Question about Whirlpool LHW0050PQ Front Load Washer
Whirlpool front load washer
Washer stops and water is still in it. I tried unplugging for minutes but that did not work.
  • abz144 Apr 08, 2009
    Water does not drain. Filter is clean, didn't find anything obstructing drain tubes or pump. Removed pump, it ran ok on bench. Reinstalled pump, still water won't drain. Thanks.
  • 121 Answers
Check water-pump filter.or pump is broken.
Posted on Feb 16, 2009
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
Whirlpool front load washer model WFW9050XW00 - Machine stopped still loaded and with door locked. I was able to unlock and remove clothes leaving water and heavy suds. Tried running drain-spin and...
Your pump is jammed with a blockage, remove the filter and check the pump behind it is revolving, usually a hair grip or button in there...remember the washer is full of water so you will have a lot of water coming out
Sep 05, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer Model# LHW0050PQ3 Which board do I need?
Sounds like possibly a bad control board.
Try to unplug your washer for 5 minutes then plug it in and run a load and see if it still does it.If not, you will need to replace the main control board.
May 11, 2012 | Whirlpool LHW0050PQ Front Load Washer
In the middle of a load my washer will stop and starts flashing F23? It is a whirlpool duet steam.
Hi, F23 means that there is a fault in the heating circuit and the heater is not working This fault is triggered if the water fails to rise by 30C or 86F in the first 8 minutes of the heating process.
1. Unplug washer or disconnect power.
2. Check the connections to water heater.
3. Check resistance and continuity of the heating element.
4. Check the water temperature sensor and connections to it.
5. Check the water temperature sensor and connection to it.
Oct 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Had to stop my whirlpool duet sport front load washer to add a garment, pressed pause, now it will not resume, is there a reset. i turned it off, unplugged, etc. has power but will not continue the cycle...
Try unplugging for 30 minutes, then try to start again. If this doesn't work you probably have a contol board or door lock problem. Good Luck, Appliance Specialists
Feb 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F21 Whirlpool duet washer, removed front panel unclogged restarted and still f21? Tech came in and had no idea said he smelled something burning, must of been his imagination.
ohh, duets are such a treat.
If the drain time exceeds eight minutes, “F21” will be displayed,
the water valves will turn off and the pump will stop running.
Press PAUSE/CANCEL to drain the machine. The display will be
cleared and the machine will turn off after a maximum of eight
minutes.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
this is what Whirlpool says, but we have found that this doesnt always work.
Nov 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet front load washing machine stops in mid cycle
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
1. Check the drain hose and make sure it is not plugged or kinked.
3. Check the electrical connections at the pump and make sure the pump is running.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer not working
Okay...try unplugging the washer for AT LEAST 30 minutes. This will often cure momentary glitches with the washer computer. After the washer has been reset, attempt the start a load and let me know if it functions normally. If it doesn't, let me know what the front panel display reads.
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer problem
Our machine was giving the HF code at 37 min after over filling with water. I unplugged the machine, popped the top (took the 3 torx screws off the back) pulled the small hose off the pressure switch sensor (round sensor on the upper back right of the machine) and blew it out just by mouth. It obviously cleared some junk. It works fine now. (also unplugged the 6 wires on the sensor, turned it around and blew on that and heard it clicking, so I knew that was ok.) Hope this helps someone.
Oct 14, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
167 people viewed this question
Dan Webster
Dan Webster
Sal De
