Hi,I've got a samsung w80v3 washing mashine and the water keeps on filling up,it overflows,what is the cause of that
2 Suggested Answers
  • 46 Answers
SOURCE: Overflowing washing machine
check the pressure switch . its circluar in shape with 6/8 wires attached, and a small nipple with a 10mm pipe attached. as the water rises in the drum air is pushed up thru this pipe which when working ok , eventually pushes against a switch .hence its name. so, if there is damage to this pipe( maybe rubbing against the drum) the passage of air escapes before reaching the switch. if the pipe is ok then check the switch by blowing up the pipe (with the power off ) and u should hear a small click inside the switch. if not replace
Posted on Feb 07, 2008
Mashine fills with water
check the program dial or settings. Put the machine off. then the water slot should close. If it does not close it is defect and you should ask a tech to replace it, or buy a new machine.
Mar 24, 2015 | Washing Machines
Wshing machine keeps filling with water
You probably have a stuck fill valve. This is the part where the hot and cold water hoses connect. Just to be sure unplug the machine and if it still fills Remove and replace the fill valve assembly. Don't forget to unplug the machine and turn off both the hot and cold water supply valves. This is a rather simple repair.
Aug 07, 2014 | Russell Hobbs RH1042 Frontload Washing...
Washing machine not filling
yes your problem is up the line somewhere. you have to have water coming out of the fill line when the washing machine is unhooked.
you will have to locate the valve to turn on the water.
good luck
Jul 05, 2012 | Russell Hobbs RH1042 Frontload Washing...
I get an error 1E on my samsung wa7584c1 washing machine. According to user guide it is a problem with overflow. How do I fix it. The mashine doesnt want to let water in
Hi you put your washing machine problem under as a shoe problem. If you change the problem to a more suitable category then the problem can be answered by an expert in that category.
Mar 23, 2011 | Skechers YouthTween Twinkletoes Pixie Dust...
Water is no fill in mashine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 31, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Water overflow error on machine E1
The error code E1 : washing machine has exceeded a check time for fill, heat or empty.
Common causes for this are fill and empty problems, heater fault (or the wiring to it broken), water pump open circuit (although that would stop the water draining too) Pressure chamber blocked or pressure tubing pipe looped below the pressure bottle, or a sticking eco ball in the sump hose (sludge and grease build up)
This error code is generic and vey common.Try getting checked the internal wiring damage by professionals.I certainly hope the problem lies there.
Thanks for contacting fixya.com
Nov 12, 2009 | Samsung WF337AA Front Load Washer
Model no wa80b3 samsung washing mashine
My washing machine is Samsung Top loading Model WA80B3, the problem is that the water inlet valve is continuously working all the time during the washing cycle and it does not stop automatically, so I have to run additional drying cycle after washing cycle and after closing the water supply manually
May 02, 2009 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
