Question about Philips Audio Players & Recorders
Philips HTS3520/12 Home Cinema System rear speakers not working
Please grand me a solution
SOURCE: Philips HTS3357/05 home cinema system
Same problem here with HTS3357/12... This system is also REALLY **** from an electronics point of view (I have checked inside and I know what I am talking about), that's the reason why the sound is so horrible on the front and rear speaker.It is as simple as a SCAM.
No more Philips for me.
Posted on Mar 25, 2008
SOURCE: samsung ht-z310 home cinema no sound rear speakers
I seen the same thing when I first opened mine except my "center" speaker wan't working. It had to do with the "Mode" it was in. The Mode button at the botoom of the remote changes the speaker configuration.
There is also an option in the setup that allows you to turn on/off speakers for the system, all of mine were either Present or Small which enables them to work.
Posted on Aug 11, 2008
  • 7 Answers
SOURCE: no sound through my lg home cinema system when watching tiv
fiirst of all you should buy a converter..........which has a multiple use
Posted on Mar 04, 2009
SOURCE: Just bought a Philips home theatre system HTS3544 low sound?
You may also need to change the speaker set up. Go to DISC setting (one of the top selections on the remote) make sure you have no Disc in the DVD player. When in this mode press setup on the remote. On this menu you will have a option to adjust the speaker volume.
I had to increase my speaker volumes to get better sound. This setting is not accessible if you try to do the set up in other than DISC setting. Be sure to check the SURROUND setting. The SURROUND button on the remote will toggle between stereo and surround as stated in a previous post.
ST
Posted on Mar 27, 2009
SOURCE: Sony BDV 370 home cinema system and Sony 40hx703
You need to use a HDMI 1.4 Cable and it needs to be connected to to an HDMI socket with an ARC (audio return channel). Alternatively you can connect using an optical cable (TOSLINK).
Posted on Sep 12, 2010
No rear sound in philips home cinema
Sometimes the rear sound or other speakers can accidentally get switched off, when changing sound modes. Check that this has not happened. Most amps have test modes that send out beeps or some other form of noise to the speakers. Try that and see if they are working.
If you can't find anything that has switched them off and there are no beeps on the channel. It could be that the amp that controls the rear channels has failed.
May 16, 2016 | Philips Audio Players & Recorders
Philips LX8500W rear wireless speakers don't get enough signal and they are not working properly.
if there wireless you need to make sure the two signal strengths are connecting to each other for that there is a testing kit you can get but its very expansive. If these are new and you installed these your self check your main raido and make sure all wires are hooked up properly, it could be the main box giving an issue with the signal.
Nov 26, 2014 | Philips Home Cinema system DivX LX8500...
Philips: HTS3520 doesn't use surround from HDMI feed from SKY
Check your connections and the settings in the menu.
Good luck
Mar 11, 2014 | Philips HTS3520/05 5.1 ch Home Cinema...
Home Cinema Wireless Kit
It may be favorable to simply purchase a rear wireless speaker system all by itself and use the existing system for surround sound applications. Monoprice . Com has some units are a good price.
Mar 05, 2014 | Panasonic Audio Players & Recorders
Philips LX600
my decoder is not on when i give power supply
Sep 06, 2009 | Philips Home Cinema Amp + Speaker system...
No sound from our Sony Wireless Home Cinema System
Basic checks first. Have you checked they are connected properly? Maybe used a different cable to check whether the rear cables are faulty? You may just have turned your system to 2.1 surrououn sound by accident or be playing a format that only supports 2.1. Check that in the system menu under dec. mode that if it is set to AFD STD that you are playing a DVD which shows can support 5.1 on the back of its cover. Also try running the setup manually and choosing your speaker configuration. Hope this helps.
Jan 10, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
Can't get tv sound from home cinema system speakers
you need an optical cable going from the TV to the home cinema for an audio output, it worked for, had the same problem!!
Dec 04, 2008 | Panasonic Home Theater System System
Philipe home cinema - No Disk Error
Hi, the best thing to do is to reset the device back to factoy settings, how to do that is mostly written in your manual. Also unplugging the power for 5 to 10 minutes might help.
Aug 07, 2008 | GE MA90559 Rear Speaker
Nov 20, 2007 | Philips Home Audio&Video: HOME THEATER IN...
20 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
