Epson sx125 has a paper feed problem. what can I do to solve this
    Habit-Forming:
  • 121 Answers
Below where you feed in your papar, see if you can reach a paper feeder, if the feeder is dusty it might not allow it to pick, clean the feeder surface with a wet hanky and make sure its properly clean without any drop of liquid on it, leave it for a while to dry off, that should help...
please rate this
Posted on Dec 10, 2012
romeo1790305
  • 17 Answers
SOURCE: Epson cx3800 paper feed problem
no you might have a paper jam somewere and mabe you ink rollers are dry you might have to tell the printer to to a pre test and clean and if there is a paper jam it should be a slot on the back by the roller should be a tap that shows the tollers look for a pice of paper jammed somewere in the roller you migh have to take the paper out to inspct it for a paper jam and if none mabe the print heads are dry and it dosent feed the paper then could be it ok clean the print heads tell the printer to to a roller clean and then after that if no paper jam no were try printing a page take all the paper out and feed it manually and if it prints then some printer want feed if you have filled the paper tray up try putting less and then try
Posted on Jan 29, 2009
SOURCE: epson r2400 won't feed paper
I had the same problem, then found these instructions for cleaning the feed roller: http://www.museofineart.com/files/RollerCleaningProcedureRev2.pdf I used the paper towel method and it's working fine now with no issues.
Posted on Mar 06, 2009
SOURCE: paper will not feed through - epson DX4000 printer/scanner
Did you check the thickness? My printer won't feed paper that's to think or thick properly it sould say in the manual what thickness of paper you should use.
Posted on Mar 24, 2009
aicaxz
  • 511 Answers
SOURCE: epson c90 paper feed problem
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
Posted on May 30, 2009
  • 526 Answers
SOURCE: Epson R340 does not feed paper or feeds it crooked
two things I would do, first carefully flip the printer upside down, (anything that looks like it can flap open, tape it well), and jiggle it slightly and see if anything falls out.
second, i would clean the pickup roller with an alcoholic pad or swab, if its not easily accessible, you will probably need to take the upper an middle casing off, which I dont recommend.
thanks adi
Posted on Jan 02, 2010
My Epson R230x printer get paper james and not feed paper, how can I solve or repair this problem
i want to know. printer back side some gape i see. but i don't know which work do in this back side.
Nov 04, 2012 | Epson STYLUS R230 InkJet Photo Printer
Preprinted 4 part paper crunching up when being printed in epson lq680 printer
Mustafa:
The printer is not meant to use multi-copy carbon invoices. The cause of your problem is the double-feed prevention pad below the paper pickup roller. When the first form is fed, the double feed prevention pad will stop multiple paper feeds. With multi-page carbons, the paper feed roller is trying to feed the form, and is pulling the top page of the form into the feed rollers while the double-feed prevention pad is stopping the bottom form from feeding and the top and bottom pages are sliding because of the carbon paper between the sheets. The only solution that I know of is to buy a printer with a tractor feed and pre-printed fan-fold forms with tractor feed strips on the sides of the forms.
Oct 13, 2012 | Epson LQ 680 Matrix Printer
Printer will not feed card stock
Sorry. I have not solved this problem and I cannot afford to pay anything for your services.
May 01, 2009 | Epson Office Equipment & Supplies
Paper will not feed through - epson DX4000 printer/scanner
Mar 24, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Paper feed problem on Epson C87
In view of vk_malik's lack of interest in this problem, I think we may declare it "solved by poster"
Nov 24, 2008 | Lexmark X644e All-In-One Laser Printer
Epson r2400 won't feed paper
Oct 20, 2008 | Epson Stylus Photo R2400 InkJet Printer
204 people viewed this question
k24674
