Question about Apple iPod nano
Ipod Nano doesnt turn on AT ALL
I pressed every button a million times, plugging it into the computer and nothing appears. its just blank. got it a couple weeks ago, I never dropped it. the only thing i can think of is when i held with one wet hand and that was 2 weeks ago
  • David Morrison
    David Morrison Mar 13, 2009
    ipod worked fine last night, didn't shut it down, woke up this morning, ipod will not turn on, can't find reset button.
    Problem Solver:
  • 15 Answers
Plug it to your computer, load up itunes, if your ipod owners link comes up, find your factory reset button, you won't lose any music or info, it will just reset itself to the settings when you first bought, i had the same problem.
Posted on Jun 21, 2009
It's blank
Try to reset the IPOD by holding center button and menu button for about 15 sec...... so that IPOD resets all the eliments.. hople this help u.
Jul 23, 2009 | Apple iPod nano
My Computer and iTunes does not recognize my iPod
put your ipod in disk mode by following these steps.
press and hold the Menu and Center buttons on the clickwheel. when you see the apple appear, switch your fingers to the center and play/pause buttons.
whena check mark appears plug it into you computer and it should detect and mount.
add music and have fun.
May 24, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
My screen is blank and nothing is working
To reset iPod nano:
1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the
Apple logo appears.
Mar 15, 2009 | Apple iPod nano
turn hold on then off, then hold down menu and select untill screen shows apple symbol.
Jan 15, 2009 | Apple iPod nano
My 4 GB ipod nano has a blank screen but still lights up, blank with NO logo and I can play songs there is just no way to see what you are doing. I unplugged the ipod and the screen has been lit and blank...
First of all try rebooting your Ipod by holding down the center button while holding down on the menu button at the same time. When the Apple logo appears, you Ipod is rebooting.
If that doesn't work, restore your Ipod back to factory setting in Itunes. It could be that the brightness and contrast settings of your screen got out of position allowing the screen to appear blank.
Aug 18, 2008 | Apple iPod nano 3rd Generation
My ipod nano wont do anything
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Hope this helps
Jul 19, 2008 | Apple iPod nano 3rd Generation
Restoring my Ipod!
Try resetting the iPod, this usually works.
As follows:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Hope this helps
check out my blog
http://www.pchelpforanyone.blogspot.com
Mar 13, 2008 | Audio Players & Recorders
I connect Ipod to computer it will not sync
As follows:
http://www.pchelpforanyone.blogspot.com/
Mar 10, 2008 | Apple iPod nano
White screen, have to do a soft restart and then words show up
if you are having the problem of a blank white screen, dont freak out! hold down the menu and select button for about 15 seconds or until the appel logo appears.if this doesnt work try plugging in your ipod. if that doesnt work wiggle the lock and unlock button a couple of times. if all these soulutions dont work go to www.apple.com and call customer support
Nov 13, 2007 | Apple iPod nano
Apple iPod nano Logo
71 people viewed this question
Top Apple Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
mac colar
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
