Question about Hardware & Accessories
NEED INSTRUCTIONS FOR LIGHTING - Hardware & Accessories
  • 5,245 Answers
1) Copy following link for setting timers.
http://waterheatertimer.org/How-to-set-timers.html
2) Add a comment and describe product in detail, including use and application.
Posted on Dec 10, 2012
Replacing halo and hid lighting in an after market headlight
    Aftermarket Projector Headlight How To Replace HID ...
    store.ijdmtoy.com/Aftermarket-Projector-Headlight-HID-Installation.../5...
    Here are some quick tips and instructions on how to install an aftermarket HIDConversion kit into an aftermarket projector headlight assembly. ... Aftermarket projector headlights look almost like an OEM headlight with the exception of the wiring and design. You would need to remove ... images for Replacing halo and hid lighting in an ...
Nov 24, 2015 | 2000 Jeep Grand Cherokee
I need directions on how to program my Utilitech 15-amp 6-outlet digital lighting timer
If possible, return to the place of purchase and find out whether they will make a copy of the instructions for you.
Dec 10, 2014 | Hardware & Accessories
Can not read instructions they are too small for me to see
Ask a friend with better eyesight to read them to you or buy some reading glasses or a magnifier. Use bright lighting that helps too.
Mar 15, 2014 | Home
I have replaced Decora dimmers with the Adorne dimmers not the lighting is emmiting a high frequency noise in the mid dimming range. The lighting is 20/35 watt halogen lamps. Why and how can I fix this?
They design dimmers for either incondescent lighting or fan motor controls. Always check which one you purchased. You can't use the motor control dimmer on lighting and vice versa. Even if you purchased the correct dimmer remember that it is for incondescent lighting only (ordinary light bulb). Incondescent lights have a resistance whereas fluorescent has a capacitance and an inductance. Halogen lamps may have a capacitance and an induction too and are creating havoc with the mosfet transistor inside the dimmer. This can also cause the dimmer to fail. Read the instructions on the dimmer to see what type of lighting is allowed.
Oct 25, 2013 | Legrand Adorne Control Box with Paddle...
How can I properly determine the amount of watts per gallon of lighting I need for my aquarium?
How many watts you need depends on the type of plants and the volume of the tank. Here is an excerpt from an article that will help you determine proper wattage.
Instructions
Identify the species of plants you have in your tank or that you plan to put in your tank and how much light that species needs. Each species of plant will have an optimal lighting requirements, from low light to bright light. To determine the plant species, compare photos on the Aquarium Plants Photos and Profiles page of the Aqua Hobby website, or take samples of the aquatic plants to your local aquarium store for identification.
Write down how much lighting each of the plant species in your tank needs. Give each plant a rating of low, medium or bright. The books "The Complete Fishkeeper" and "Freshwater Aquariums for Dummies," as well as your local fish store, are good sources of information for this.
Review your list and determine what type of plant dominates your tank. For example, if you have mostly plants that need bright light, then use a bright-light formula. If you have an equal mix of plant lighting needs, then use a medium-light formula.
Calculate a range of watts of lighting you need for your tank with one of the following formulas, depending on the amount of light you determined you needed for your plants. For low light, multiply one and two by the number of gallons. For medium light, multiply two and three by the number of gallons. For bright light, calculate three and five by the number of gallons. For example, for a 20-gallon tank with plants that need medium light, you would get a range of 40 to 60 watts (2 x 20 = 40 and 3 x 20 = 60).
Read more: How to Determine Watts Per Gallon for Aquarium Lighting ' eHow.com http://www.ehow.com/how_8014286_determine-per-gallon-aquarium-lighting.html#ixzz23KB8HErA
Aug 14, 2012 | Fish
I need programming instructions for my intermatic outdoor lighting timer
Hi Jeanne,
Here's a page with detailed instructions and pictures - that will guide you through programming. I hope this helps & good luck!
Nov 09, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have no instructions for re-lighting my furnace's pilot light. Can you help?
Instructions for lighting the pilot can be found on page 10 of this Installation Manual.
Here is link on How to Light the Pilot on a Water Heater. I realize this is not a water heater you are working on, but the setup is very similiar the link has a couple of videos that you might find helpful. :-)
Apr 23, 2010 | Williams 3003622 Ceramic Wall Mounted...
4 Blinking Lights no screen
Please confirm that the model number is KV-27FS100 and I'll provide the parts and instructions.
Thanks,
Dan
Oct 14, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Vulcan space heater lighting instructions
turn the round knob to left "the ignitation" spot, then push down the button to light the pilot.
May 07, 2008 | Ovens
Hardware & Accessories Logo
15 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
