Question about Zanussi WJS1265W Front Load Washer/Dryer
Heating element Hi, my washing machine has stopped heating the water. How do i acces the element so that I can test / replace it please.
    Sergeant:
  • 236 Answers
You have to remove the back half of the case by removing the lid, screws at the sides (bottom) and from the bottom rear. then from the top centre. slide the rear case backwards by seperating the hose bracket and the element is at the bottom of the outer tub.
Posted on Jun 11, 2007
Washing machine not heating
PLEASE CHECK THE WATER COMING TO THE FRONT WASH FRONT LOAD WASHER DONT HEAT THE WATER IT AS A HOT AND COLD WATER VALVE CHECK WATER VALVE
May 02, 2014 | Hotpoint WMA50 Front Load Washer
Washeing machine not heating up
It sounds like either the cable's have rusted off, fallen off the water heater element. Or the Water heater element has failed.
Watch this link to get the repairs done
How to replace washing machine element on Hotpoint washer
Mar 04, 2014 | Hotpoint Washing Machines
Ariston AQXXF 129 Error code F 05 - What is this?
see this causes and fix it. God bless you
F05 Water temperature sensor error If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Replace failed component.
Sep 30, 2012 | Ariston Technologies Washing Machines
How much for the repair manual and trouble shooting guide for my W6021 asko asea front loader, it will not heat, but the heater is good!
Hi.
The thermistor is located near to the heating element(pt.40) and motor(pt.6). The thermistor/holder assembly is part 31/31in picture below:
To get the full part manual click here. The assembly is at pages 4/5.
Here the part.
To test the thermistor remove it from circuit and read Ohms at its terminals. If the thermistor is good it must read zero or very low impedance. If it reads open, then it is broken.
If this solution was helpful, then please do not forget to accept the solution. Your feedback is important to us.
Regards.
Sep 14, 2010 | Asko W6021 Front Load Washer
On the normal cycle of my Duet front load washer at 37 minutes the machine stops and flashes F5. I push the reset button then the start button and the machine works fine after that.
HI. This is a Water temperature sensor error.
Potential Causes
Replace failed component.(Most common issue will be a failed water temp sensor)
Jul 25, 2009 | GE WBVH6240F Front Load Washer
Washing machine doesnt heat the water
Most washing machines do not heat water, they merely let the hot water into the wash tub that comes from your house hot water heater.... when selecting warm, hot and cold water will be mixed together to get warm or when selecting cold.. only the cold water is allowed into the wash tub.. Please provide brand and model number of machine so I can tailor a reply toward your specific washer...
Sep 21, 2008 | Washing Machines
Washer dryer not heating up
both the 'wash' & the 'dryer' have their own heating elements, If the 'wash' completes its full cycle including 'spin', then I suspect this heat element is ok.Re the dryer, most likely the heat element circuit is 'open circuit' somewhere, could be  the element, thermal fuse, thermostat, or a wire burned out
Oct 23, 2007 | Hotpoint Aquarius WD640 Front Load...
Indesit w113 washing machine
check heating element (rear of drum at the bottom) for open circuit, replace if needed, occasionally the timer will start to click round continuously, indicating the machine has a fault, the machine shuts down waiting for the water to heat up, elements available at most appliance shops but you may need to order specially?
Sep 01, 2007 | Washing Machines
Won't heat water anymore - only washes in cold water
u need to take the back half panel off once off u will see the two thermostats and the heater element you can test the element by undoing the wires and getting an old wire with plug on 1 end and bear wires on the other place corrisponding wires to were that wire had come of turn plug on and if it is working it will heat up straight away which means the thermostats need replacing if it doesnt then the element needs replacing
Feb 07, 2007 | Zanussi FLA1001W Front Load Washer
Water won't stop heating up
You should replace the thermostat (it doesn't stop current to the heating element in the temp it should). Good luck!
Oct 15, 2006 | Hoover AL130 Front Load Washer
Zanussi WJS1265W Front Load Washer/Dryer Logo
118 people viewed this question
Top Zanussi Washing Machines Experts
shaun taylor
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
