Question about Syntax SV266A SKA KT266A Motherboard
I have a selfbuilt Syntax MB computer. No beep on start up Screen black
Suddenly, I turn it on and I get no beep.
Screen stays black. No POST.
I thought the radeon 7000 video card had gone bad.
Changed it with one from my other computer.
Still blank screen. Fans go on, neon on HD goes on but not the neon on the floppy.
Amd CPU Phynix Bios 2003. i Meg menory, XP os.
Suggestions?
  • 3 more comments
  • dick cory Dec 10, 2012
    Brian thank you for your response. However, your solution is for after the computer boots and goes thru POST. I thought the PS went bad and have replaced it. same problem. I turn it on but just black screen and no boot. Maybe cpu is bad? or bios? Any suggestions would be appreciated. ****
  • Brian Sullivan
    Brian Sullivan Dec 10, 2012
    Is a 40 pin flat ribbon IDE ? check the data and power leads from motherboard to hard drive for secure dust free connections check ram modules are clean and dust free secure seatings
  • Brian Sullivan
    Brian Sullivan Dec 11, 2012
    you rebuilt your computer i would be going over every connection from motherboard to hard drive power and data leads and connection points
  • Brian Sullivan
    , it helps to start with potential environmental causes first, such as a problem with the AC power being supplied to the computer. From there, a good rule of thumb is to simply start disconnecting items from the computer one at a time until just the CPU, motherboard, RAM and power supply remain connected, and then swapping in known good replacements for them. Inspect the inside of the computer for any signs of burned components, such as capacitors or integrated circuits that are deformed or discolored, and replace the affected expansion card, motherboard, drive or other device if damage is located. Verify a proper connection for each expansion card, cable, drive and stick of RAM by disconnecting and reconnecting each item without removing it from the system. This can sometimes clean corroded or loose contacts and solve minor problems that prevent the system from booting.
  • Brian Sullivan
    the bios chip might have gone bad
  • Syntax Master
  • 27,725 Answers
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer Hope this helps.
Posted on Dec 10, 2012
  • 1 more comment
    Mark, the video card is an ATI Radeon 7000AGP card from 2003 (not a 7600). I beleive before PCI-express existed. My problem is not the video card because I have a sister computer identical except for HD and I swapped the functioning v-card from A comp to comp B. same problem.no bios boot or POST.. Per someone's suggestion I replaced the ps with an identical spare that I kept for an emergency. No help. Anyone else have another suggestion?
  • dick cory Dec 11, 2012
    Brian, I find it best to disconect all unnecessary components.Which I have. I took out the memory chips used an eraser to clean contacts.Still cant get the initial bios beep. Still dead except fans and neons. Dick
3 Suggested Answers
SOURCE: bois problems????
i tried repairing it wouldnt complete done complete erase of hd and trying new xp installation it goes so far then stops
Posted on May 07, 2008
  • 41 Answers
SOURCE: Hey,im looking for the same bios for Syntax SV400.
hi
try to download the drivers from this link,
http://members.driverguide.com/driver/detail.php?driverid=350127
you have to register first before you can download.. it's free..
Posted on May 09, 2009
Computer will turn on but will not boot up
Dear,
Did this situation come with any beep sound. Because, most of the time, in this situation; the computer beeps. Here are some codes. Check if any of these condition apply to your system.
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
best of luck!
Mar 07, 2012 | Gateway 510XL (2800446) PC Desktop
I have a compaq r4000 cto. I just replaced the system board with a used board. When I first started it up I got a black screen and three beeps which after a few tries became a black screen and four...
It's unlikely that you have 2 or more defective memory modules. Remove all cards such as video, modem, etc. Also disconnect all drives (hard drive, CD, DVD). Try booting with one memory module at a time. If still a no go then I would suspect the motherboard.
Feb 20, 2011 | HP Compaq Presario R4000 Notebook
Acer TravelMate 4150LCi
beep sound can causes from Keyboard
boot menu shown can cause from HDD
MB can cause both -> I/O (Input/Output) controller problem
Try to plug other HDD into u're laptop, if detected the problem is from HDD but if it's not it from MB
Dec 12, 2007 | Acer TravelMate 4150LCi Notebook
I screwed up the MB BIOS and CMOS
well we have to reset your BIOS. you have to remove the CR2032 flat battery(the silver and circle shape thing) on the motherboard and put it back just exactly before you removed it then you would be just fine that if the problem is on the BIOS setup..i need to know how many beeps you can hear when you power on the PC.?
Dec 11, 2007 | Computers & Internet
Bios Beeps and no boot
Remove and reinsert the dimms
reseat the video card also
put everything back and try agailn
If this dont work reseat the cpu and repeat steps above
If the above fails to fix
If it will boot into safe mode
and use the standard vga as
you did before and restart
and try to reinstall the drivers
You are sure you installed the rilght
drivers for your OS
It may be that the card is not compatible
wilth your mobo.Try checking compatability list
for your OD
Nov 16, 2007 | ASUS A8N-SLI Deluxe Motherboard
HP desktop wont start up
Hi, depends on the beep sequence, it could either ba a bad memory or a bad video card. By being bad does not necessarily mean defective but could possibly be just loose. Try to open the casing/cover and reseat/push back into place the video card (if it is not built-in) and/or the memory. It is possible that they were jarred loose while in transit. Pls make sure the unit is unplugged before doing this. BTW, being new, you might void your warranty if you open the casing, pls check your warranty card. Hope this works out for you. Please let me know how things turn up. Regards
Apr 12, 2007 | HP Compaq dc5100 PC Desktop
Syntax SV266A SKA KT266A Motherboard Logo
76 people viewed this question
Top Syntax Computers & Internet Experts
John Anderson
John Anderson
T-Comtech Repairs
T-Comtech Repairs
Roy May
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
