tv's have a mini jack out and not rca. Some have a earphone socket which could also be used.
Some tv's only have a digital or optical output port. Iin basic sound work and can be connected with the following combinations .
Minijack to minijack
Minijack to rca
rca to rca
digital to digital
optical to optical
Oct 26, 2015 | RCA Televison & Video
Connecting sound bar to proscan TV
Proscan has released hundreds of models of televisions over more than two decades, so I can't be specific without more information. There are also hundreds of different sound bars on the market. The answer given should apply to all situations:
Ideally, the sound bar should be connected to the television using one of the methods (in order of preference):
  • Optical cable output from the television into the optical cable input to the sound bar; (best)
  • SPD/IF coaxial output from the television into the SPD/IF coaxial input to the sound bar; (really just as good)
  • RCA R/L outputs into RCA R/L inputs to the sound bar. (not nearly as good as either of the above)
Jun 03, 2014 | Televison & Video
Connecting sharp tv to samsung sound bar
don't you mean sound bar to tv?
your tv has an input and output for audio and video,find the audio output and connect the sound bar!
Jan 07, 2014 | Samsung HW-D450 Sound Bar
Cannot figure out how to connect my new sound bar to my older TV
If your TV has audio output connectors (RCA type), you can use them as a source of input to your soundbar. This should be apparent by reviewing the installation instructions that accompanied your soundbar.
Nov 30, 2013 | Mitsubishi WD-62527 62 in. LCD Projection...
I just purchased a new hisense 40 inch smart led television but I seem to have misplaced (thrown away) the manual. I am wanting to add a sound bar but I am unsure of what type to buy because I am unsure of...
its a smart tv it will have an optical plug in. I have a samsung sound bar and a 50" LG the samsung has a optical input on it. look on the back of the sound bar you will see two spots that have a rubber flap on it and say optical on it
Feb 26, 2013 | Televison & Video
I am attempting to attach a Samsung Sound Bar to my 42 inch LCD 1080P Polaroid Television. I can not seem to get sound from the Television connected to the Sound Bar. Thoughts?
Connect the audio out RCA jacks (white and red) on the TV to the white and red RCA input jacks on the sound bar for analog stereo sound or connect the black digital audio output jack (typically optical) on the TV rear panel to the sound bar's optical digital audio input jack for surround sound. Use an optical cable. There may be some user settings on the TV for audio.
Aug 12, 2010 | Polaroid FLM-4201 42 in. LCD Television
Connecting Bravia to PC using HDMI cable
You did okay but the phono sockets are not for Computer/TV use. Phono sockets should be checked int the manual on why they're there. If you have connected the Bravia to your computer, using the appropriate cable, then you should also purchase or request from the retailer where you purchased the TV a cable that has stereo phono plugs and, you didn't say what size phono sockets they are but I presume they are 3.5 mm. So, if the TV has 3.5 mm sockets, you purchase a cable with stereo 3.5 mm plugs. This is adequate for the stereo wav sound coming from the computer and going into the TV. Remember, having 2 Phono inputs on the TV doesn't mean anything. The TV could have a number of video inputs too, ATD AVT, AV, COMPONENT1, COMPONENT2, HDMI1, HDMI2, HDMI3, etc. each have it's respective sound inputs for AV, S-VIDEO, DVD, Blue-Ray, etc. But for the computer there may be a different type of socket for it's sound inputs, normally it is the old phono sockets. Seek help from the retailer or else you could cook the circuitry of the TV's sound system.
Sep 18, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Electro Med Services...
