Question about Samsung SMH1622W
Makes a really loud buzzing noise during operation
First couple of months didn't make any strange noises, very quiet operation. Started making a buzzing noise during operation that now has gotten very loud. When running the microwave for peroids over 3 minutes, the noise will back off and by 5 minutes the product sounds normal again. Build date of Dec 2011. Seems to be coming from behind the keypad area, likely main control board.
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Unit uses a Magnetron and likely a power board called an inverter to run it. Someone would have to open the unit in a way where they might pinpoint where the sound is coming from and then take action--does not of course sound normal or good to me.
Posted on Dec 10, 2012
ginko
  • 19396 Answers
SOURCE: GE Spacemaker XL1800 Microwave
You need to take apart the oven and fix the turntable gear, then reassemble it, it is not a difficult job. Always work with power unplugged.
Posted on Aug 04, 2008
  • 251 Answers
SOURCE: During cooking, the microwave will work for about
sounds like the cooling fan has came adrift or stopped working , this will cause the magnatron ( the microwave generator ) to overheat tripping the over temperature stat ,so fix the cooling , but be sooooooooooooo carefull in there , microwaves + really high voltages , not really a job for a non electrician/microwave tech
Posted on Oct 20, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: UPDATE: GE Spacemaker XL1800 Microwave
JVM1850BD002 is a correct model number. This is a GE made by Samsung. It sounds like the motor or coupler is bad. More likely the motor. If you grab the motor shaft and try to gently turn it, it may grind or slip a lot. That's a sign of a bad motor. If the coupler is bad, it will be cracked or broken, causing it to slip on the motor shaft or the turntable itself. The coupler is reference 40, and the motor is reference 43 on this handy exploded view drawing: http://genet.geappliances.com/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00016500/00016593.p01.pdf (copy & paste whole URL) Here is the GE part price info on these two parts: DESCRIPTION DRAWING PART NO. PRICE MOTOR-SYNCHRONOUS 43 WB26X10038 $46.00 COUPLER 40 WB06X10144 $8.75 If the motor is bad, you might be able to find the Samsung part number printed on the motor label and look it up at http://www.samsungparts.com They often have parts for far less than the expensive GE parts.
Posted on Dec 04, 2006
cactus bob
  • 267 Answers
SOURCE: 3 years old - LOUD couple pops, no longer heats but all else works
SHORTED MAGNTRON new microwave time !
Posted on Jan 24, 2009
  • 338 Answers
SOURCE: vibration
Need a new magnetron
Posted on Sep 03, 2009
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Microwave occasional loud buzz
make this test and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Nov 14, 2013 | Jenn-Air JMV8208AAS Microwave Oven
GE microwave occasionally buzzes loudly.
Nov 14, 2013 | Microwave Ovens
Buzzing noise
follow this steps and fix it. God bless you
Oct 23, 2013 | Panasonic Microwave Ovens
Sharp sound bar buzzing
test this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2hVe8AHvJ
Oct 12, 2013 | Microwave Ovens
Buzzing noise
follow this instruction and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2ZYUSVYSH
Jul 19, 2013 | Morphy Richards AM925EF Microwave Oven
Panasonic Microwave NN-C980-B buzzing noise but it still works.
All:
I have a 2003 Sears Ultra Wave microwave 721.63682300 with a similar problem. A few months ago it started giving off short buzzes when turned on. That stopped but then I noticed that everything took twice as long to heat up. After quite a bit of teardown&inspection I found a circuit break in the inverter board leading to ZD704 diode (pictured). I will now try to find a replacement diode to see if replacing will fix it. Thanks for your postings.
Feb 15, 2009 | Panasonic NN-C980 Convection/Microwave...
Makes a loud buzzing noise and does not get hot
Have seen this many times.
Sounds like a bad CAP since a bad diode would blow the fuse and a bad mag would likely do the same thing.
Since yours is making the loud 60hz buzz you need to replace the capacator that will likely fix the problem. A $10 fix
Jan 06, 2009 | Kenmore 62622 Microwave Oven
Viking Micro noise
The noise is probably from the high-voltage transformer. When it is overloaded, the excess magnetic field it produces vibrates its wire coils. Odd that it only happens for a brief time. It is either defective itself (in which case it may go a long time) or it is getting overloaded by the magnatron/capacitor/diode on its output (in which case it will get worse shortly)
Hope Ya Fix it
Jan 08, 2008 | Microwave Ovens
Mwave made loud buzzing noise then didn't heat up anymore
When there's a loud buzz like that, it does not heat, and does not blow the fuse, it is usually a defective magnetron. Did it sound something like someone making a "gurgling" sound into a coffee cup? I think this has a a one-year warranty, with n five-year warranty covering the magnetron. You can find a local Amana-authorized servicer here: http://amana.com/amana/jsp/portalhttp.do?cs=0&BV_UseBVCookie=Yes&NextPage=7
Mar 03, 2007 | Amana AMV1162 Microwave Oven
Samsung SMH1622W Logo
519 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
