Question about Whirlpool GU2400XTP Built-in Dishwasher
Clean light blinks
My dishwasher doesn't run an entire wash cycle it only goes a little while then quits and the clean light blinks. Reset it and it starts at the rinse cycle 15 min left. I've checked water level, door latch, and it seems as though the heater works as the dishwasher is warm inside. What else can I do or try? Maybe the heater isn't warm enough how do I test that? Please help! 5 kids=lots of dirty dishes Thanks
  • laurie tuttle Jun 11, 2007
    I dont have an energy saver button
    I am wondering if you have any other ideas for my problem that didn't seem to work it did the same thing
  • 87 Answers
Raise the temperature of your water supply. To reset computer open door,within 3 seconds hit hi-temp scrub then energy saver then repeat this. Close door and latch, push cancell button.
Posted on Jun 10, 2007
I have a whirlpool gold quiet partner III Black dishwasher. All of a sudden it stopped working. I push the accusense button and start the cycle for washing, it looks like everything is working normally, I...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry . Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher started up....didn't notice it quit running overnight...dishes seem only half clean. The "clean" green light is blinking. Tried opening and closing and then re-starting it. Can't get...
Greetings,
there is a temp related problem..this could be in the wash cycle not letting water get hot enough or a heater failure....remove your kickplate..there is a tech sheet..it explains how to reset this blinking light.....Bruce Denton
Jan 18, 2011 | Whirlpool Dishwashers
''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Apr 01, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Blinking Clean Light
  • Close dishwasher door
  • press "Hi-Temp Wash"
  • press "Energy Saver Dry"
run the 'normal' cycle without the hi temp feature
Nov 16, 2008 | KitchenAid 24 in. KUDI01FL - Multiple...
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Kenmore dishwasher wont start blinking clean light
today January 9, 2009...blinking clean light, kenmore dishwasher would not run,,,the solution on Fixya ..."keep hitting normal -heated wash-normal -heated wash buttons over and over...unlocked the blinking green light problem. Dishwasher is running as I type this....will post again when I see the results of another washing tomorrow. H.T. Las Vegas Nv
Jan 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher starts then stops
My (KUDI01TJ)Dishwasher did the same thing.
I Pressed start, it acted like it was starting and then turned off.
FIX:
I started the rapid advance service diagnostic feature:
1.Close dishwasher door
2.press "Hi-Temp Wash"
3.press "Energy Saver Dry"
4.press "Hi-Temp Wash"
5.press "Energy Saver Dry"
This started the diagnostics and the dishwasher went through each cycle.
After this, my dishwasher worked fine.
I think the controller must have got in some wierd mode and unpluging the washer would not clear it out but running the
diagnostics cleared it.
Hope this works for you
-Steve Payne
Jun 13, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
May 11, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
303 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
